Time and date will not store - Computers & Internet
    Problem Solver:
  • 5 Answers
Try replacing silver round watch like battery on mother board first.
Posted on Oct 08, 2012
  • 813 Answers
Hi friend
chage ur mother bord battery im shore your problem will be sloves
thnx using fiya
Posted on Apr 05, 2008
How to activate date/time stamp on nikon d90
The date and time are stored with the picture as metadata, but the D90 won't mar your photos by scrawling a string of numbers on it. Any good photo editing program will let you print the date and time on the picture, in the margin, or on the back, depending on your printer.
Dec 03, 2016 | Nikon DSLR D90 Digital Camera
Date and time wrong on start up
This indicates the BIOS battery is flat and therefore cannot store the correct date and time in the BIOS. You need to install a new BIOS battery and then go into the BIOS setup to set the Date & Time.
Nov 14, 2012 | Advent Clearance 5411 Laptop...
Date time not set
When you change the date and Time to the correct Date and Time and when you next boot up the laptop the Date and Time is lost. Then this is caused by a flat BIOS battery which cannot keep these setting stored in the BIOS.
Replace the BIOS battery then go into the BIOS setting to set the Date and Time and this will fix your problem.
Apr 18, 2012 | Computers & Internet
How to set date & time
To set the Date and Time on your computer - go into the BIOS configuration then to Date and Time to set the correct Date andTime.
If the Date and Time needs setting up again after to boot up the computer again, then the BIOS battery needs replacing because the old battery is flat and cannot maintain (store) the Date and Time.
May 19, 2011 | Computers & Internet
We have a Panasonix KX-T7731 phone system with 7 different extensions. How do I program each individual phone so that the date and time appear on the phone display?
With the handset on the cradle:
Press Program button
Enter *#
Enter the system password - system default is 1234
Enter 000
Press the Auto Dial/Store button
Enter date using the Scroll button (the round one used for spkr volume) to move to right and left to next field
Press Auto Dial/Store button to accept setting
Press Redial button to move to time
Enter time using Scroll button (the round one used for spkr volume) to move to right and left to next field
Press Auto Ans/Mute to exit Date & Time
Press Program Button to complete
Dec 30, 2010 | Panasonic KX-T7731 Corded Phone
Setting date and time on photo
As long as the current date and time are set correctly, the camera will always store the date with the picture. If you want to print the date with the picture, please refer to the documentation for whatever program you're using for instructions.
Apr 16, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic KXT7453
To set date and time on your phone system you must first enter user programming mode.
Using a display phone with the receiver hung up.
Press PROGRAM
Dial ** 1234 (SYS PROG NO)
Dial 000 (DATE AND TIME)
Press SP-PHONE key once (display shows current date)
Normally this is correct if not dial the changes in with your keypad. Use the FWD\DND key to
move forward on the display and the CONF key to move backwards.
Press AUTO DIAL STORE (Confirmation tone)
Press SP-PHONE key once (display shows current time flashing on hour)
Dial new hour (Two digits) Use the FWD\DND key to move forward on the display and the
CONF key to move backwards. Dial in any changes and when your done:
Press HOLD (SYS PROG NO)
Press PROGRAM
Your phone should be back to normal.
Nov 03, 2008 | Panasonic KX-T7453 Corded Phone
Samsung idcs 18d
got the scoop on how to change the date and time. first while handset is on hook press TRSF then dial 200 Dial 1234 the display shows enable cus prog dial 1 to enable then press TRSF To change the date and time from here out press TRSF and dial 505 the display will show : (this is an example)
old: 6010104:0047
new:WMMDDYY:HHMM
Enter the new time and date using the above format and the system will return to step 2. Verify the time and date and re enter if necessary Press TRSF to store and exit. or press SPK to store and advance to the next program.
Mar 10, 2008 | Lands Phones
Print the date on the image/photo
It is not possible to embed the date/time stamp as part of the image itself with the XT. The date/time information is stored as part of the exif information stored in the image at the time of shooting.
However, you do have a couple options for printing images with the date/time stamped onto the image:
If you use the direct print capabilities of the camera when connected to a compatible printer (PictBridge, CP, or DirectPrint are all supported), you are able to enable an option that will print the image with the date/stamp printed on the image. There are also software packages that you can use that will do the same when printing from the computer.
And finally, it is possible, with some photo finishers, to request that they imprint the shooting date/time on the image. This will vary from photo finisher to photo finisher, and the will be some who can't, or won't, do this.
Dec 30, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Date code or time code
date & time is already stored in EXIF header. If you want them to appear visible, there're a lot of software will do that. Use QImage Pro to print, and i can print date & time on it, or save to files. If you use Linux, you can write simple script to put date & time stamp on JPG files.
Sep 07, 2005 | Olympus C-3000 Zoom Digital Camera
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
