Question about Apple iBook Mac Notebook
USE OF APPLE COMPUTER
Can I change the program in my computer, A Dual USB Apple, that is may be to install Window XP?
My computer don't accept ethernet cable, that is the RJ45 socket don't fit, is apple have their own RJ 45 socket or what else I need to apply so as to access internet.
    Novelist:
  • 137 Answers
Make sure you are putting the cable into the right socket. This picture shows them. Use the second from the left. Make sure the socket is clear of debris or bent/broken pins. Also make sure you are using the correct cable for the connection. It does fit normally, so I'm guessing that some piece of plastic or metal is bent or broken.
Posted on May 23, 2008
One. A PowerPC iBook like yours can only install Windows XP through emulation. This means that Mac OS X has to be installed to run the emulator. It will also run slower in emulation mode, meaning that XP will pretty much only be good for word processing. The newer intel Macs like the imac and macBook can install Windows XP natively even without Mac OS X installed!  two. It's weird how the etherent cable doesn't fit? Apple uses standard ethernet cables, so....
Posted on Apr 06, 2008
My ipod touch is brand new. I can not get it to accept my itunes gift card
I suggest installing iTunes on a computer that you own, log-in with your Apple ID and then try to redeem the gift card.
If you don't already have an Apple ID, then this is probably the problem. You can create an Apple ID using iTunes.
You can download iTunes to your computer from this link (click here).
Follow the directions on the page to download and install iTunes to your computer.
Good Luck and let us know how this turns-out.
Dec 27, 2011 | Apple Ipod Touch 4
Itunes or windows wont recognize iphone 3g
uninstall itunes and the other components such as quicktime, apple mobile device support, apple application support,apple software update and bonjour.
  • go to your control panel and add or remove programs(win vista or 7) or programs and features(win XP)
  • remove the stated programs from above, restart your computer
  • visit apple.com/itunes and download iTunes and install.
  • plug your iPhone in and then it will load the driver for it and then be recognized again by your itunes and computer
Dec 15, 2010 | Apple iPhone 3G
I have a 5th generation iPod Nano. I've had it less than one year, and now whenever I plug it into my computer with the USB cord that came with it, my computer says "USB device not recognized" and that the...
  • Check system requirements. - iPod nano (5th generation) requires the following minimum versions of Windows: either Windows XP (Service Pack 3 or later), Vista or Windows 7. If you have one of these versions of Windows, verify that Windows is fully up to date by downloading and installing software updates from Microsoft. If you have Windows XP with Windows XP Service Pack 1 or Windows XP Service Pack 2, download and install Service Pack 3 using Windows Update.
  • iTunes online? - Confirm that iTunes has been downloaded and installed.
  • AMDS online? - iPod nano requires Apple Mobile Device Support (AMDS), which should be automatically installed with iTunes. To verify whether it is installed, click Start > Control Panel. Open the Add or Remove Programs control panel and verify that Apple Mobile Device Support is visible in the list of currently installed programs. If it is not, remove and reinstall iTunes.
  • Check USB connection. - Disconnect all USB devices from the system with the exception of the iPod nano and any USB keyboard and mouse. Then restart your computer. Verify that you are using a high-powered USB 2.0 port. Test with an alternate iPod USB cable if one is available.
  • AMDS - Re-verify that AMDS is running and installed.
  • iTunes usage - Remove and reinstall iTunes.
hope this helps
Oct 14, 2010 | Audio Players & Recorders
Hai mr.igot problem when i install usb bf-810 iwas isntal driver but when i plug the port inthe PC it's show"USB devivice not recognice"can u solve my problem
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 98 or Windows® ME driver 5.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 5.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 5.3 Select the “Next” to install.
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 2000 driver 6.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 6.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 6.3 Select the “Next” to install.  Before you start installing the driver, please Don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® XP driver 7.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 7.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 7.3 Select the “Next” to install.
