Question about Miele Novotronic Premier 500 Front Load Washer
Miele Premier Novo Washing Machine: Water coming straight out of the machine
When I turn my washing machine on, water pours straight out of it. Investigating a little bit I have found that it comes out of the little tap that is next to the fiter.
I have opened up the filter and cleared out the small amount of gunge, and have cleaned the rather dirty detergent drawer, but whatever you do water seems to pour straight out of the machine.
I think it is possible that there may be some sort of blockage into the drum, (perhaps from fabric conditioner building up or something) or that some valve isn't doing the right thing.
Does anyone have any idea what I should do. There is a bit in the manual that says that you need to pour 2 litres of water into the machine to re-enable a ball valve after removing the filter. However, this two litres just pours out of the little tap.
Any pointers or siggestions would be very greatfully received.
  • Anonymous Aug 22, 2008
    I have exactly the same problem. When I turn on the machine the water pours out of the over flow
    New Friend:
One possibility is a problem I had today. Water was pouring out underneath the machine as it was starting the fill cycle. (i.e. pulling water in from the mains to fill the drum)
I thought it might be coming out if the manual drain as the water was pooling at the front left of the machine.
However, when I opened up the machine it turned out that the water was leaking at the point it enters the drum. After the washing powder drawer, water goes down a concertinaed hose into a light grey U-bend which fits into a grommet sited in an aperture in the cast iron frame that supports the drum (suspended by springs).
The U-bend unit had simply come loose (though you wouldn't notice this at first glance) and required only for it to be firmly pushed back into the grommet (it goes in further than you think at first).
I've run two full loads leak-free since my fix, but obviously I now feel I need to keep an eye on it in case it comes loose again - it's 14 yrs old after all. Better than buying a new one though I guess.
Posted on May 27, 2013
  • 128 Answers
The lower left panel is a filter that should be cleaned out regularly - the filter is also connected to the drain pump which rids the washer of the water. When you clean the filter out - make sure you have a bowl or Tupperware handy that holds about 2 quarts - slowly remove the filter and the water will drain into the bowl. Clean out any debris and reassemble. If the filter is not seating properly in its seat - water will leak from the small hose - the filter is what blocks the water from coming out of the hose.
Posted on Nov 30, 2008
  • J Rowe
    J Rowe Dec 20, 2014
    Unfortunately this comment misses the point
    New Friend:
    Problem Solver:
I have the exact issue the original poster has had. Water coming out of the overflow pipe situated at the left hand foot of the front panel.
However, the two comments suggested as a possible symptom and solution don't appear to be resolve the issue.
Can anyone else offer a suggestion?
If I succeed, I shall post my solution here. Thank you for your assistance in advance.
Posted on Dec 20, 2014
  • mpservices Dec 20, 2014
    The little Pipe on the front of the machaine is not an overflow - it is the drain for the lint filter. If the lint filter is screwed in all the way and water is still coming out of the little hose then the lint filter is not sealing or sometihing in the cavity is blocking it from sealing. Hope this helps
Miele 500 washing machine inlet light comes on and machine wont pump water out or spin
try leaning against door when pressing start . if it runs get the switch replaced
Jan 24, 2016 | Miele Novotronic Premier 500 Front Load...
Miele premier novo, the main wash light flashing
Hi
Main wash is a fault indicator. The is a problem within the heater circuit, NTC, element, relay or loose wire. You will have to open front and check.
Remove 3 screw around dispenser and 3 10mm bolt around door. disconnect hose by drain pump and front of machine will open like a door.
Apr 01, 2010 | Miele Novotronic Premier 500 Front Load...
Leak from tap at front of machine
the filter may not be sitting right in its slot - an obstacle may be keeping the filter from being seated all the way - once the filter is fully seated, it blocks the water to the front tap
Oct 27, 2008 | Miele Novotronic Premier 500 Front Load...
Open drain door at bottom front left of machine. Pull yellow tab that is there. This is the manual door opener.
Jul 15, 2008 | Miele Novotronic Premier 500 Front Load...
Miele leak when switched on for wash, from filter unit front LHS bottom of machince
You can replace the Bellows as it is called but to fix it before you replace it clean it with Bleach to kill the mold and then dry it ALSO after any load you do leave the door open a bit this allows the mach to air dry out and prevents the build up of mold ..Good Luck plz rate this post for me
Feb 17, 2008 | Miele Novotronic Premier 500 Front Load...
Miele novo w526
Can you hear the drain pump running??....If so the WPS system has been activated and there is water in the base.
If not, please post back if any water is going into the main wash compartment once it's started. No water, then faulty inlet valve.
Jan 21, 2008 | Miele Novotronic Premier 500 Front Load...
Miele washing machine
All Miele washing machines and dishwashers need to fill in a required time. Flashing inlet (Tap icon) indicates that the machine can not fill in time. There are filters in the end of the hoses which connect to your water supply from the machine and filters in the inlet valves which you can get at by removing the hose from where it fixes onto the machine it'self. You will need some long nose pliers to grab the little tab on the small filter to get it out. Clean all filters and hoses. Still same problem then check the pressure of the water coming into the machine. There should be a good pressure coming out of the hose and will be difficult to stop the flow of water with your finger.
Dec 20, 2007 | Miele Novotronic Premier 500 Front Load...
Miele Premier novo washing machine
Flashing rinse light is a drive fault. No motor action. If it's an earlier model it would be the motor brushes. Later model will be the electronic which controls the motor.
Aug 10, 2007 | Miele Novotronic Premier 500 Front Load...
Miele Novotronic Premier 500 Front Load Washer Logo
775 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
