Question about Zenith P42W34P 42 in. EDTV-Ready Plasma Television
Black stripe down TV plasma screen
Sometime my plasma TV devops a black vertical stripe
  • 3 more comments
  • LON8767 May 04, 2008
    HAVE BLACK LINE DOWN SCREEN
  • gregandmaria Oct 20, 2008
    I have the same problem, only the line changes colors from black to rainbow stripes, and it is on a JVC Plasma.
  • Anonymous Nov 10, 2008
    Black verticle line that comes and goes and changes position on the screen
  • Anonymous Nov 19, 2008
    Black vertical line!
  • DLG2 Mar 20, 2009
    I have up to three black lines approx 1" wide that have been appearing in the middle of the screen of a 42 " Zenith plasma when it is powered on... The three lines appear randomly sometimes one, two or all... in the center, left of center and/or right of center.
    Scholar:
  • 50 Answers
I'm sorry you have not been given a clear ansewer on how to repair your TV. I know how to fix the problem you are having (1.5 inch Black vertical lines that come and go) If you still need help fixing your Plasma TV please feel free to message me @ [email protected] or just give me a call @ 1-503-432-9904 and I'll help you fix your TV buddy! Ask for Dave!
Talk to you later buddy!
Dave
[email protected]
Posted on Feb 03, 2009
SOURCE:
Black Vertical Stripe Our Hitachi plasma TV has just started displaying a vertical black stripe about three inches wide right down the middle of the screen. This stripe comes and goes every hour or so,...
try doing white wash feture in options see if u can get it out this way 1st before having to take aprt cheak cables are using old style sumtimes they do get glitch do factory reset thx for using fix ya . nick
Feb 03, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Half of my screen will turn in to vertical colored stripes
T-con board. Check lvds cable for tight connection.
Sep 15, 2009 | LG 42LC2D 42 in. LCD HDTV
if your TV is still under warranty, call Samsung to get it fix. I seen this problem and is quite expensive to repair
May 27, 2009 | Samsung LN-T4665F 46 in. LCD Television
42" Panasonic Plasma - Vertical red stripe 6" from left side
We originally had a red stripe roughly 3" wide running vertically on the ride edge area of our Panasonic 52" Viera plasma tv. It has now been joined by a solid black stripe of the same width running from the top to the bottom. Living in Germany and purchased at local PX long enough ago that the warranty is likely expired. Now what?
Jan 18, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Vertical lines down center of Plasma TV
Because of the complexity of these sets, the fault can be much more than just a bad IC. These sets are serviced at the board level. After changing the board, calibration is done as necessary.
The fault may be in the matrix power driver output area, or in the plasma screen back-plane layer itself. This has to be determined by the process of elimination.
I can tell you in advance that this will not be a low cost repair.
Jerry G.
Jan 10, 2009 | Philips Magnavox 42MF521D/37 Television
Black lines on sony plasma tv
go here, it will work.  follow closely and read entirely!  it worked for me on a gateway plasma!
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed.html
enjoy!
stephen
Oct 27, 2008 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Hitachi 42EDT41 plasma model-1" black stripe on right side
This is an old post but maybe it will help others. You will have to take the back off of the TV. On the bottom you will see ribbon cables coming from the screen and connecting to 3 PC boards. Take the screws out that holds the cable down. Underneath you will see 4 resistors marked 100. All you have to do is re-solder the resistors and your vertical line will be gone. You need to be good at soldering or you could damage the ribbon. The only ones that you have to re-solder is the ones in line with the lines on the screen.
Jun 06, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Philips plasma tv vertical black stripe
Ok did this happen the first time u turn on the TV. ? If so u might have a ribbon cable disconnect from the logic or u might have a defective Plasma panel. If u have a defect like your describing the IC's on the panel short out and no longer work causing that section of the screen not to function. Only fix then is replace panel
Apr 26, 2008 | Philips 42PF9630A 42 in. Plasma Television
along the sides or the center ? if on the sides check the picture format and see if it changes. If its doesn't go away sound like u might have a defective IC on the ribbon cable that plugs into the plasma panel
Apr 05, 2008 | Televison & Video
Zenith P42W34P 42 in. EDTV-Ready Plasma Television Logo
1,931 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
