Question about NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111)
Ray Hi, my name is ray and i having prolem to connect to my router, because i lost or forgot my password.
  • 123 Answers
You must reset your router..
Posted on Apr 06, 2008
How do I recover from lost guest password?
If you can log into the router you should be able to simply reset the guest PSK to whatever you like. If you have a computer that can successfully connect to the guest network you can open an elevated command prompt on it and type netsh wlan export profile name="ProfileName" folder="C:\" key=clear Replace ProfileName with the SSID for the network.
Dec 09, 2015 | Belkin Wireless Dual-Band N450 Router
What will i do if i forgot my security key???
All you have to do is connect to the router and change security key/ secure the connection. Just follow the following steps: -
First you have to access the router through web browser (Internet Explorer) by typing the IP address of your router in the address bar, which is 192.168.0.1 (Default router settings are written under the router)
(unless you've configured otherwise, the default username is admin and the password "leave it blank") and lookup for the options to do the following: -
Next step is to secure it:
1.On the left-hand side, under Setup, click "Wireless Setup" 2.Under "Wireless Security Mode", select your desired encryption method (preferably WPA2-PSK)
3.Choose a Network Key - it can be anything, as long as it's 8-63 characters in length
4. Click Save Settings.
1. Change the SSID (Name) of the router
2. Change the default administrative user name and password
(The above step would prevent unauthorized access to your router)
Now your router and your connection would become secure and the user has to provide the network key to access the internet.
In case you have forgotten the User Name/ Password of the router, there is no way to recover the lost password However, you can reset the router to factory defaults and re-configure settings like password, network key etc. First, to reset the router to factory default setting, press the reset button at the back of the router.
Please note that after RESETTING THE ROUTER to defaults, ALL SETTINGS WILL BE LOST AND YOU HAVE TO RECONFIGURE IT. Generally, after hard reset you get the connectivity, however, you have to make the connection secure etc.
Please, refer here to download the product guide/manual and make configurations as per the details provided by your Internet Service Provider (ISP).
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 01, 2011 | D-Link AirPlus DI-524 Wireless Router
I forgot either my username of password
Hi There,
The key to resetting this router is to use a pen or paperclip to hold the "Reset" button (it's on the back side where all the connections plug in.) Next to the power cord. What you do is hold this button in, then unplug the router at the same time; and plug it back in. Let the lights go normal; then, do it again 2 more times. This will reset the router back to it's "default" password which will be "admin" there will not be a user name. From this point, you can reset your configuration.
I am sorry, this router requires a full configuration reset to fix the lost password. You cannot retrieve it without going through this process.
Thank You.
Jan 29, 2011 | Linksys WRT160N Wireless Router
I forgot my password can not log on to my wireless network any suggestions?
If you are talking about your router then you can reset the router there will be a button on the back that you push and hold for 5 sec then follow the steps below
To open the set up page of the router of the router , one of your computer should be able to go online through the router.
It could be a wired computer or wireless computer.
If it is a wireless computer then make sure that the computer is connected to your own wireless network.
Do not change any wireless settings on the router using a wireless computer.
OK ! Now you have a computer online through the router and you want to open the set up page of the router.
First step is check the IP address of the computer.
Check the IP address and the Default gateway on the computer.
For Windows XP
START ==> RUN ==> type in cmd in the RUN box==> click OK or Hit ENTER . You will see a black window that is a command prompt . In the black window type in " ipconfig " ==> and Hit ENTER on your key board .
For Windows Vista and Windows 7
click on START ==> type in cmd in the start search box ==> enter ==> you will see the black window. Type in " ipconfig "you will see a lot of information. Try to find out the local area connection IPv4 address .
Note down the Default gateway number.
For MAC OS
Click APPLE icon in the right top corner of the computer. Go to System Preferences ==> go to Network ==> you will find the option Built in Ethernet or Airport whichever is connected. If you go to that you will find the Ip address and router Address.
