Question about Buffalo Technology AirStation WBR2-G54S (747464109220) Router
Buffalo Airstation G54 wireless is not working
Hi, The buffalo Airstation G54 wireless is not working. When connecting to the ethernet port the laptop works. With wireless it does not go to internet. Looks to me the wireless is not working.
Please assist how to diagnose.
Bush
  • 1 more comment
  • KimmiIL Apr 18, 2008
    exact same problem with mine this week. Now, the internet connect wants an 8 or 12 digit password. I never set any passwords.
  • sudhakk May 30, 2008
    Facing the same problem. Any suggestion from anyone please....
  • alifraz Oct 06, 2008
    exactly the same thing with mine either Ethernet works or wireless
    New Friend:
  • 11 Answers
Agreed, Netgear is the Shism!
Posted on Oct 07, 2012
  • 4 Answers
Connect your computer straight to your internet modem.
If it works then connect the router after reset....
read the manual..if it does not work then return your router and get a new one or simply buy netgear..has been working for me Without problems for 4 years other than two years ago got fried due to electrical over charge
Posted on Feb 07, 2009
6ya staff
SOURCE:
I have this router but i want to know hoe to secure my internet connection
By default, the firewall on it should block all incoming connections from the WAN or internet network port (good thing). Make sure you do two things : 1. Change the default password on the router, and 2. secure your wireless using WPA2 for authentication and AES or TKIP for encryption. Also, rename your SSID to something that doesn't give away that fact that your router is a buffalo. I'm paranoid, so I donot broadcast my SSID...if you are too, then this is a good option.
Oct 22, 2013 | Buffalo Technology AirStation G54...
I have the Buffalo WHR-G125 model, i have had it for around 2 years & for the past week i have to spend ages trying to connect my laptop to it, i have switched the plug off sometimes to reboot, i have...
I have seen a similar issue several time created by the cordless phone.
If you have your router too close to your cordless phone, you may have radio interference since both are working on a close bandwidth.
Please move one of the 2 away and tell me if you see any improvement.
regards
Mar 18, 2011 | Buffalo Technology AirStation G54...
I have to disconnect and reconnect my Buffalo Router each time I want to use a different system. How do I fix this problem so I don't have to do this anymore?
I think you need to reset your modem and start anew. I am going to send you to another forum to learn about your WHR-Hp_G54
See: http://www.techsupportforum.com/forums/f136/buffalo-whr-hp-g54-227877.html
Jan 08, 2011 | Buffalo Technology AirStation G54...
I've had a new laptop but require my security key, model WBMR-G54 to access the security enabled network, from my old laptop.
If you've forgotten the wireless security key you entered when you set up the router you can reset it by connecting to the router directly with an ethernet cable instead of the wi-fi. Plug a cable into the router and then laptop and access the setup page for the router. See the manual (or download one from the buffalo site) for setup instructions.
Dec 27, 2010 | Buffalo Technology Buffalo AirStation...
I have lost my Network Ket to my AirStation 54G. Is the only way to change it to Reset the ROuter ?
To get the network key of your wireless network, you will need to access the rotuerset up.
Is there any computer conencted to the router with the cable ?
If not then is there any computer online through the same router wirelessly ?
You can open the set up page on the working computer.
If you do not have any other computer online then you will need to connect the computer to the router with the cable.
Click Here for more info about how to find the network key
Nov 19, 2009 | Buffalo Technology AirStation G54...
Client Manager will not pick up my buffalo wireless card.
You can find the driver in the Buffalo download archive for older products:
http://site2.buffalotech.com/support/downloads2.php
Choose from the menu.
You also find manuals and set-up guides there.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Jul 31, 2009 | Buffalo Technology Buffalo AirStation...
Device password requested on 1 or 4 laptops, 1 laptop can wiifii and no wiifii on the others
u set up ur buffalo airstation on the 1st laptop tat is working fine,,and at tat time u secured ur wireless network.so tat no one can else can connect to it..specially ur neighbours..u have to use tat password on the new computer.and tat will do it
May 09, 2009 | Buffalo Technology Buffalo AirStation...
Trying to connect buffalo router to comcast modem for wireless internet
You will need to use the MAC address of your PC. Do an IPConfig/all while connected with a ethernet cable. That's whatg you need to put in under Wan--> WAN MAC address
Jan 17, 2009 | Buffalo Technology AirStation G54...
Problem with my buffalo airstation G54 WHR-HP-G54
  1. After unpacking your Buffalo wireless router, connect the ethernet cable from your jack to the rightmost ethernet port on the back of the router. This is the blue WAN port labeled "Internet". Next, use another ethernet cable to connect your computer to the router, using any of the 4 remaining open ethernet ports on the back. Finally, plug the AC adapter into the power port on the router and plug it into the wall.
  2. Once the router has been plugged into the network and powered on, the power light will come on and the other status lights on the front will go through a series of flashes. Once the leftmost diagnostic light labeled "Diag" has gone off and the light labeled "Router" has come on, this means your router has been initialized and is connected to the network.
  3. Now open a web browser window and enter 192.168.11.1 in the URL field and press enter. You will get a prompt to enter a username and password to access your router settings. You should enter "root" (without quotes) as the username and leave the password field blank, then click OK. You are now taken to a page where you can configure your Buffalo wireless router.
