Question about HP Compaq Business Notebook NX9010
Vista Thanks for the help with locating the second ram on the lptop , if now I have 2 GB ram do you think I can run Vista on it
  • 77 Answers
With 2gb of ram. yes you can run Vista but the question is, do you really want VISTA? it might run sure, but it might be too slow, if i were you, i will upgrade the ram and still use XP and you would definitely see a performance boost with that upgrade
Posted on Apr 07, 2008
What are the features and system requirements of: (1) Vista (2) Window 7 which major advantage does Window 7 has over Vista? Thanks.
Here are the minimum requirements
  • 1 gigahertz (GHz) or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) RAM (32-bit) or 2 GB RAM (64-bit)
  • 16 GB available hard disk space (32-bit) or 20 GB (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
Windows 7 is better, smarter and faster than vista!
Here's a website that'll further help you
\http://www.tweaktown.com/articles/2886/windows_7_vs_vista_cpu_memory_performance_comparison/index2.html
Jan 28, 2012 | HP Computers & Internet
Hi!... I am using window 7 ultimate 64 bit. I am facing the problem of full HD. earlier when me using window Vista that has been ok. If there is any solution plz let me know!.. thanks Moiz Raja
windows 7 os requires atleast 16GB avilable space while windows vista requires atleast 15gb. It could be true that your system requirements are not sufficient for the new os you want to install
If you want to run Windows 7 on your PC, here's what it takes:
  • DVD-ROM drive
If you want to run Windows Vista on your PC, here's what it takes:
  • 1 gigahertz (GHz) 32-bit (x86) or 64-bit (x64) processor
  • 1 gigabyte (GB) of system memory (512 megabytes (MB) for Home Basic)
  • 40 GB hard drive with at least 15 GB of available space (20 GB for Home Basic)
  • Support for DirectX 9 graphics with WDDM and 128 MB of graphics memory (32 MB for Home Basic)
  • DVD-ROM drive
If you think this solution helps you then your token of appreciation in the form of Rating and a testimonial will be esteemed.
Thank you and Keep Visiting FixYa!
Apr 17, 2011 | HP w1907 LCD Monitor
Asus notebook windows 7 totally frozen..."not responding" Can't even exit without holding power off.
This is due to the fact that your ASUS Eee PC 701 PC does not offer minimum System requirements to run windows 7
Microsoft has published their minimum specifications for a system running Windows 7
as
  • 1 GHz or faster 32-bit (x86) or 64-bit (x64) processor
  • 1 GB RAM (32-bit) / 2 GB RAM (64-bit)
  • 16 GB available disk space (32-bit) / 20 GB (64-bit)
  • DirectX 9 graphics processor with WDDM 1.0 or higher driver
But I suggest following as min to run smoothly
  • A Dual Processor (AMD or Intel) – you can use a lower Celeron or Pentium Processor, but you will regret it
  • 2 GB RAM (operating memory) – you can use less, but you will regret it
  • 16 GB available disk space and another 20 to 30 GB if you plan on running applications
  • A Vista compatible graphics card (DirectX 9 graphics process with WDDM 1.0 or higher)
  • A Vista compatible sound card
  • Vista drivers for any other unique hardware you have on or connected to your computer
If this helps please do leave a vote and rate for the solution.
Feb 21, 2010 | ASUS Eee PC 701 Notebook
No memory
OS Vista minimum want 512 mb ram for run. & yiur only 512 mb ram which is used for your all program. So incres your ram Atleast
1 GB. 2 GB is best.
Jan 30, 2010 | Acer 4220-2346 Notebook
I have a compaq presario c700 running windows vista. On my previous laptop I was able to record successfully using Audacity. Now, however, recordings are very poor - the sound comes and goes, and is of...
