I have no sound and yet my speakers are pluged in and turned on i think i may have done somthing to my sound card
  • 655 Answers
First you should check whether the driver for your sound card is installed properly or not. to verify follow the following steps:
  • Goto control panel and double click on System.
  • Then Click on Hardware and then Device Manager.
It will open the device manager window. See this window carefully, if there is any component with Yello mark then you have to re-install the driver for sound-card.
If you don't have any component with yellow mark then everything is ok you have just check out your Mixer Volume etc.
If any question just Ask me.
thanks
Iqbal
Posted on Apr 05, 2008
I can not hear sound what problem of this?
Several things must be in place to hear sounds on your pc.
You must have speakers - the kind you not only plug into your pc but you must also plug them into your wall to have a louder sound. OR --- you can use head phones. The headphones plug into your pc sound card.
You must have a sound card or onboard sound
You must have a sound card DRIVER.
These three things and some reading will get you going
Best of it
Rice @ Fix Ya
Dec 14, 2010 | Computers & Internet
No audio device installed for the output speakers i have a toshiba saterlite laptop model no a215-s4757 my headphones work when pluged in thanks,i think its the sound card
For vista use the following driver and install it
http://cdgenp01.csd.toshiba.com/content/support/downloads/driver_audio_realtek_26518A.exe
For windows 7
http://cdgenp01.csd.toshiba.com/content/support/downloads/driver_audio_realtek_TC40068800A.exe
Nov 28, 2009 | Toshiba (4CH-VOUT) Sound Card
No sound conning out of speakers from wharfdale mixer
Speakers are working OK otherwise?
Do you get sound from headphone jack?
It's probably some pot control not turned up.
Is MAIN OUT turned up
Are speakers connected to monitor out or main out.?
Is gain for mic turned up?
Is there a MAIN OUT switch (on/off)?
Is there a MUTE control on the board?
Aug 05, 2009 | Wharfedale Force One Main / Stereo Speaker
Hey, i dont know what sound card i have, theres somthing wrong though.. plz help
assume "something wrong" means "there's no sound" coming out of the speakers. A few things to check first:
1) Make sure your cable to your speakers is plugged in, and plugged into the right jack. It should be the green one on the back of your PC.
2) Click on the "speaker" icon down on your task bar (right-hand side), and that will open up your sound settings. Make sure it isn't a) muted, or b) turned way down low.
3) If you have powered speakers (plugged into the wall), make sure they are getting power to them.
After you've done all that, figure out what model computer you have, and based on that I can probably tell what kind of sound card you have (most these days are built onto the motherboard).
Cheers
Nick
Nov 15, 2008 | Computers & Internet
Speakers
'Buzzing' is not a good thing; it implies that filtration of the DC used by the output section is not as it should be. Power supplies that are mildly overloaded can cause this or an abnormal current drain from one (or more) channels.
The odd problem with the back speakers does sound like a setup problem rather than a circuit failure.
Oct 31, 2008 | Onkyo TX-DS989 Receiver
Sound card for acer aspire 5315-2153
Go to your speaker icon on the desktop, double click it to bring up the mixer. Your Mic is muted by default. Just take the tick out of the box and you should be away.
If your running Vista, then goto Start-Settings-Control Panel-Sound
You should find the settings box for your microhone there. If not, then do the same procedure as for XP, but only click the speaker icon once and select mixer.
Hope that helps =)
Apr 14, 2008 | Acer Aspire 3000 Notebook
No sound from left rear surround speaker
i think it would probably be somthing inside the channel???
Jan 01, 2008 | Aiwa NSX-DS55 CD Shelf System
The speakers
I am asuming these are usb speakers then I would check my usb port to make sure its ok try pluging in somthing dif that is usb if you have not already tryed this
Dec 02, 2007 | Altec Lansing ATP 3W Computer Speakers
Sound
Check you sound card.
Make sure speakers are pluged inproperly.
Turn up volumn.
Nov 28, 2007 | Audio Players & Recorders
Problem about sound
i am using same configuration with 5.1 creative speaker with good sound. in 5.1 sound system there are 2 seperate jack for left and right speaker. you attach one adopter having 2 in and 1 out point.The jack is 'Y' shaped. that will solve ur problem.
Nov 25, 2007 | Intel D915GAV Motherboard
Computers & Internet Logo
David Payne
David Payne