  4. Click on the Admin Config button on the top right of this page. Enter a name for your AirStation and click Apply. Wait for the router to restart with the new setting, you may have to refresh your browser window.
  5. Next click on the Password button in the small row of choices under Admin Config. The Administrator name is fixed as "root" however, you should now choose an Administrator Password (8 characters or less) and enter it in the two fields provided, then click Apply. Wait for the router to restart, and you will be prompted to login with the username "root" and the new password you just set up. If you choose a password over 8 characters long, you will be unable to login and will have to reset your wireless router by using the pinhole on the bottom.
  6. Next click on the Wireless Config button on the top, third from left. In the small row of choices under Wireless Config, click Basic(11g). Make sure the box labeled Enable next to the Wireless Radio setting is checked. For the SSID setting, switch to the second choice Use: and then choose a name for your wireless network. You should write this name down and keep it near your wireless router in case you forget it. Click Apply.
  7. Next click on the Security(11g) choice under Wireless Config along the top of the page. For the Wireless Authentication setting, select WPA/WPA2 mixedmode - PSK. For the WPA-PSK (Pre-Shared Key) field, choose a password that is between 8 and 63 characters (letters and numbers only) and enter it here. Click Apply. buffalo04.jpg
  8. Your Buffalo wireless router will restart and is now configured to connect securely to the Internet.
Jun 23, 2008 | Buffalo Technology AirStation G54...
Open Questions:
Amazon PrImE rEfUnD PhOnE [+1]845[481]1722 nUmber vviss AMAZON PRIME Tech Support Number +1-845-481-I722 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``845`-481`-I722``] UsA Amazon Prime Technical SuPpOrT Number +1-845-481-I722 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. Facebook is an internet social media and networking website and with Facebook, you'll be able to share something like permitting registered users to create profiles, upload photos and videos, send messages and keep in contact with friends, family, and colleagues. To find out new things and knowledge completely different places beauty we tend to arrange our tour at reasonable costs. Then you'll watch United Airlines, here all of your needs are fulfilled at a minimum rate. Alaska Airlines could be a major USA airline headquartered in SeaTac, Washington, inside the urban center metropolitan space of the state of Washington. it's the fifth largest airline within the u. s. once measured by fleet size, scheduled passengers carried, and variety of destinations served. Walmart is committed to providing you superior customer service and a nice searching expertise. We're happy to retort to your questions about Walmart com connected queries. The best Walmart phone number with a tools for skipping the wait on hold. The customer can Call Walmart com customer service faster by CSPN. Contact Customer Service team to provide a comment or ask a question according to your problems. This is Amazon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Amazon agent. This phone number is Amazon's Best Phone Number because 1,820,712 customers like you used this contact information over the last 18 months and gave us feedback. Common problems addressed by the customer care unit that answers calls to +1-845-481-I722 include Return an Order, Missing Delivery, Refund an Order, Dispute a Charge, Can't Login and other customer service issues. The Amazon call center that you call into has employees from Arizona, Washington, North Carolina, India and is open 24 hours, 7 days according to customers. In total, Amazon has 1 phone number. It's not always clear what is the best way to talk to Amazon representatives, so we started compiling this information built from suggestions from the customer community. Please keep sharing your experiences so we can continue to improve this free resource.
Oct 23, 2019 | Facebook Computers & Internet
AMazon PrImE rEfUnD nUmBeR {1=845={481}{1722}#[email protected] OREGON AMAZON PRIME Tech Support Number +1-845-481-I722 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``845`-481`-I722``] UsA Amazon Prime Technical SuPpOrT Number +1-845-481-I722 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. Facebook is an internet social media and networking website and with Facebook, you'll be able to share something like permitting registered users to create profiles, upload photos and videos, send messages and keep in contact with friends, family, and colleagues. To find out new things and knowledge completely different places beauty we tend to arrange our tour at reasonable costs. Then you'll watch United Airlines, here all of your needs are fulfilled at a minimum rate. Alaska Airlines could be a major USA airline headquartered in SeaTac, Washington, inside the urban center metropolitan space of the state of Washington. it's the fifth largest airline within the u. s. once measured by fleet size, scheduled passengers carried, and variety of destinations served. Walmart is committed to providing you superior customer service and a nice searching expertise. We're happy to retort to your questions about Walmart com connected queries. The best Walmart phone number with a tools for skipping the wait on hold. The customer can Call Walmart com customer service faster by CSPN. Contact Customer Service team to provide a comment or ask a question according to your problems. This is Amazon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Amazon agent. This phone number is Amazon's Best Phone Number because 1,820,712 customers like you used this contact information over the last 18 months and gave us feedback. Common problems addressed by the customer care unit that answers calls to +1-845-481-I722 include Return an Order, Missing Delivery, Refund an Order, Dispute a Charge, Can't Login and other customer service issues. The Amazon call center that you call into has employees from Arizona, Washington, North Carolina, India and is open 24 hours, 7 days according to customers. In total, Amazon has 1 phone number. It's not always clear what is the best way to talk to Amazon representatives, so we started compiling this information built from suggestions from the customer community. Please keep sharing your experiences so we can continue to improve this free resource.
See all Buffalo Technology AirStation WBR2-G54S Questions
Buffalo Technology AirStation WBR2-G54S (747464109220) Router Logo
728 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Ekse
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
