Question about Acer TravelMate 2300 Notebook
Travelmate 4000 disassemble
Hi! A few days ago my graphic card started to have a strange behavior, but only during startup (have some vertical pink lines in half the screen) and when the 3D rendering starts. I've reinstalled all drivers and the problem continued. Then I thought it was overheating problems and, even though I was able to clean in from under it, it wasn't enough :(
Can anyone tell me or send me a manual on how to take the laptop apart? Thanks
P.S. - My e-mail is [email protected]
  • 2 more comments
  • Radu Lykan Apr 05, 2008
    After the drivers installation I had reinstalled Directx9c but that wasn't the problem. I don't have pixels or those lines in the LCD on the desktop or any 2D applications. The problems starts on games or 3D applications, so I'm guessing it's a rendering problem... There is also the possibility of the graphic card memory/chipset being a bit fried but I hope it's "only" and overheating problem.
    About the service manual I already have it, so I was looking for an "instruction manual" on the 1st steps to take, specially on what to do to remove the keyboard and the front
    ok, thanks :) I will try to reinstall all (I have an external 2.5HD so I will transfer that disk to the laptop and try to reinstall all). I will have to wait a week before I can try this cause It happened to me while I am away from home and don't have the CD's with me. I'll put here if it worked or not. Thanks
    I friend o mine has a Aspire 1680 with the same graphic card, so I swap is HD with mine and restarted my laptop. His works well, but I cannot say the same with mine. Whenever the Direct3D is used the graphic card has the same behavior :( Seems my chipset is really defective. Thanks for the help
  • Dlog Jun 23, 2008
    i've got the exact same problem....BUT there is some sort of temporary solution that at least works for me
    [[first of all: if anyone happens to know, how to disassamble this notebook, let me know....i'd really appreciate that]]
    after i'd lived with the lines covering my screen for quite some weeks, i took my notebook to a friend (apart of the lines it just works fine in 2D mode) and happend to see, that each time, the nootbook was moved with a little force, the visible lines rearranged. that means, i've got a loose contact.
    before i tried to disassamble the notebook again, i did a little search and found this forum here, so hopefully, the links presented do me any good. since you've got the same problem, i'll explain, what i did, in order not to get it any worse and in the best case to let the lines on the screen vanish:
    first of all the problem:
    on startup, when you see the big ACER logo, covering the output of the notebooks bios, one will see red lines from top to bottom and from the middle to the right of the screen.
    in the worst case scenario you'll have the same with the windows bootup screen, only in blue and some flickering dots...don't be scared by that, i only call it worst case scenario, because you can let that vanish with a little "trick" i will explain afterwards.
    after that, one will see red lines all over the screen, while on the windows desktop
    so much for the problem. now, lets look at my temporary fix for that:
    first of all, set the color depth of your screen to 16bit....while in 32bit mode, you will have a lot of thin red lines on the screen, in 16bit mode, you will still have lines, but in blue (much better to work with) and they've got kind of the have resolution compared to the red lines.
    now don't hang me up on the red and blue lines. the color of these lines actually changes depending on the color of the window or desktop picture you've got in the "background" behind the lines (for me its blue on a dark background and light orange on bright backgrounds...for instance if you've got a black desktop, you'll see blue lines, if you open an explorer with its white background, you will see orange lines)
    the next step is the installation of the omega drivers (first link in a search for "omega drivers" on google). with these drivers you'll have control over the clock speeds of gpu and gpu memory using the ati tray tools shipped with it.
    after installation, use the tray icon of the ati tray tools, to access the overclocking settings. we don't want your graficcard damaged any more so you should set the clocks of gpu and memory to the lowest value possible befor the screen acts even more funny due to a clock that is set to low. for me core speed: 398.25 and memory speed 168,75 works just fine.
    (you should read about this tool on the internet before trying it out if you don't know what you are doing)
    after applying this any flickering, that is still present, should stop. to look for any flickering, you can use any black window (for instance the command promt window (cmd.exe))
    the final step is to stop any hardware acceleration (somewhere in the graficcard settings, you can access from where you can change the resolution and color depth of the screen....sry, but i use a german windows version, so you'll have to look that up on your own)
    after doing all of these steps you hopefully won't see any lines any more but some kind of a dot matrix (not the optimum but at least much better to work with)
    and now the little trick:
    if you press the right shift-key (press hard but don't break anything), the lines/dots/whatever should vanish.
    if you do this while the notebook is still cold, the screen should present itself like there isn't any damage at all....while the notebook gets warmer, it becomes more likley, that the lines will vanish, while you hold the shift-key but will reappear, if you let go of the pressure (if you are lucky, you'll have a whole day without them or even more)
    i hope, that this helps a bit....i am NOT a professional and i came up with these things on my own, but it works for me at the moment.
    i can work with it and it does't get any worse, so hopefully you can do the same thing and live with it
  • Acer Master
  • 19,396 Answers
Reinstall direct x before disassembling the laptop. If the problem is hardware is likely to be LCD display to be replaced, LCD ribbon cable out of place, or graphic chipset defective.Here is download of part list and explode view for your laptop. You can require service manual or schematics for travelmate 4000 on this forum, or check older posts and see if you can find it.
