Black stripe down TV plasma screen
My TV plasma has a black stripe that sometimes appears on the screen?
  • 1 more comment
  • Anonymous Aug 11, 2008
    A vertical black stripe on the left-center part of my plasma screen appears.
  • Anonymous Jan 03, 2009
    I have the same problem. the black vertical stripe suddenly appeared just right of center. there was nothing I could do to fix it. Just as suddenly it went away. The stripe existed on every AV input I used and in on all channels. It was even on the PC connection, so it was definately a tv problem and not a connectiong problem.
  • kate_wes May 09, 2009
    We have a black stripe down the left hand side of our 50cm lg plasma. It is only 6 months old. Any ideas??
  • 72 Answers
Along the sides or the center ? if on the sides check the picture format and see if it changes. If its doesn't go away sound like u might have a defective IC on the ribbon cable that plugs into the plasma panel
Posted on May 03, 2008
Panasonic TC-P42S2 .. Transparent 2 inch wide vertical discoloration on panasonic 42 inch plasma, very left of the screen.
Fixed mine, myself! Black 3 inch vertical band (stripe) appeared after a cros country move on our PC-T50G10. Occasionally we would see white band with multicolored pixel width stripes. Took the risk of taking off the back to see if I could see anything. Found places on sides and bottoms where plastic like 2" flat cables could be seen. Guesstimated where the band was and found that I could flip down a black cover on one end of the cable. Tried to pull it, gently. Mistake. Realized it wouldn't one out like computer hard drive cables, so I took out the screws holding the plate on the other end (it's only an inch long). That allowed me remove the cable. Took it out, cleared away dust, put t back and closed the black over. It worked! Put the screws back in, back on and... we are happy (although I do have four extra screws!). Just be gentle.
Feb 17, 2012 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Black Vertical Stripe Our Hitachi plasma TV has just started displaying a vertical black stripe about three inches wide right down the middle of the screen. This stripe comes and goes every hour or so,...
try doing white wash feture in options see if u can get it out this way 1st before having to take aprt cheak cables are using old style sumtimes they do get glitch do factory reset thx for using fix ya . nick
Feb 03, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Get a black line down the center of the screen. IT can have 2-8 white lines or red llines within the black stripe. It use to come and go but now is there all the time!
It's caused by a poor connection betwwen the screen and the rear circuit board. There is a conductive rubber filler which is used to bridge the connection and it can move off line. You can sometimes sort it by GENTLY flexing the casing.
Apr 04, 2010 | LG 42PX4DR 42 in. Plasma TV
Black line on plasma tv
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Jul 19, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
if your TV is still under warranty, call Samsung to get it fix. I seen this problem and is quite expensive to repair
May 27, 2009 | Samsung LN-T4665F 46 in. LCD Television
Philips Plasma Black Stripe
We have the same problem with out TV. Apparently the problem is the drivers.
Sep 08, 2008 | Philips 42PF9630A 42 in. Plasma Television
Hitachi 42EDT41 plasma model-1" black stripe on right side
This is an old post but maybe it will help others. You will have to take the back off of the TV. On the bottom you will see ribbon cables coming from the screen and connecting to 3 PC boards. Take the screws out that holds the cable down. Underneath you will see 4 resistors marked 100. All you have to do is re-solder the resistors and your vertical line will be gone. You need to be good at soldering or you could damage the ribbon. The only ones that you have to re-solder is the ones in line with the lines on the screen.
Jun 06, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Philips plasma tv vertical black stripe
Ok did this happen the first time u turn on the TV. ? If so u might have a ribbon cable disconnect from the logic or u might have a defective Plasma panel. If u have a defect like your describing the IC's on the panel short out and no longer work causing that section of the screen not to function. Only fix then is replace panel
Apr 26, 2008 | Philips 42PF9630A 42 in. Plasma Television
I'm sorry you have not been given a clear ansewer on how to repair your TV. I know how to fix the problem you are having (1.5 inch Black vertical lines that come and go) If you still need help fixing your Plasma TV please feel free to message me @ or just give me a call @ 1-503-432-9904 and I'll help you fix your TV buddy! Ask for Dave!
Talk to you later buddy!
Apr 05, 2008 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Televison & Video Logo
1,958 people viewed this question
Top Televison & Video Experts
