Question about Sony FD Trinitron WEGA KV-36FS120 36" TV
David 93 - continued
Hi it is me again. My model number is KV-32HS500. Also i have counted the number of blinks in a row from that standby light and it is 7 blinks. Please tell me what is wrong and how to fix it.
  • 4,234 Answers
THe 7 blinks indicate a problem in the high voltage section. The most common failure part is the horizontal output transistor. This is a 3-legged part attached to a heatsink close by the flyback transformer (part with large red wire coming out the top). Try replacing this part first. That may resolve the problem. The part should be marked something like C5438. This wouldmean that the actual part number is 2SC5438. Please note that this number is only an example. Let me know if that does not resolve the problem.
Dan
Posted on Apr 05, 2008
SOURCE:
SONY TV KV-BT21M80 TV going stndby again & again.please give me solution.
When the TV goes to standby state, do the standby light blinks. If it does, count these number of blinks at one time switch on. These are fault indications. From these number of blinks, you can get an idea about the faulty section circuit inside. If it blinks, count it. If you wish to get more details, about the blinking codes to Sony TVs, check this link.
Feb 28, 2013 | Televison & Video
Won't turn on. relay clicks & standby light blinks.
Hello
Blinking of standby light on Sony TVs are fault symptoms. You just count the number of blinks exactly and keely, for switiching the tv with its FRONT PANEL POWER ON-OFF SWITCH; and not by the remote control hanset. Do it for atleast three times, and confirm the number of blinks, and inform me through Fixya. OK.
Dec 01, 2010 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Little red light on front flashes and no picture. Help! Thanks...
The standby light should be blinking in a repeated pattern. Pleawe count the blinks and report that number here. That count indicates the circuit that is having a problem. Also, please confirm that the set is model number KV-32FS100.
Thanks,
Dan
Nov 19, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Push on button and it acts like it going to come on but then switches itself off.
If you r set is a Sony, then the standby light should be blinking a repeated pattern of blinks. Count them and post the count here along with the model number. That count will indicate the problem circuit and thus the solution to your problem.
Thanks,
Dan
Oct 23, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sometimes tv won't turn on and standby light blinks and sometimes it works perfect
The key here is the number of blinks of the standby light. This is an internal diagnostic code. Please provvide that count and I should be able to suggest possible fixes.
Thanks,
Dan
Apr 26, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony Trinitron 2002 model # KV-32HS500
Mine never blinked 7 times but 6, 5, 4 times Yes
Sep 17, 2008 | Televison & Video
Standby mode and can't get tv to work
This sounds like the set is in protective shutdown. A problem has been detected and the set shut down. Normally when this happens, the standby light will blink a code count. Can you count the blinks and post that number here? That will indicate the circuit in which the problem was detected. Also, please confirm that the model number of the set is: KV-36HS500 as the blink codes are different based upon model.
Thanks,
Dan
Aug 19, 2008 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Help
That would depend upon the number of blinks and the specific model number. I am guessing that the model number is KV-32FS100. What is the blink count?
Dan
Jul 24, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony KV 32HS500
what is the blinking pattern? blink pause blink
Jan 14, 2008 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
32 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