.1 Driver Installation (MAC OS X) 8.1.1 Power on your computer and make sure that USB port is enabled and working properly. 8.1.2 Insert the USB adapter software driver into CD-ROM driver. 8.1.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS X " folder run on "PL2303_1.2.1r2.dmg", it will auto run the program and appear "PL2303 driver" folder in the desktop. 8.1.4 Click on "PL2303 driver" folder , execute "USBSerialOSX1.0.9b6.pkg" will auto install, you may change the driver directory that you want to install. 8.1.5 System will demand restart computer. 8.1.6 Plug in the USB-Serial adapter into USB port. 8.1.7 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". 8.2 Driver Installation (MAC OS 8&9) 8.2.1 Power on your computer and make sure that USB port is enabled and working properly. 8.2.2 Insert the USB adapter software driver into CD-ROM driver. 8.2.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS_89" run on "PL2303_OS9_v136b1.hqx",it will auto run the program and appear "ProlificUSBSerial" file. 8.2.4 Copy "ProlificUSBSerial" file into "system folder"-"Extension". 8.2.5 Plug in the USB-Serial adapter into USB port. 8.2.6 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". Follow the steps below to install driver of USB-Serial adapter:
hope that helps you
May 29, 2010 | BafoTech BAFO BF-810 Serial Adapter
ITunes freezes after 8.1 upgrade on Vista PC
Apple has made it harder and harder to use our ipods over the last upgrade especially.
I am running itune 8 on vista home basic and I have the same problem.
But since I repair ipods i put numerous ipods on this system and it doesn;t work that great with any of them.
although I have found one solution that really has helped with alot of connection issues and ipod crashing in vista. I installed a usb 2.0 card in my computer and only use it for my ipod cable and it has helped.
Most of the iPods and iPhones only will connect with a 2.o usb port anymore.
So if you have a usb 2.0 use it, if you need drivers get them and reinstall them in your computer to get the fast usb connection. it is still slow in itunes but it's much better.
as for iTunes 8 and why it crashes, well it is an apple product. the don;t care about the ipod, it's a throw away product for them. They want you to buy a new one. But in this day and age, they should give us a break and start making the products so they are user friendly. Thats why Mac has never really exploded. They are too expensive and they don;t support their products. Even the Geniuses at the genius bars in Apple store done know **** about their own products, they just give refubished ****.
Good luck and sorry for the Rant!!!
Apr 04, 2009 | Apple iPod classic MP3 Player
My apple ipod shuffle USB is not responding.
try to re install your usb driver again.
Feb 09, 2009 | Apple iTunes
I bought a dynex cardreader for my apple computer
You have an apple iBook?
Don't install any software for the memory card reader.
Just plug it into the USB port on the iBook and open a Finder window (from the desktop hit Apple/N) or click on the desktop, then go to the menu at the top, and in the FILE menu select New Finder Window.
The card reader will show up as long as it has a functioning memory card in it. There is no need to install any software.
With Apple computers this is generally true with any peripheral, including printers and other devices. The Apple operating system has much better support for peripheral devices than what you might be used to with PCs, and generally additional software or drivers is not needed, and allowing the computer to do it automatically is much more trouble free, and obviously easier.
For audio and PA System expertise and help with feedback with your PA system, see my website at www.rexark.com
May 24, 2008 | Dynex External USB 2.0 Multiformat Memory...
Purchased computer model Elite 9070a have been well serviced with HP products this being 3rd HP computer we have purchased. However am very disalusioned with Vista program and wish to replace with windows...
You sound like you tried to install XP with Vista running - this will generate the message that you have received.
To install XP on your system, insert your XP disk into the computer and then restart it.
Select Boot From Disk during start up and this will lead you into the XP Installation.
Xp will not recognise Vista and will just overwrite it - deleting the current OS and formatting the C:\
Good luck.
Apr 23, 2008 | Computers & Internet
My computer does not reconize ipod
plz change usb cable it is wrong.
Mar 01, 2008 | Audio Players & Recorders
Ipod nano to Millenium computer
Technical Specifications: iPod nano Mac system requirements: Macintosh computer with USB port (USB 2.0 recommended) Mac OS X v10.3.4 or later Windows system requirements: PC with USB port or card (USB 2.0 recommended) Windows 2000 with Service Pack 4 or later, or Windows XP Home or Professional with Service Pack 2 or later http://www.apple.com/ipodnano/specs.html
Jul 10, 2006 | Apple iPod nano
Apple iBook Mac Notebook Logo
100 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