The default gateway is the IP address of your router.
This IP address of the router will be used to open the set up page of the router
Now you got the IP address of the router.Open the Internet Browser ( Internet Explorer, Firefox, Safari )
In the Address bar of the browser Type the IP address of the router.
Do not type http:// or www just type in the IP address only.
It will ask you for the user name and the password of the router.
This is the User name and the password of the router and NOT the wireless password. On a wireless router, there are 2 passwords. One is to access the router and the other one is for the wireless network.
For most of the routers the default password will be " admin " . for some routers the default password is " password ". For Linksys router the default password is admin and no user name.
Jan 13, 2011 | Computers & Internet
I cannot connect to the internet with my linksys wireless router hooked up through my dsl modem. I also lost the installation disk. What can I do to resolve my problems?
DSL uses a ppoe account. Your DSL provider should have given you a router/dsl modem to connect to the internet, and then you can use another router to feed the house a wireless connection. The ppoe user name and password should be set up on one of these devices. If you don't know what your user name and password is, (I forgot mine a long time ago), you can contact your provider and have your password reset. Once this is done, you will either have to connect via wire to the device that should have your user name and password, and set it. Default IP address to get into this router is 192.168.1.1, type that into your address bar on your browser.
default user name and password are both admin, all lower case for both.
Once you get into the device then you can go into the setting and look for connection settings.
Here is the PDF for this router. Start looking at page 5 to learn how to set up a ppoe user and password.
http://www.quickline.com/Shop/Documents/Benutzerhandbuch_WRT160N.pdf
Dec 30, 2010 | Linksys WRT160N Wireless Router
I have forgot my wpa security password,i have tryed to reset my router,but im not having much luck,cause i dont understand it all.when i follow the instrsuctions what the person onm line tells me to do,i...
How to View or Change Your Wireless Network Password Symptoms:
  • You have lost or forgotten the password to your wireless network
  • You have lost or forgotten the password for the router, access point or other network device
  • You left the default password or used a weak password and someone has hijacked your network
Depending on the router, you can either view or reset the wireless network password (also referred to as the passphrase or security key) if you can log into the router. Some routers mask the wireless network password, so while you cannot recover it, you can enter and save a new password.
If you cannot log into your router because you have forgotten the router password or your network has been hijacked, please refer to "Lost or forgotten password for router or other device" below.
To view or reset a wireless network password:
  1. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
  2. From the left-hand navigation menu of the Router Manager, select Set Up > Wireless Settings.
  3. From the center screen, select your encryption type from under the Security Options heading.
    • If the wireless network passphrase is visible, review it and use it to log devices onto your network.
    • If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
If you cannot log into your router:
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
NOTE: Restoring factory defaults on a device will erase any customizations you have made. You will lose any configurations saved to the device!
See the following articles for more information:
Nov 07, 2010 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Lost my user name and need to add new computer
Are you trying to connect to the wireless network ?
Or your new computer will be connected to router with the cable.
If it is hard wired to the router and the router is working for the other computers then you don't need to change anything on the router.
If you are trying to connect to the wireless network then you should know the wireless settings of the router.
Click Here for step by step solutions
Nov 06, 2009 | D-Link DIR-300 Wireless Router
Lost Utility CD and forgot old password
here is the user guide for the 566, it is the same manual , look at page 20 for instructions on how to reset the router:
http://www.ddp.ru/upload/images/PDF/WL566gM.pdf
Sep 26, 2009 | ASUS WIRELESS ROUTER |WL-520G - RT...
Forgot password
Just reset the router from the small hole at the backside of the router and you shall be fine but all the information ill be lost..
Jun 28, 2008 | Linksys Wireless-G WRT54G Router
Lost instruction
Most of the Router user name and password will be admin and admin try this
Jun 22, 2008 | MSI Wireless-G RG54G3 Router
NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111) Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
