Question about Whirlpool RF380LXPS Electric Kitchen Range
WHIRLPOOL RANGE, RF386PXEW ACCUBAKE
I put the oven on autoclean, it works for a fee minutes, then I start getting error codes pf5, and other codes, the oven will not unlock, I have unplugges and the oven did unlock after hitting the off button
aborcass
  • 2651 Answers
SOURCE: What does E2 - F3 - code mean on a Whirlpool Accubake Gold??
F3 - E2 Oven too hot Replace oven temperature sensor
Posted on Jan 11, 2009
rockitman187
  • 2559 Answers
SOURCE: I get a E0 -F2- error code on my whirlpool Accubake GR450LXH2 ran
That mean that the key pad is shorted,needs replaced
E0-F2 Shorted keypad Replace Electronic Range Control/Clock (ERC)
Or
E0-F2 Oven temp too high
1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor
Posted on Jan 13, 2009
  • 4 Answers
SOURCE: Whirlpool Accubake Duo System electric range fault coes E4 F3
F3 code correlates to oven temperature. Either the oven temperature sensor is malfunctioning or the over-limit switch is open. This is usually the result of using the self-clean mode and the over-limit switch gets stuck open. It has to be replaced...not too bad of a job if you have some mechanical/electrical knowledge. Ask parts supplier for a schematic so location can be visualized (inside top cavity on oven wall with a couple of wires. Also, Sears carries parts for these ovens. Hope this helps.
Posted on Mar 12, 2009
localwonder
  • 6784 Answers
SOURCE: Whirlpool Gold Accubake Duo. ''E4 - F3'' or ''E0 - F3''
HI. These codes are an indication of oven temperature sensor failure. The sensor is damaged. This will not allow for proper operations. The affected part must be replaced, asap.
The sensor is, generally, located inside the oven, mounted on the back wall, on the top right, or left corner.It will look like a 4 inch long slender probe. There will be two screws holding the housing on the back of the oven wall. Once the screws are removed, the sensor will need to be extracted from the back side of the unit.
Posted on Dec 28, 2009
Testimonial: "Thank you so much. This is a job that my husband can do to fix it."
SOURCE: Whirlpool oven door won't unlock after cleaning
The motor that controls the door lock was bad. Go online and order a new motor based on range model number. User can fix if reasonably handy with tools.
Posted on Jan 08, 2010
I have whirlpool accubake model wle 3430 almost 10 years old and have a code E1 F1 and oven is not working ! 1 e
The F1-E1 error code means the control board has detected a problem within the control itself and the control board needs to be replaced
When ordering the control please note it may also be called the,CLOCK,EOC or Electronic Oven Control in addation to the control board..any of those names it will be the same part.
GENE
Sep 04, 2011 | Whirlpool Accubake SF362LXTS Kitchen Range
I am getting E0 -F2- error on my Whirlpool Gold Accubake oven display. If I press cancel it sometimes will start but has been working less and less. The range is quite old and I do not have a manual. What...
Shorted keypad (also called touch pad)
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Mar 29, 2011 | Whirlpool Accubake RF362LXTT Electric...
The oven doesn't work
unplg the system for 15 minutes then plug it back it. When you plug it back in make sure everything goes in straight. this is just trying to reset the system
Jan 02, 2010 | Whirlpool Accubake RF362LXTS Electric...
Oven clicks to self cleans or f3, the door locks and food burns
Replace the oven temperature sensor.
Take your model number to any appliance parts store for a replacement sensor.
Apr 20, 2009 | Whirlpool Accubake RF362LXTS Electric...
Or
Jan 13, 2009 | Whirlpool GR450 Electric Kitchen Range
Whirlpool Accubake oven super capacity series 465
Press and hold the Broil button for 5 seconds. You will see the c change to f. THen change the temp to what you need.
Dec 21, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool RF380LXPS Electric Kitchen Range Logo
123 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
