Question about Optorite (DD1203) DVD±RW Burner
Optorite dd1203 DVD
This thing will not read DVD's. It used to. It will, however, read CD's. Have uninstalled, reinstalled...tried everything I can think of. Any suggestions?
    Novelist:
  • 236 Answers
If you have constantly used the drive for at least a year now, using DVDs, then try using first the lens cleaner. But you sure are starting to experience laser weakness, sooner it wil not read even CDs.
Posted on Apr 08, 2008
  • 871 Answers
Have you tried cleaning it? have you tried upgrading its firmware? have you tried making it a master drive?
Posted on Apr 05, 2008
SOURCE:
Can't read detect disc
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd/dvd is getting enough power test all leads that are attached to the cd including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Nov 27, 2011 | Optorite (TED80Y2) DVD±RW Burner
Sony dvd dru-190a not able to read dvd's but reading cd's. Please help.
It sounds like the laser on your drive is gone. But there are a couple of things you can try first before buying a new one.
Uninstall the driver for it in Device Manager and let windows reinstall it automatically on reboot.
or use DriverEasy to install it > download here .
Uninstall and reinstall whatever burning software you use.
Take a look at this thread. Some of the tips there might apply to you.
http://www.techsupportforum.com/micr...ng-cd-rom.html
The drive I had trouble with back when I posted in July finally died a couple of weeks ago. CD's worked fine, just like you. All my good settings with Auto Run, etc, were still there. So I bought a new drive and I'm back in business.
Jun 11, 2011 | Sony 20x Dvd Rw +And -Dru-190a Burner
Recently installed Optorite CR-RW cw5202, when I check the properties it says there is 0 free and 0 used bytes on the disk, the disk I have in is brand new but still it's not allowing me to burn anything...
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd-rw then plug them back in this should activate the found new hardware wizard or
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Feb 04, 2011 | Optorite (cw5201) CD-RW Burner
Software
If you are looking for cd/dvd creating "Burning" software.
Google "Free burning software"
I currently use CDBurner XP and IMGBURN
Jul 21, 2010 | Optorite (DD1203) DVD±RW Burner
Optorite CW 4002 (drive d) will not read any type of disc. Device manager says it is working properly. Windows XP Home Edition. Drive worked before reformating the hard drive disc C
Your operating system may have missed the driver needed to make the cd run properly. You better re-install or repair your operating system.
Apr 06, 2010 | Optorite (cw5201) CD-RW Burner
My dvd burner wont read or recognize a copyed disk is in drive
My Optorite DD0405 will not burn a DVD+R DL disk? is this because its not supported by the burner? I have Nero 9 and would like to burn 4.8 GB of a file from my desk top to a DVD DL with 8.5 GB space. How can I do this
Thank You
Dec 03, 2008 | Optorite (dd0405) DVD±RW Burner
Optorite dvd rw dd1603 can't write cd
What are you trying to 'burn CD or DVD?
What software are you using?
XP/Vista will only burn CD's
Third party software required for DVD's
Jun 07, 2008 | Optorite (dd0401) DVD±RW Burner
Burning dvd image using Roxio disc copier
burning dvd images using roxio really does wonders. however, when you trying burning it to your physical dvdrom, it fails. this may be due to firmware bugs or needs some fixes. have it updated to the lastest firmware update and regularly clean your vdvroms lens with a cleaning kit.
so how is it now?
Jan 28, 2008 | Optorite (DD1203) DVD±RW Burner
OPTORITE
clean the lens manualy use conton and water
Sep 15, 2007 | Optorite (dd0405) DVD±RW Burner
Optorite DD0401 DVD +/- RW
Right click My computer>Explore, and see if your dvd writer is showing as a DVD RW drive and not a CD Drive, then come back
Nov 14, 2006 | Optorite (dd0401) DVD±RW Burner
Open Questions:
SBCglobal MAil TecH SuPPoRt %%%{1=855=536=5666}#[email protected]@# TOLL FREE This AoL MaiL USA phone number is ranked #2 out of 2 because 7,728 AoL MaiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the AoL MaiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AoL MaiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AoL MaiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact AoL MaiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL MaiL USA Calling AoL MaiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL MaiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL MaiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL MaiL USA's phone numbers against each other. Contacting AoL MaiL USA in General While I********** is AoL MaiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL MaiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL MaiL USA.
Oct 22, 2019 | AOL Computers & Internet
See all Optorite (DD1203) DVD±RW Burner Questions
Optorite (DD1203) DVD±RW Burner Logo
Top Optorite Computers & Internet Experts
Ekse
Marvin
Marvin
Are you an Optorite Computer and Internet Expert? Answer questions, earn points and help others
