Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Fridge not chilling
Fridge is warm and is no longer keeping foods chilled.
    Sergeant:
  • 415 Answers
Check the temperature setting recommended by the mfg. you will find all the info. in the use & care guide.
is it just the fridge or is the freezer acting up as well?
Posted on Sep 13, 2008
SOURCE:
Where can I get a repair manual for a Hotpoint Fridge
First of all, the model number you gave is not complete. But check you defrost system in the freezer, when the refer section stops cooling, your evaporator in the freezer is possibly full of ice and the fan won't move air through ice. When the refer sections fails to cool, check for a fan in the freezer. If it works, you have a defrost problem and is occurs every 3 - 5 days. The unit should defrost once or twice a day. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Apr 20, 2016 | Hotpoint Refrigerators
Hotpoint frost free fridge freezer the fridge not working but freezer is
Hi Reginald
Most refrigerator / freezer units chill the fridge area by venting some fraction of the very cold air from the freezer into the fridge compartment through a channel that has a mechanical air valve in it. In this way, it can control the chilled air flow, and aim for the set temperature, all the way down, in some cases, to freezing, or even colder, on the fridge side.
That vent unit, depending on your model, sill be somewhere in the wall that separates the freezer from the fridge. What can happen is that moisture condenses into the louver that slides to control the airflow, it freezes, and then system is stuck, since it's cold on the freezer side, and this keeps the louver frozen stuck. If that is the case, shutting the unit off for a while may recover function, though getting it to where ice is melting in an interior wall may be more risk of food spoilage than you'd want. Otherwise, use a search engine to look for 'how to test freezer / refrigerator vent in make/model', and you'll likely come across all sorts of youtube and step-by-step tutorials.
Good Luck!
D
Nov 30, 2015 | Hotpoint Refrigerators
Is it good for compressor to run allways
No... If the thermostat is set too high so that the fridge can never get to the required temperature then you have to ask whetther the fridge/freeser? needs to be so cold. If your home is very warm and the unit just about copes with chilling and freezzing your food maybe you need a more effective fridge.
You can always turn the thermostat fown if it is not very warm as long as your food is preserved/stored safely.
The compressor should go off, you will pay a large electricity bill if it does not.
If the unit is not working very efficiently have the freon level checked, might need topping up
GOOD LUCK
Jun 16, 2015 | Refrigerators
Hi, I have a Whirpool fridge, model ED22TW that is suddenly no longer keeping things cold/frozen. Both the freezer and fridge gauges are turned to the max however my frozen foods are still defrosting...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 08, 2011 | Refrigerators
What is the best temperature to keep the refrigerator ( Hotpoint)
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:SIY_RFFRIDGETEMP
What should a Hotpoint fridge temperature be?
Your Hotpoint fridge is designed to operate at a temperature ranging from 0.5 degrees in the coldest part up to 5 degrees inthe warmest part.
As warm air rises and cold air falls it is safe to say that the best way to store your food is to place it in the most appropriate shelf compartment, as shown in the diagram below.
  • Zone A - Cool Dairy Products, Cheese, Butter, Margarine, Low Fat Spreads, Cooking Fats/Lards, Preserves, Jams, Curs, Marmalade, Salad Dressing or Sauces
  • Zone B - Colder General Food Storage
  • Zone C - Coldest Meat, fish & poultry, Pre-cooked/chilled food
  • Zone D - Salad Bin, Vegetables, Fruit and Salad Items
May 08, 2011 | Hotpoint Refrigerators
Water dispenser does not dispence water
need to replace the water inlet valve. the part number for this model is 4389178
Jun 18, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Hotpiont ffm90 fridge not chilling
hi if the freezer appears to work and the fridge if warm,the problem is that the freezer is over frozen and blocking the vents which send cold air into the fridge when required,and the noise is the fan hitting the the ice build up,defrost (switch off)your applinace for at least 36 hours then switch back on,you will then find after the freezer reaches -12 the fridge will then start to go cold.
Mar 09, 2009 | Hotpoint FFM90 Bottom Freezer Refrigerator
Over Chilling Refridgeration set on 7C still goes to 0C Digital thermostat
sounds like a bad thermostat,you can check it with a meter by putting the meter on omes,thermostat in closed position no reading turn thermostat all the way on you should get a reading if not replace,let me know-mike
Sep 29, 2008 | Westinghouse WRS6R3EW 36" 25.8 Cu. Ft....
The fridge is making ice
I agree in the fridge there should be a chill controller check that it isn't turned up too hi.
Thanks J
Feb 08, 2008 | Freezers
Fridge temp too high
probable cause is jammed fan. first take back panel off fridge, electrical connections are plug and socket. yoy may find a quite small build up of ice underneath the fan. melt it off and you should be ok. samsung are prone to this problem
May 08, 2007 | Samsung RS2630WW Side by Side Refrigerator
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
87 people viewed this question
Top Frigidaire Dishwashers Experts
Archie Ferrarini
Archie Ferrarini
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