Regards
Posted on Apr 05, 2008
  • 2 more comments
  • Ginko
    Ginko Apr 05, 2008
    You can hope whatever you like. It is not a CPU overheating problem, as the laptop shut down when youy have such a problem.If the graphic chipset overheats , then is defective. Graphic chipset is not supposed to have a have a fan and there is no room for placing one inside. If you have the problem only when you play videogame then can be just a matter of compatibility with your graphic chipset.
    I suggest you not open the laptop, you can cause further damage if you do not have right knowledge. Thanks for negative rating given.
  • Ginko
    Ginko Apr 05, 2008
    Ps: We all use service manuals to service laptops, they all include enough intruction on how to disassemble them. You will better call an authorized service to solve your problem.
  • Ginko
    Ginko Apr 05, 2008
    If your graphic chipset start displaying weird lines or pixels on screen, always after a while, even when you do not use a game, then there is graphic chipset overheating (this is not quite frequent) If it happens to a laptop it is quite a serious problem, and cleaning will not solve it.as the graphic card is integrated into MB, and there is no way to replace the chipset. In your case it is probably a system problem of some kind. If you have a spare 2.5 hd, you can try to reinstall system on a different hard disk, possibly from recovery disks, and see if you still have the problem.
    Let me know if you hve more queries.
  • Ginko
    Ginko Apr 05, 2008
    Last thing , what I sent you is not the service manual, it is part list and exploded view. I do not have service manual forTravelmate 4000 in digital format. I will Try posting a request in the forum.I uploaded here service manual for travelmate 7300, some detail in assembling are different. If you decide to take the laptop apart be very careful with keyboard and mousepad ribbon cables when you remove the keyboard.
SOURCE:
Vertical lines on monitor, normally pink
I have had that very same problem before. Unfortunatly it is all bad news. The card is going bad. You will have to replace the card. I wish there was something else I could tell you, but I know with 100% certanty that the card isnt any good. And the reason your other graphics card may not work is due to you not either uninstalling the 7500 drivers before you swapped, or some of the software affiliated with the 7500 were not completly removed during the uninstall process. Try this program http://www.guru3d.com/category/driversweeper/ to completly remove all dirver files for the 7500.
Feb 20, 2010 | ATI RADEON 7500 (64 MB) PCI Graphic Card
Audio video doesnt play smooth, it's jittery. cpu usage of player goes 40-60%. windows xp prof service pack 3. all acer travelmate audio video drivers. acer travelmate 4000 notebook
Does this happen only when viewing online audio/video, as opposed to inserting a music-CD into your CD-drive, and using Windows Media Player to play the music?
If so, then how fast is your Internet connection?
It probably is too slow to download and play at the same time.
So, when you click on a YouTube video, click "pause",
and let the download proceed for a minute or two,
and then click "play", to play what has been downloaded.
Nov 17, 2009 | Acer (54.AA806.001) Sound Card
Continuous vertical white band display problem
What is the error from installing xp sp3?
Is the white band always there? it is either a problem with the lcd panel most likely, or the graphics card. try a different monitor if you have one.
Jun 21, 2009 | Dell Dimension 9100 PC Desktop
SCREEN FLASHES, PINK STRIPES , SOMETIMES BLANKS TO BLACK THEN ON
This issue could be either the Monitor inverter failing or it could be your Video card. If you have another computer available, plug the monitor into a different computer and see if you get the same behavior, if you do, then the monitor is failing and needs to be replaced. If on a different computer it works fine, then you may have a video card failing. Does it seem to happen the longer the monitor is on? Could be as it heats up, it starts to fail.
Mar 03, 2009 | Dell E153FP 15" LCD Monitor
Acer Travelmate LCD screen went dark
The same thing happened on my HP. I ended up buying a LCD screen off ebay. That corrected the problem. New screens cost $150+. You can get one off ebay for half the price.
Jan 16, 2009 | Acer TravelMate 270XV Notebook
Computer startup and running issues
Hello:
Try to remove the graphic card and then clean with soft clothe and then insert it again and test.
if same problem encounter, you need to replace the video card, since your pc is virus free.
considering the monitor, you need also to change the or test the monitor but its 10% that this a cause of the symptoms.
most probably the graphic card got faulty.
may this help,
melnavz
Sep 03, 2008 | Computers & Internet
Icons green tint to them
I'm not sure but I think this model uses an integrated graphics card which would then involve replacing the entire motherboard.
It may be that the screen backlight is getting old - they often age by showing a tint, usually it is pink but I have seen them go greenish.
Try an external monitor connected to the laptop via the VGA d connector. If the picture on the external monitor has a good colour balance then it is probably not a faulty graphics chip, and likely to be the laptop screen.
Mar 16, 2008 | ASUS A6Km Notebook
Acer Travelmate 2410 with display probs
Could be the screen is running with the wrong colour depth and resolution - reset the settings by right clicking on the screen selecting properties and then adjust on the settings tab.
Mar 10, 2008 | Acer TravelMate 2300 Notebook
NX 6800 GT Driver issues
Either your graphics agp slot needs the driver updating or the card itself is faulty, check the agp slot for dust and gently moneuvre the card in the slot to see if the lines appear to change and check that therea are no bent pins in your connecting plug or card.
Nov 17, 2006 | MSI NX6800GT-T2D256E GeForce 6800GT, (256...
Computers & Internet Logo
1,164 people viewed this question
Ekse
Alun Cox