Stuart, make sure have the System requirements Here are the recommended memory (MB or GB of RAM) and processor speed (GHz) requirements for using Audacity with different versions of Vista:
Version Recommended RAM/
processor speed Minimum RAM/
processor speed Vista Home Basic 2 GB / 1 GHz 512 MB / 1 GHz All other Vista versions 4 GB / 2 GHz 1 GB / 1 GHz
Note that the minimum system requirements as defined above (i.e. those that allow the operating system to run, ignoring what is required to run applications) are much greater than for Windows XP. If your computer does not significantly exceed these minimum requirements then you may have problems doing more intensive tasks in Audacity such as recording for long periods or editing a large number of long tracks, or may need to close other programs and processes before you can do so. Please be aware that the cheapest "deals" for new Vista machines may well only include the Vista Home Basic Edition and system specifications little in excess of the Vista minimum requirements.
Other things being equal, 64-bit versions of Vista will require more RAM than 32-bit versions. While some users report Audacity runs fine on 64-bit Vista with 2 GB RAM, this depends on the number of tracks being worked with and the number of other programs and services running on the computer. Memory is now very inexpensive. The general recommendation for 64-bit Vista is to install a minimum of 4 GB RAM - and for very best performance, install the maximum RAM that your motherboard supports.
If you meet the min system requirements. Uninstall your sound card drives and try the beta version for Windows Vista.
http://audacity.sourceforge.net/download/
WBTech
Jan 19, 2010 | Apple iMic, USB Audio Interface Sound Card
Is 1 gig of ram enough memory to support vista to run?
Hey there you want to use vista?? lol good luck. You need a min of 2 gigs ram to run vista but should ideally have 4 gigs for good operation. vista is a memory hog. You can change the configuration to use less but still need at least 2 gigs
seth
Jun 27, 2009 | HP Pavilion dv6000z Notebook
Vista RAM usage ?
The minimum recommended ram for Vista is 1 GB, generally accepted practical minimum is 2 GB. A 1 GB system will be kinda laggy. Maximum RAM for 32 bit Vista is 4 GB.
Vista Home Premium is roughly equivalent to Windows XP Media Center Edition (Has Media Center, cann't be put on a DOMAIN type network)
Vista Business is roughly equivalent to Windows XP Professional (Can Join a Domain, Doesn't have Media Center)
Vista Ultimate has all available freatures of Vista, you can do any windows function with Ultimate
Apr 26, 2009 | Dell Dimension 3100 PC Desktop
Which windows is suitable for vaio vgn-nr280e
Windows XP
You can run the Vista utility to check if you can run vista on that machine, but I don't think you'll be able to.
XP is your way to go!
Hope this helps muhammad_far.
Jan 17, 2009 | Sony VAIO VGN-NR280E/W 15.4" Notebook PC...
Slow
I would clear your cache on your computer. Also would run Disk Cleanup & Defragment. It really depends on what OS your running because Vista can slow it down running on 2 GB RAM because thats the Minimum and the best would be 4 GB. I'm running 2 GB and it does run slow at times so thats why I use classic theme instead of Vista Aero. Also, for it being slow could be spyware or a virus. Thanks, GaComputerGuy
Aug 28, 2008 | Gateway Computers & Internet
Will hellgate london work on my pc
These are the system requirements:
OS - Windows XP/Vista
Processor – XP: 1.8 GHz or faster / Vista: 2.4 GHz or faster
Memory – XP: 1 GB RAM / Vista: 2 GB RAM
Hard Drive – 7 GB (14 GB required for Digital Delivery)
DVD Drive – 8 SPEED (not required for Digital Delivery)
Video Card – 128 MB with Pixel Shader 2.0 support*
Sound Card - DirectX 9.0c compatible
DirectX - Version 9.0c (included)
Online Multiplayer – 512 Kbps or faster
Input - Keyboard, Mouse
This download is not supported on FAT16 and FAT 32 file systems.
*Supported chipsets: NVIDIA GeForce 6200 or greater (GeForce 8800 recommended for DirectX 10); ATI Radeon 9000 or greater. Laptop versions of these chipsets may work but are not supported. Updates to your video and sound card drivers may be required.
I think you'll need a better Video card.
Nov 17, 2007 | Dell GX270 P4 256/40/48X/XPP/NONE...
HP Compaq Business Notebook NX9010 Logo
96 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
