Loading 2 operating systems
How do i load a second os on my notebook. it came pre installed with windows vist. tanks
  • 9japekin Apr 05, 2008
    how do i switch between both operating systems
    Problem Solver:
  • 11 Answers
Due to arow key when your pc boot there was it ask u will go xp or vista
Posted on Jul 10, 2008
  • 813 Answers
Hi friend
click here to under stand how to make ur pc dual boot
Posted on Apr 05, 2008
Satellite a75-s209: error loading os
The OS installation may be corrupt. Remove all USB drives and discs from CD and try again.
You will need to run a repair or possibly re-install Windows (onto itself).
Jan 09, 2013 | Toshiba Satellite A75-S209 PC Notebook
I m lookin for installing dual boot with Vista ultimate n Windows 7, gotta dvd for both, any help??
If you wan to fresh install, here you can do ::
Try following steps.
Restart the PC, Press Delete for some time
It will lead you to BIOS setting
Go to the Boot Priority menu,
select DVD ROM as First Boot and HDD as Second Boot
Now Insert your Operating system CD: Vista Ultimate
Restart the PC and when screen says " Press any key to continue"
hit "enter"
Let the CD load and then select New Installation
Format the drive by pressing L, and then create three partition , 100 GB for Vista Ultimate, 100 GB for Windows 7 and rest for data.
Hit enter and let os Load
After complete OS loading, system will restart and again you will see " Press any key to continue"
DO NOT PRESS ANY KEY.
OS will boot and register it with microsft. create login and then remove OS DVD,
Insert the Windows 7 DVD
restrt the system, Hit enter when it says " enter any key to continue"
select new installation, point to the earlier created partition for windows 7 installation
proceed with same procedure.
after complete installation, when you restart the pc, you will find both the BOOT entries at booting.
do not forget to load device drivers on both the OS.
Enjoy!
Sep 07, 2010 | Acer Aspire 5610-4648 Notebook
USB port not registering
Try with different USB devices on all the USB ports of your Notebook. Check if those devices which is not detecting in the Laptop, working on other systems.
(If one of the three is not working, then its a hardware issue). If all the ports are not working, you can try the following steps.
1:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and do NOT connect the battery now.
5. Turn on the Notebook power.
2. Update your BIOS:
a) Open www.hp.com in the search field type your Laptop product number (eg:AB123UA), can be found on the sticker pasted on the bottom of the Laptop.
b) Click on Software & Drivers
c) Select the Operating System (Make sure you are using pre-installed OS only)
Note: Do not install BIOS on retail or changed OS
d) Install BIOS and restart.
3. Re-install USB entries
1. Save and close all programs that are currently running.
2. Click Start, select Shut Down, and choose Restart the computer.
3. Press the F8 function key or the Ctrl key when the HP logo appears. This will display the Windows Startup menu.
4. Select option 3 to load Windows in Safe mode.
5. After Windows loads in Safe mode, Click Start and select Control Panel.
6. Double-click the system icon. If the System icon is not found directly under Control Panel, click the Performance and Maintenance icon and then click the System icon.
7. The System properties Window opens. You can open the System Properties window directly by pressing the Windows key and Pause/Break key simultaneously.
8. Select the Hardware tab and click the Device Manager button.
9. In the Device Manager Window, double-click the Universal Serial Bus controllers.
10. Right-click the device listed under Universal Serial Bus controller and select Uninstall.
11. Click OK to confirm the removal of the device.
Restarting the notebook will automatically install the drivers.
That's it. If there is no luck, your Laptop required an onsite diagnose. Contact HP or local service center.
Jul 27, 2010 | Compaq Computers & Internet
Windows vista isn't starting up due to corrupted file. How do I log in/
If windows Vista OS isnt loading then your Operating System ( OS ) is corrupted. Try running the installation disk and repairing your system. If this fails you will need to do a FULL operating system re-installation.
May 20, 2010 | Dell Inspiron 1525 Notebook
Hello. I got a Toshiba m305-4848 pre-loaded
You have to format the drive...Vista can go"over" XP,but XP cannot override Vista.Or partition your drive and get a dual boot system, then you can choose either O.S., like I have.
Mar 22, 2010 | Computers & Internet
How to reformat my MSI notebook?
You need to have an valid Operating System installer CD/DVD. This could be a Windows or Linux installer or whatever Operating System that you prefer.
  1. Turn your laptop on.
  2. Open the CD drive and load the CD Installer.
  3. Reset your laptop to manually reboot it. If you loaded the CD fast, this step is no longer required.
  4. The setup program will then load. Follow the onscreen procedure.
  5. At the point of selecting the hard disk drive, choose "Delete Partitions" to completely remove all data.
  6. After deleting partitions, create new partitions for your hard disk. You can choose to divide your hard disk capacity into 2 or more partitions depending on your requirements.
  7. Format the root partition now (Drive C) to continue the installation.
Mar 03, 2010 | Computers & Internet
No operating system not found comes up. It is a
You must install your OS (Windows XP, Vista, Windows 7, etc....)
Nov 21, 2009 | Sony VAIO VGN-BX760NS2 Notebook
"error loading operating system"
Sounds like your Windows XP installation failed. Run the XP install again making sure to delete the existing partition and then create a new partition. You could also have a bad drive out of the box.
Sep 15, 2009 | Dell Latitude D600 Notebook
Computers & Internet Logo
140 people viewed this question
David Payne
David Payne
