Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Hi. When the machine is switched on from the mains, after a few seconds you hear a click. I think this is the door mechanism. Immedately after this the trip on that mains ring is triggered so the mains goes off. The display on the machine comes up as normal, no errors. The machine was in the middle of a B wash when it went of and is full of water. (Empty maintenance wash your supposed to do). I have managed to cancel this in the short time the machine is powered on. Initialy I thought it may be the pump, so disconected the power connector to it. Have gradually been working my way round various connectors to try and isolate the problem part. Any ideas ?
Thanks
Got the same problem, engineer came out thinks motor will need replacing approx £180 plus fitting
Posted on Apr 18, 2008
Washer dryer door open and key sign and clicking noise when I try to start up washing machine Amber light flashing
Is the door fully closed or has some debris got into the mechanism.is the child lick on?try resetting the machine by switching off power at socket, then whilst holding the start button for five seconds whilst you switch it back on at socket.door solenoid should cluck once and the key sign should disappear.hope this is of help.
Jan 18, 2015 | Hotpoint Aquarius WD640 Front Load...
Door locked light is flashing hotpoint aquarius washing machine wont start
More than likely the door mechanism is faulty and needs to be replaced
Jun 17, 2012 | Hotpoint Aquarius WD640 Front Load...
My hotpoint aquarius wdl540 keeps tripping the switch on the main fuse for the kitchen plug sockets
hello, the reason for this because theres a dead short inside washer or the socket may have a loose wire check all the earth wires inside the washer and the sockets get back to me if you still have trouble
regards
shaun
Jan 03, 2011 | Hotpoint Aquarius WD640 Front Load...
Door will not open
Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open.
Thank you !!
Jun 26, 2010 | Hotpoint Aquarius WD640 Front Load...
I have somehow managed to put my hotpoint aquarius into test mode
To get out of it you need to press start, the display should go daft. Press start again and the display should settle down. Now press the on/off button and the start button at the same time and hold them down for a few seconds until the display shows d-end or d-off.
Mar 15, 2010 | Hotpoint Aquarius WD640 Front Load...
Hi i have a Hotpoint WD640 1400 spin Aquarius + and on the control panel it keeps flashing F-13 can anyone help
The dryer fan or dryer thermistor (thermostat) is faulty.
If the fan is working, then replace the thermistor, or check for broken wire.
Please rate my solution.
Thanks.
May 05, 2009 | Hotpoint Aquarius WD640 Front Load...
Broken door handle.
Remove top cover, and reach down with a long screwdriver or similar, and actuate the door lever from inside by pushing the catch over.
Thanks.
Apr 11, 2009 | Hotpoint Aquarius WD640 Front Load...
I have a hotpoint wd640 and i cant get it out of test mode any ideas?
trn main dial to empty drum icon
press start/cancel button and on/off button together then switch off at mains and leave for 10 mins
got this info off hotpoint themselves and it works for me
Jan 02, 2009 | Hotpoint Aquarius WD640 Front Load...
Saying to close door and we already have
When you shut the door , do it very firmly until you can hear the latch click, if it still will not start, then you could have a faulty door lock or a communication problem between boards.
Plz rate my solution.Thanks.
Dec 23, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
90 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
