Question about ASUS P4S800-MX Motherboard
Computer not booting
My computer was on for about 48 hours working normally,i turned off after working and then later on turned on it went to normal start up screen with all the icon shown on screen and then turned off itself.
i turned back on and it turned off again.i tried next day and it turned on normally and and turned off again after 2 minutes.
i started again and by pressing appropriate key went to bios set up to see any problem and i saw on bios screen, line saying hardware problem.
i opened the case and noticed cpu fan fixed on top of heat sink was loose, it seems heat sink was loose too.I fixed the clip back and turned computer back on and it did not turn on (monitor screen black, light on monitor amber) nothing happen, no beep, cpu fan was working, i felt the bottom part of ram stick was hot.(clip was loose).
And i noticed that two very thin cables coming from front side of the case one with tag 'cpu' and other 'vga' were connected to motherboard's SiS 661 FX north bridge were out as well.there is on-board integrated video and audio and there is no pci and agp card installed.
computer specs are
windows xp professional service pack 2
asus P4S800-MX mother board
Intel pentium 4 processor
512 mb ram (one stick)
form factor Micro ATX
On Board Graphic Processor
SiS 661FX
please help to get me back on track.
thanks for your very busy time.
  • Anonymous Apr 23, 2008
    je veux avoir le driver multimedia audio controller et l'internet controller pour mon pc ibm thinkpad r51 de type 2887
  • 1,027 Answers
Unfortunately it sounds like the processor fried. These are very prone to heat degradation.
Link to computer gate
Link 2 is to
Link 3 Take your pick
Your board supports Northwood/Williamette processors with HT
in 400/533/800 Front Side Bus
Posted on Apr 05, 2008
When I booted up my PC 4 days ago, my Symcmaster 193P monitor started immediately blinking continuously and very fast; it did so on the POST screen and went on after booting in Windows too. It stopped and...
Yes i do agree with you there is no problem with a graphic card,and i suspected it to be a problem with the cable which is used for connecting but it was fine when you swapped the monitors however i would still suspect on the slot where the cable is connected,may be you should try samsung service center before you decide.
Post back for more solutions we will be happy to help you.
Hope this helps.
Jan 09, 2011 | Samsung SyncMaster 193P 19" LCD Monitor
I fully charge the phone but within 48 hours,even without using it, have to charge it again
Don't panic this is quite normal.
Even when you are not using the phone it is still on and actively connected to your service network. Therefore using battery power.
Actually to get 48 hours from your handset is very good.
Normally you would have to re-charge the 81xx series at least every 24 hours.
I was charging mine every 12-14 hours.
Jul 27, 2010 | RIM BlackBerry Pearl 8100
I can't get my Sansa MP3 player to charge
Hi, 48 hours later , the player has sucked in enough electricity ! Thank you , Linda
Jun 05, 2010 | SanDisk Sansa Fuze MP3 Player
I turned on my Dell Dimension 4700 computer,but the amber light started to blink . I held the start up button for 5 seconds and the light went out. I tried to start it up again and got the same thing,...
Vaughn it sounds like the power supply is going bad, try another known good working power supply. If that doesn't work then the motherboard would need to be replaced. If the power supply isn't giving the correct voltages that could cause the computer not to turn on. If the motheboard isn't able to convert the voltages properly then the motherboard could be faulty.
Dec 23, 2009 | Dell Dimension 4700 PC Desktop
Dell D600 Battery Causes Screen to go Black
Laptop batteries normally just last for a few years, depending on usage. If your battery is almost done, it may report a 'full' status, but just have the capacity to feed your laptop for a few minutes.
You may check this by disconnecting current while your laptop is started up. If low battery capacity is the cause, the same will happen within a few minutes.
Laptops normally go in standby on low battery, to avoid data loss.
May 05, 2009 | Dell Latitude D600 Notebook
Booting problem in acer 4520
*********** board needs to be replaced
Dec 08, 2008 | Computers & Internet
How do you adjust color guns in an rgb projector?
Sep 18, 2008 | Televison & Video
Compaq notebook won't boot up
When you boot the computer back up go into Safe Mode and check to see if you can roll the computer back to the point before you installed the software.
If so this should work. If it works then run a virus scan, a defrag of the hard drive and cleans the temp files.
You can do a diagnostic startup and uninstall Onecare. So once that it is uninstall ed it should be smooth sailing.
Here is a link for some startup / diagnostic software you could try after booting.
I hope this helps
May 19, 2008 | HP Compaq Presario V2000 Notebook
XG-C50 Problem
Replace the fly-eye lens of projector.
Nov 09, 2006 | Sharp (BQCXGC50X1) Projector Lamp for...
ASUS P4S800-MX Motherboard Logo
163 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
