No light(green) assuming power failure to WD unit from transformer
Pin damage, now sorted thanks
Posted on Apr 06, 2008
Replace fuse power cord board blown
hi, there seems to be dead short somewhere i'd unplug all the leads from the power board and plug one in at time, then power up the set to see which board is blowing the power supply hope it helps
regards
shaun
Feb 01, 2014 | Mitsubishi WD-65737 Home Theater
No power output or display.green standby light flashes.
Sounds like either a blown mainpower fuse or the thermal fuse for the power transformer. If the protect circuit was kicking in, the display would light up, but then turn off with a red blinking light. the green light with no display means the transformer is not getting power.
Dec 31, 2013 | Denon Avr-1610: 5.1 Ch A/V Home Theater...
Green light keep blinking but not stay still on so tv can not be turn on.
This is called the blinking light of death in these sets---when power is removed from set and put back the light should blink for about 70 seconds and stop----it is the digital signal unit booting up.
About the only common easy failure for this is there are 4 caps on the power supply board that fail---they will be puffed up on top like photo attached.
Nov 06, 2012 | Mitsubishi WD-73735 Television
Misubishi wd-52631 DLP TV, it shuts off suddeny. when turn it on again, the green power light is flashing, then steady green, then shut off again. the lamp light is NOT falshing or red. the status light...
Hi, have you replaced the lamp after 2-3 yrs of usage? The lamps used by mitsubishi tend to last around 4000 hrs 1-3 yrs.It is common for the green light to light up.Other common failures are the ballast which is the board that powers the lamp.Also check if its not overheatin, dust out the fans.Heres where u can get the lamp or ballast http://www.discount-merchant.com/SearchResults.asp?Search=wd-52631
Apr 19, 2011 | Mitsubishi WD-52631 52" Projection HDTV
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Hello! I have a Malibu transformer for my outdoor lighting. Last night, we had a severe rain storm. During the storm, my outdoor lighting went out. When I went to check the transformer box this...
My malibu transformer has a reset button on the back near the terminal connections. If the transformer is on (time displays on the panel) but the light fixtures are not lit, look for the reset button on the back and depress it.
Oct 07, 2010 | Malibu Hardware & Accessories
Green light on 1950W monitor flashing green and no picture
I assume you already try it on another PC.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 28, 2010 | Computers & Internet
WD ELEMENT DOESNT POWER UP. GREEN AND BLUE LIGHT FLASHES
Have you contacted WDE.. by email,or, phone? Seems like that the hard drive has had its bios info corrupted , due to possibly hooking it up to the pc(in the wrong order), or even, a power surge that you were not aware of... The Manufacturer can send you a link to upgrade/restore the harddrive bios...
Sep 01, 2009 | Western Digital Elements powered by WD 320...
No power to my WD elements 1 tb
Same thing here. What about the data. Could you recover it ?
Jun 09, 2009 | Western Digital Elements powered by WD 320...
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
