Question about iRiver X20 MP3 Player
Iriver x20 hi,my iriver x20 mp4 has lost some space in th sense a folder is empty but it has the space so help me with it
  • 49 Answers
Try and view hidden files...
it depends wat the folder is...
it might be a system folder, in which case you'd be better to just ignore it
Posted on Jun 09, 2008
Song names in X20
i think you should try this...
if you dont already, download iriver plus 3
install it
open iriver plus 3
plug in iviver
go to tools>Portable Device>Disk Initialization
this should format your iriver and replace all the original files
i reccomend only putting music, video, pictures and ebooks on via iriver plus 3
and also please make sure you safely remove the iriver each time you connect it to the computer
if you dont, there is a chance that you will screw your iriver, you may have heard of the "building library" problem, which nobody has found a solution for yet.
i hope this helps you!!
good luck!
Jun 06, 2009 | iRiver X20 MP3 Player
My IRiver MP4 is stuck on "Build Library"
ive searched for hours, i couldnt find a solution..
but i will buy it off you for $30
..i like pulling things apart.. lol
anyway, if your interested, ill pay for postage too, contact me
deano_90@hotmail.com
Apr 26, 2009 | iRiver X20 MP3 Player
How can i delete my music from mp3/x20
1. connect it to your computer
2. u have a few options
  • Manually search the MUSIC folder of your x20 and delete the songs.
  • sync it with a program such as iriver 3 plus or windows media player and delte it through the program
  • reformat if your looking to delete everything
hope this helps!
Apr 07, 2009 | iRiver X20 MP3 Player
Iriver X20 won't read on Iriver plus 3
this is a major problem i found with iriver plus 3. it tends to stall quite regularly. i suggest using wmp11 its just as effective. it cannot convert files but it syncs up quite nicely
Hope that helps!
Nov 08, 2008 | iRiver X20 MP3 Player
Iriver X20 switches off when using FM Recorder
there may be a problem with the menu files...
Aug 30, 2008 | iRiver X20 MP3 Player
Folders inside my IRIVER X20 no longer recognised!! HELP PLEASE!!!
Try making a new folder, under the same name as the ones lost, or missing. Since the X20 is flash memory based, you may have had some of your data go randomly corrupt. You MAY have to start things over. Sorry! Good Luck!
Apr 10, 2008 | iRiver X20 MP3 Player
Iriver mp3 player
Same problem on a 2GB x20 I just bought. Easy to get things into the device, but nothing recognized as playlist either using iriver plus3 or Media Player.
Feb 05, 2008 | iRiver X20 MP3 Player
Transferring recordings from iRiver x20 to PC
Yes, it should work if you connect to the pc then click on my computer> iriver> then find the recordings and copy and paste them to a folder on your computer.
Jan 05, 2008 | iRiver X20 MP3 Player
Downloading movie length DVD to iriver x20
Yes, you need to convert all your movies to a format iRiver and understand and play.
Here's a link:
Movie Converter for iRiver and instructions
I'm not sure whether Movie Converter supports original DVD files. If that is not the case, then you'll have to convert DVD video into a format that iRiver X20 can use, and then feed that new video to Movie Converter.
However, that would be a bit redundant: to save on time and quality, you could use other video Conversion tools, such as SUPER:
http://www.erightsoft.com/SUPER.html
After loading your DVD, you set the parameters to mirror those accepted by your iRiver model. In case of iRiver X20, those parameters are:
Extension: AVI [[also known as container]]
Video Codec: WMV9 SP, MPEG-4 SP [[MPEG-4 = XVID, DIVX]]
Video Resolution: max 320 × 240
Video Framerate: max 30 fps
Video Bit Rate: max 512 kbps
After successful conversion, upload your new video file to your iRiver X20 and play it back. If it plays [and plays correctly] - then congratulations - it works! If it does not play, then you might have made a mistake while setting the output parameters in SUPER.
Hope it helps. Rate me. Thanks.
.:: Cyberneticus ::.
Workıng only wıth pc
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Dec 24, 2007 | iRiver X20 MP3 Player
iRiver X20 MP3 Player Logo
54 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
