Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
Wurlitzer 1015 jukebox
The record rises and momentarely plays but only a second after it turns back as if it has ended and arm rests normal putting the system in idle.
  • erdalkilic Apr 05, 2008
    actually my jukebox possibly is a 1946 and holds 24 vinyls. The arm is in position. vinyl lifts up turns arm sits on correct position sound is heard but stops elevator comes back vinyl returns to position and system stops. the whole thing stops within few seconds. can you help
    Yes actually my jukebox possibly is a 1946 and holds 24 vinyls. The arm is in position. vinyl lifts up turns, arm sits on correct position sound is heard but stops. elevator comes back vinyl returns to position and system stops. It stops like it would after finishing a normal play cycle. So I do not think it is the cartridge. the whole thing stops within few seconds. can you help
  • 871 Answers
Wow. a jukebox.
ok, the record rises and plays BUT it doesnt finish the song and the arm rests but doesnt go back to its place thus making the system idle...
am i right?
ok, seems like the needle is the one at fault...
to replace the needle only means that you have to replace the whole cartridge as well It's a simple pull-out / push-in fit.
here is a link for the needles. link
here is for the cartridge link
as the way you described it, apparent solution would be to chagne the cartridge.
thanks for using fixya.
Posted on Apr 05, 2008
  • earl norman llanera
    earl norman llanera Apr 05, 2008
    ok, so may i ask how old is the cartrige for your jukebox? i recommend that you replace the cartridge even if you think that the cartridge is not at fault.
    lets assume that the cartridge indeed is not at fault,
    here is a pdf manual link see in 18.7....this is the answer to your question.
    records not played completely ...
    tone arm lifts up to early ...
    solution = re- adjust the tone arm trip switch k3. remove adjusting screw to have play time extended.
  • 19,396 Answers
It is the arm sensor for the end of the disk.
  • 2 more comments
  • Ginko
    Ginko Apr 05, 2008
    It is a mechnaic sensor. You to take apart the Wurlitzer nad check the arm mechanics. there should be a sensor to detect when the head get to the end of the disk. This is probably stuck , os some mechanic may have broken. You need to check it out.
    Regards
  • Ginko
    Ginko Apr 05, 2008
    Oops, I posted the solution for older vinyle Wurlitzer.
    On the new cd oner, the solution is usually much simpler.
    First disconnect your Wurl from power cable, and plug it back, to reset the machine, just in case it is a matter of settings.
    If you still have the problem on startup, it is likely that you have a lens problem.
    When you get a dirty lens the cd stops before playing the whole songs.
    Try first putting a cleaner cd into the juke box and using cleaner solution. If this is not enough you will need to take apart the Wurlitzer, so to access to laser lens and clean the lens manually using cotton, cleaning solution, and isopropil alcohol. Ensure the Wurlitzer is disconnected from power if you have to service it inside.
    Regards
  • Ginko
    Ginko Apr 05, 2008
    Well, manual says: locate the arm switch, and unscrew the adjusting screw. I did not find k3 on diagrams, on older model was a mechanic located at the base of the arm.
  • Joseph Omen
    Joseph Omen Mar 08, 2013
    I have the older model 1015and do not have the adusting screw. The only thing that I see is a felt washer at the base of the arm.My problem is it does not drop at the begining of the record.I tried to loosen the screw under the washer and push up against the washer and now the arm goes in anywere from 1/4" to a 1/2 " from the startof th record. Please help Joe
I have a Wurlitzer one more time. vinyl record jukebox.. I moved ( or turned) the turn arm forward to clean behind it and now the records will start to play and return to the changer. How do I adjust it.
Look up underneath the mechanism. You've moved the tone arm with respect to the bracket beneath it (which closes the trip switch). Select a record...turn the machine off...then look up under whilst someone moves the tone arm and you will see what it is attched to. If you are lucky you can hold that tight and gently move the arm back the other way a bit.
Jul 28, 2011 | Wurlitzer Jukebox 1015 One More Time...
45 (record) Jukebox. While playing the jukebox was changing records, the arm lifted the record slightly off the turntable. the credits and song selection would not clear off the readout, even after...
Have you checked all the fuses or circuit breakers on the jukebox?
Are all the power supply led's lit?
Make sure that all the connection plugs into the boards are fully seated and making good connections.
After checking the above if the fault remains you will need to contact a Wurlitzer service engineer.
Regards
Alan Hood
ami-man
UK
May 23, 2011 | Wurlitzer Jukebox 1015 One More Time...
Need manual for Wurlitzer jukebox 1015 45 records.selection will not play records when I press keypad. Thanks
I suggest that you check out the Victory Glass wedbsite for a manual.
www.victoryglass.com
Regards
Alan Hood
ami-man
UK
May 08, 2010 | Wurlitzer Jukebox 1015 One More Time...
Seeburg jukebox sx 100 scans twice and returns
I suggest that you go to the following site for a solution to your problem.
The information listed hereis second to none.
http://home.pacbell.net/fmillera/
Regards
Alan Hood
ami-man
UK
Oct 13, 2009 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 3600 series wont select a record ?
If the buttons don't latch in, the machine is not in credit. Put on free play or put some money in.
Dave F.
May 30, 2009 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 1800 jukebox, plays record but at end the arm does not lift so record does not reject until I press the reset button and then it works.
If the normal cancel button is working then take a look at the tone arm trip switch, which probably just needs adjusting. You can test this by flicking it with your finger when a record is playing. If it works it just needs adjusting to trip at the right place on the record.
The trip switch is located behind the fat end of the cobra tone arm on the back side of the arch, so you get to it by taking the machine back door off.
Dave F.
Nov 29, 2008 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 2500 jukebox
You don't give enough information. Is it in the play position? Is it putting the tone arm down on the record?
Mar 26, 2008 | Wurlitzer Jukebox 1015 One More Time...
Record won't retract
If it isn't making any move to retract the tray it's probably the trip switch. If you look in the back and follow the mechanics under the tone arm you'll see how it closes a switch as the arm goes to the centre of the record. Clean the switch or adjust it.
If it is half returning the tray it is the tray stack all gummed up. Use Servisol Silicon spray or have it rebuilt by someone who knows how.
Dec 06, 2007 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
250 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
