Question about IBM ThinkPad R32 2658 Notebook
IRDa on Think Pad R32
My thinkpad r32's IR port covered is opaque (unlike others which are amber and transparent) but when i check the entries in my system an IBM IRDa is installed and is working just fine. It comes to me that my R32 comes with an onboard IRDa but the manufacturer disables it by placing an opaque cover that renders the port unusable. Am I correct? Can I take out the cover to enable it?
    Problem Solver:
  • 5 Answers
You might be able to but just in case go to your local computer store or go to the IBM factory.
Posted on May 28, 2008
SOURCE:
Change os on a think pad r32
Seems you are attempting an upgrade install. Try to do an erase install / Format Install, most probably it will pick up the drivers on its own if not you can search for the drivers on
http://www.driversforfree.com/omn_ofm_omd/ibm/thinkpad/r32/drivers.aspx
Apr 04, 2014 | IBM ThinkPad R32 2658 Notebook
Can I increase the ram in my think pad?
Hello
Memory Upgrade for IBM ThinkPad R32 2658-xxx Laptop, the IBM ThinkPad R32 2658-xxx Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 128 or 256 MB (removable) of Memory. You can upgrade your IBM ThinkPad R32 2658-xxx Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 128 or 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
good luck and do rate the solution if helps.
Dec 22, 2010 | IBM ThinkPad R32 2658 Notebook
Hi i have a R32 think pad.... it cant support my external hard drive.. can i upgrade the hardware.. 1.1 to 2? cant i buy a 4 port usb.. 2.0 and plug that in will it work??
Your laptop has USB 1.1. It won't support anything running 2.0 because of power constrictions. 2,0 has a power line and 1.1 does not. as far as upgrading the hardware, the chipset is not designed for 2.0 so it will run a 4 port 2.0 as 1.1 because there is no provision for power (voltage). Hope this helps.
Mar 17, 2010 | IBM ThinkPad R51 Notebook
What are the risks of Restoring R32 Thinkpad using F11 key? Drivers of CDROM & Modem are being prevented from being loaded by certain programs added later on as a result of which these have stopped...
Dear sir,
If you want to restore the thinkpad you must backup your files from windows drive(usually it is C: Drive) By pressing F11 you can restore the system. i.e windows goes back to default settings or manufacturer settings.(Settings when you purchased laptop) other software you installed after buying is also erased.so before doing restore backup your personal files. i think it solws your confusion.
good luck
fixya customer support
chandrashekhar
Jul 29, 2009 | IBM ThinkPad R32 2658 Notebook
Hello my ibm think pad r32 is when we give the restart comment tham windows going to shatting down but power not going off
The restart command does not power off your R32 but does a soft reboot of the r32, if you want to have a power down and physicaly power off and startup then you need to select shutdown and then turn the R32 back on manually. Cheers.
Jul 22, 2009 | IBM ThinkPad R32 2658 Notebook
I have a Western Digital Passport that works fine
Western Digital Passports work perfectly on USB ports 2.0 that supplies 5v of electricity with a max of 500mA. If your computer was manufactured more than 5 years ago, it may be using the USB 1.1 which is slower than the current.
Jun 14, 2009 | IBM ThinkPad R32 2658 Notebook
Owners manual ibm thinkpad notebook 2568 r32?
Try this link. Its pretty long so make sure you copy the whole thing.
http://www-307.ibm.com/pc/support/site.wss/product.do?subcategoryind=0&familyind=101256&brandind=10&doccategoryind=0&modelind=0&doctypeind=8&validate=true&partnumberind=0&sitestyle=lenovo&template=%2Fproductpage%2Flandingpages%2FproductPageLandingPage.vm&operatingsystemind=49979&machineind=101260
Mar 20, 2009 | IBM ThinkPad R32 2658 Notebook
ThinkPad R32 Overheating
Its more likely the fan has stopped working. I recommend taking it to a qualified repair shop.
May 21, 2008 | IBM ThinkPad R32 2658 Notebook
How to run USB 2.0 version device on USB 1.0 port on IBM Thinkpad R32
Well i not shore what to do, but you can go to you local computer store or the IBM factory.
May 01, 2008 | IBM ThinkPad R32 2658 Notebook
DVD
I don't mean to disagree with my associate, but DVD players for R series (or T, A, etc) can be found for less than 20.00 US (Ebay is a good example)
For that matter, we've got at least a dozen at our shop which we sell for 25.00
Installation is very simple as well, just pop the old drive out, put the new drive in.
Good luck
Oct 30, 2007 | IBM ThinkPad R31 2657 Notebook
IBM ThinkPad R32 2658 Notebook Logo
90 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
