Question about Nokia 6233 Cellular Phone
Nokia Bluetooth. Passcodes
I have recently given my daughter my old phone but I am unable to activate bluetooth. When trying to pair her phone with mine it says 'Enter Passcode' none of us knows the passcode and have tried everything we can think of. Other search sites have not helped as the numbers they suggest do not work. Any advice welcome please!
    President:
  • 1,017 Answers
You can put anything sutch as 0000, as long as you both enter the same code.
Posted on Apr 05, 2008
6ya staff
SOURCE:
How to pair it with galaxy tab 4
This is for the 1900, but should be the same. Go to Bluetooth settings on your Galaxy.
Samsung HM 1900 User Manual
Aha, I found this for the 1500
4 Enter the Bluetooth PIN (0000, 4 zeros) to pair and connect the headset to your phone. Your headset supports the Simple Pairing feature which allows the headset to be paired with a phone without requesting a PIN. This feature is available for phones that are compliant with Bluetooth version 2. The headset also can be paired via the Active pairing feature, see page 14. Connecting with two Bluetooth phones
With the Multi-point feature activated, your headset can be connected with two Bluetooth phones at the same time. 1 After connecting with the first Bluetooth phone, press and hold the Talk button until the blue indicator light stays lit. 2 Press and hold the Volume up button to activate the Multi-point feature. 3 Activate the Bluetooth feature on the second Bluetooth phone and search for the headset (see your phone???s user manual). 12
4 Select the headset (HM1500) from the list of devices found by the second Bluetooth phone. 5 Enter the Bluetooth PIN (0000, 4 zeros) to connect the headset to the phone. ??¢??¢ You can set the headset automatically to reconnect to the recently connected phones each time you turn it on. -- To reconnect to the two most recently connected phones, activate the Multi-point feature. Press and hold the Volume up button in Pairing mode until the blue indicator light flashes twice. -- To reconnect to only the most recently connected phone, deactivate the Multi-point feature. Press and hold the Volume down button in Pairing mode until the red indicator light flashes twice. ??¢??¢ When the headset connects to two Bluetooth phones, some phones may not connect to the headset as the second Bluetooth phone. English
Disconnecting the headset
To disconnect the headset from your phone, ??¢??¢ Turn off the headset. 13
Reconnecting the headset
When the headset is paired with a phone, it will attempt to automatically reconnect each time you turn it on. If the headset does not automatically attempt to reconnect, ??¢??¢ Press the Talk button. Pairing via the Active pairing feature
With the Active pairing feature, your headset can automatically search for a Bluetooth phone and try to make a connection with it. 14
3 Press and hold the Talk button until the violet indicator light turns on. The headset will switch to Active Pairing mode, search a Bluetooth phone within range, and attempt to pair with it. [. . . ] ??¢??¢ To switch between the current call and the held call, press and hold the Talk button. 19
http://lastmanuals.com/manual/SAMSUNG/AURICULAR-MONO-BLUETOOTH-HM1500
Oct 30, 2015 | Samsung HM1500 Bluetooth Headset
I am trying to pair Nokia E63 with Bluetooth Headset BH-213 but my Nokia E63 is not able to search Bluetooth Headset device. I have already turned on Bluetooth of both devices. Please guide me.
Please follow the proper instructions given below to successfully pair your Nokia E63 with the Nokia BH-213 Bluetooth Headset.
1.Ensure that your phone is ON and headset is OFF.
2.Press and hold the multifunction key (for about 5 seconds) until the green indicator light starts to flash quickly.
3.Activate the Bluetooth feature on your phone, and set it to search for Bluetooth devices.
4.Select the headset from the list of found devices.
5.Enter the passcode 0000 to pair and connect the headset to your phone.In some phones,you may need to make the connection separately after pairing.
6.When the headset is connected to your phone and is ready for use,the green indicator light flashes slowly.
However if you are having problem with the Bluetooth connectivity of your phone the most probable cause may be a malware attack.It can be solved by cleaning your phone memory by entering *#7370# on your phone and restoring the default settings when prompted.Make sure you back up your contacts to the memory card or copy it to the SIM directory.
Hope you are satisfied with my solution.Thanks for choosing Fixya.
Jun 24, 2011 | Nokia Bluetooth-Headset BH-213 2600...
My nokia 7610 says unable to perform bluetooth operation
When you get an error "unable to perform Bluetooth operation", it means that one of the Bluetooth devices is not communicating correctly. It could be your phone, or it could be the Bluetooth device that you are trying to connect to. And that will depend on the device that you're connecting.
There's a possibility that the Bluetooth requirement of your device is not supported by your Nokia phone. Example, you are trying to pair up a Bluetooth handsfree car kit. "IF" the phone does not support the handsfree profile, then you will get this error message.
So, you need to make sure that your device and your phone is compatible with each other. Second, try to pair up the phone into different Bluetooth devices, like phones, headset, etc. Doing this will let you know if the Bluetooth on your phone is working or not. If it works with another Bluetooth devices, then the problem has something to do with the device that you are trying to connect to.
Thank you and good luck!
Jul 31, 2010 | Nokia 7610
My sony bluetooth is paired with an old phone and i want to unpair it and use it with my new phone
Just turn off the bluetooth connectivity of your old device and for your new device just turn it on and look for new paired device, make it sure that both bluetooth connectivity are activated
Oct 31, 2009 | Nokia N76 Cellular Phone
Unable to pair with PC via Bluetooth
beter to uninstall the pc suite and reinstall it.
May 10, 2009 | Nokia N72 Cellular Phone
No bluetooth connection
Hi
Please check the Bluetooth settings! make sure you paired the device to other device
Thanks!
Dec 30, 2008 | Samsung SGH-a737 Cellular Phone
Connectivy
check the visibilty??
Aug 25, 2008 | Nokia 6126 Cellular Phone
Bluetooth passcodes
"C program run. C program crash. C programmer quit"
Apr 05, 2008 | Nokia 6233 Cellular Phone
Nokia 6233 Cellular Phone Logo
89 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
ASHRAF CA
ASHRAF CA
