Question about Garmin eTrex GPS Receiver
Downloadig from memory map
Each time try to download a route from memory map to computer, get error message 0,
dont understand whats wrong, what settings do i need on my etrex.
please help if you can
regards
matt goldie
  • Garmin Master
  • 638 Answers
Is Mapsource installed on your PC?
Are you using the "Receive from Device" icon?
Is your unit being recognized when you use "Receive from Device"?
If your answers are yes to all of the above, you might have to update your Mapsource programme (free of charge) from the Garmin Website. Also, updating your unit software from the Garmin site is also a good idea.
Please let us know if this fixes your problem.
Posted on Apr 05, 2008
"Detail maps Don't Support Routing" in Garmin Quest
I too have a Garmin Quest and yesterday felt like throwing it against the wall because of the above problem. I found the solution eventually. When you download the maps from the Garmin Maps page, where you select the maps download, make sure that the checkbox to "Include route calculation data" is ticked before downloading your maps. Also make sure that the total memory required for the number of maps selected does not exceed the available memory on your Quest. If you try to fit more information into your Quest than it can receive then you are bound to have some problems. The Quests seems to have different memory specifications. According to the USA spec the memory is only 128mb, the Garmin site says 115mb and the box that my Quest came in says that it has 243mb.
Jul 10, 2009 | Garmin Quest GPS Receiver
Company Share Drive access error.
is the drive mapped if so you may need to attach the drive again look under mapped drives and if it dont show there then click on tools map drive select the appropate drive letter and path you can look on another machine just click on my computer tools map drive get the info write down and type it or click over to it select it and bam your back....
Jun 26, 2009 | Microsoft Windows XP Professional
NO DETAILED MAPS FOUND TO SUPPORT ROUTING
You need to unlock the unit. I had the same problem with one that I have. Try this:
The No Detailed Maps Found That Support Routing message could be due to the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message No Detailed Maps Found That Support Routing disappears.
  • If you get a Can't Unlock Maps message following this error remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file.
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device.
Retrieving your unlock codes:
  1. Log into your myGarmin account: https://my.garmin.com/mygarmin/customers/myGarminHome.faces
  2. Select myMaps.
  3. Select Manage Maps.
  4. Select the device from the drop down menu.
  5. The unlock code is located under the "Maps installed on this device" section.
Creating an unlock code file:
  1. Plug your Garmin device into the USB port.
  2. Double-Click on My Computer or Computer located on the desktop.
  3. Double-Click on the Garmin or nüvi drive.
  4. Double-Click on the Garmin folder.
  5. Right-Click in a blank space in this window.
  6. Move your mouse over the word New.
  7. Select Text Document.
  8. Press Enter / Return on your keyboard.
  9. Double-Click on the New Text Document. This will open the New Text Document in a window called Notepad.
  10. Type the unlock code that is listed in the Manage Maps section of your myGarmin account in all upper-case letters with no spaces before or after.
  11. Select File.
  12. Select Save As.
  13. Change the Save As Type to All Files.
  14. Type gmapprom.unl in all lower-case letters for the File name.
  15. Select Save.
  16. Close the Notepad window.
  17. Delete the New Text Document file.
  18. Disconnect the GPS device from your computer.
*nuvi x70 owners with transatlantic mapping will need to follow the Creating an unlock code file instuctions above for their U.S. mapping and then create another unlock file for their European maps:
  10. Type the European unlock code that is listed in the Manage Maps section of your myGarmin account. This will need to be typed in all upper-case letters with no spaces before or after.
  11. Select File.
  12. Select Save As.
  14. Type gmapprom1.unl in all lower-case letters for the File name.
  15. Select Save.
Enabling maps on the GPS device:
  1. Touch the wrench icon on the Where to/View map screen.
  2. Touch Settings.
  3. Touch Map.
  4. Touch Map Info.
  5. Select the checkbox next to the maps to be enabled on the device.
If you continue to receive the No Detailed Maps Found That Support Routing message after completing these steps please contact Garmin Support: http://www.garmin.com/garmin/cms/site/us/support/supportcontact
Feb 03, 2009 | Garmin nuvi 260W GPS Receiver
Error message when I turn NUVI 260W on....
Try three things:
1)Do a reset
2)Do a Master reset
3)Try doing a full software update by getting the free program from Garmin called WebUpdater.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To download the latest unit software visit Garmin website: www.garmin.com/webupdater
After installing WebUpdater once from the Garmin website, perform all future software updates from your computer. Simply connect your compatible Garmin device to your computer, then run WebUpdater from your computer's "Start Menu" by selecting "Start", "Programs", "Garmin", and finally "WebUpdater"
Normal 0 false false false MicrosoftInternetExplorer4 REMEMBER: It takes hours to do a complete a map update.
Unless you bought the Lifetime maps you may have to pay for current maps.
Jan 21, 2009 | Garmin nuvi 200W GPS Receiver
I keep getting memory full message and route waypoints full on nuvi 610/660
The Navigator memory card will come with the a countrie's maps. Maybe you need to take the memory card into the computer and download more maps. Also try to erase the nt middle east location and start over.
Artgirl
Jul 08, 2008 | Garmin Nuvi 610 GPS Receiver
Drawing
This happened to me twice, and both times were after I had downloaded a long route. Both times, the only available fix was to do a "hard reboot" by selecting page-OK-power and then selecting "yes". That restored operation, but it also deleted the downloaded maps, routes, and waypoints, and forgot my preselected options.
(In MapSource, I had used the "Select maps around route" option, and both times the total memory associated with the selected maps was much less than 115MB - one was 59MB and the other was 63MB. And in three years this has never happened when fewer maps were loaded. My experiences therefore suggest that the actual working memory available for downloading is much less than 115MB - I don't yet know what the actual limit is.)
May 24, 2008 | Garmin Quest GPS Receiver
Error message on screen (read message below)
Did you tried to update your Maps? There are two maps inside your Garmin. Basemap which covers all highways and major roads and mapsource source which cover regular streets. Try reloading mapsource maps.
From the "Where to" menu select the little wrench and then select map and then select Map info. What does it say for Map Info?
If the unit is still under warranty, call Garmin and get a RMA. Return the unit to Garmin.
Dec 25, 2007 | Garmin StreetPilot C330 GPS Receiver
TomTom One Europe
What is happening is your map updates are being copied onto your memory card without overwriting the old maps hence you are running out of memory.
In the tomtom home browser you should be able to delete your old map before installing the new one. Make sure you have a back up of the map card before you try this though so you can reinstall if something goes wrong.
Also have you replaced the voice prompts on your tomtom? The voice files take up a lot of memory so if you have put new ones one without removing the old ones you will be wasting memory.
There is one window in TThome that lists eveything installed on yuor card so have a good look at this and see what you can get rid of.
Oct 30, 2007 | Tomtom One Europe v2 GPS Receiver
Dell Axim + Tomtom. Routeplanning error
The error during planning is a map error not an OS error. It will give you this warning if you try to nav somewhere that it cant see any way of getting to because there is a gap somewhere en-route. Normally its the last 100 yards or something. The workaround is to nav to an adjoining road or somewhere very close to where you want to end up. Oddly or maybe coincidentally (which I doubt at 60,000 miles per year) I have only had this happen on the new maps.
Oct 22, 2007 | Dell Axim X5 Pocket PC
Garmin eTrex GPS Receiver Logo
67 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
