1- shut it down then open the computer box 2- find a green or blue jumper beside the memory slot or Data cable slots 3- remove jumper , then turn computer on wait for 10 sec then shut it down 4- put the jumper back and close the computer box 5- turn the pc on and have fun
There are two ways to restore this machine to factory settings;
First is thru the Recovdery partition in the hard disk itself:
Close any windows currently open and click the Inspiron's "Start" button. Select "Shut Down" and choose the "Restart" option.
Tap "F8" when the Dell image appears on the screen. Continue tapping the key until the advanced boot menu loads.
Scroll down to "Repair Your
Computer" and press "Enter" to access the DataSafe local backup screen.
Click "Next." Select "Dell Factory Image Recovery and DataSafe options."
Click the "Restore without
preserving new or changed files" radio button and click "Next." Click
"Next" three more times and click "Restart" to restore the disk drive to
its original condition. Follow the on-screen prompts to set your
operating system settings.
If the hdd was already repartitioned or corrupted, the second option should work:
Insert the Dell recovery disk in
your Inspiron's optical drive and close the "AutoPlay" window when it
appears. Shut down any other open programs. Click "Start" and select
"Restart."
Tap "F2" as soon as the Dell
image appears on the laptop's screen. Scroll to the "CD-ROM" option and
press "Enter." Tap any key when you see the "Press any key to boot"
option.
Press "Enter" when the setup screen appears. Press "F8" and highlight the Dell's hard drive partition. Press "Enter."
Follow the instructions on the
screen to choose the Inspiron's operating system options. Click "Finish"
and remove the recovery disk from the optical drive. Click "Start" and
select "Restart."
Hold down the power button for 10 seconds. That will hard-shut the PC. Once that is done, fire it back up, and try again. Somethimes, windows will act goofy shutting down. Especially Vista when it is left on too long without shutting it down.
Check your computer bios settings. There is a power managment section. Turn off power managment or set it to os controled. Check dells support site for any acpi drivers that you may need. These are needed for suspending controls.
