Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Printer turns off and will not come back on after you push cancel
I was printing pictures and pushed cancel when i pushed print again it said printing and froze then i turned it on and it makes starting noises and never turns on
  • blueeyes1 Apr 05, 2008
    i cannot get my pinter to come on after pushing cancel when i pushed print again it said printing and froze so i turned it off and niw it doesnot come on
  • turbor May 05, 2008
    i push cancel and then try to copy another picture it wouldn't do anything so i turn it off now i can;t get it to come back on I try unpluging it but stll won't turn on what do i do?
  • 2,785 Answers
Just unplug your power cord and push it back.then switch the printer on.please post your result
Posted on Apr 05, 2008
I have a dell 2350d printer. It contninues ot print repeatedly the samr thing over and over again. Somebody at the hotel must have pushed print 500 times. How do I cancel the ENTIRE print job?
turn off the printer, disconnect the usb cable from the unit then click the start button on your computer, select printer & fax there u can see your printer right click on it then select cancel all pending job,, hope this help
Jul 31, 2011 | Office Equipment & Supplies
Cancel printing is on and will not turn off after canceling when pushing the stop/exit button. i cannot print anything else. when i turn it off and unplug it then plug it back in for 1 min and turn it back...
You did not list your model but if it is an MFC series then try turning off the machine and then hold down the clear/stop button while turning the power back on. Continue holding the button for a few seconds. This procedure will clear whatever may be stuck in memory. This works on most Brother models but may not work on yours.
Good Luck and Thank You for using Fixya.
Aug 12, 2010 | Brother Office Equipment & Supplies
When I turn the printer on getting ready to print the light flashes between green and amber. When I push the Resume button nothing happens. When I turn the printer off and then turn it on again. The same...
-check for paper jam
-check your ink cartridge
-unplug your printer for 1 minute
-turn it back on
-if same problem still exist go to your computer and look in the system tray in the bottom right-hand corner find a printer icon and cancel all print jobs.
in most cases things should function again.
Mar 26, 2010 | Canon BubbleJet i560 InkJet Printer
How to cancel printing a document
If the document is currently printing and you are using Windows, then at the bottom right of the screen you should see a printer icon (picture).
Double click on that icon and it will open the printer dialogue box and you will be able to cancel the printing from there.
Oct 26, 2009 | HP Photosmart 3180 All-In-One Printer
Error0xc19a0024 on a hp 6180 will not print
Follow the below 2 solutions :-
  1. Turn off power and unplug from power source.
  2. Open right side of printer.
  3. Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
  4. Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
  5. Unplug power source.
  6. Reconnect the flat ribbon cables by aligning and carefully pushing into the connectors on the main circuit board.
  7. Plug in power source and turn printer on.
  2. Open right side of printer (looking at the front).
  3. Disconect,by pulling gently, the flat ribbon cable off the main circuit board that is the smaller of the two.
  4. Plug in power source and turn printer on. Wait till you hear no more movement from inside from unit booting up.
  5. Press both cancel and power button at the same time.
  6. Message on printer screen will be, "Enter Special Key Combo".
  7. Push keys; Left-Ok-Right.
  8. When printer screen changes, scan through and look for "System Menu" and push "Ok"
  9. Scan again and look for "Clean Derivative" and push "Ok". Wait for 1 minute.
  10. Scan again and look for "Clean Firms" and push "Ok". Wait for 1 minute.
  11. Press "Cancel" 4 times
  12. Turn off power and unplug from power source. Wait for 2 minutes.
  13. Reconnect the flat ribbon cable by aligning and carefully pushing into the connector on the main circuit board.
  14. Plug in power source,and turn on power.
  15. When printer boots up, answer the questions on the printer screen for your area.
  16. The printer will cycle the ink from the cartridges to the print head and back.
If problem persists, let me know.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 07, 2009 | HP Office Equipment & Supplies
My Canon i 560 s will not print and this is the error message, I followed instructions, no change, won't print, yellow light flashes ,"Operator error. Press the printer's RESUME button. If this doesn't...
Turn off your PC, turn off the printer. Open the printer and check for paper jams, push/pull the ink cartridge carrier left to right to ensure it also isn't jammed.
Only use a small amount of paper (10 sheets). Too much paper can sometimes block the feeder
Turn everything back on, try again.
Jul 02, 2009 | Canon BubbleJet i560 InkJet Printer
Cannot get print operation stays on answering machine.
turn off your printer. then you chose start option from your windows. and click printer and fax option from above of hlep and support switch. and you can chose that printer in which you faced problem. and open that printer option. then you will see pending list of your printer. on that list you select all and do right click on that list and click cancel option.after cancellation of all the pending document. you turn on your printer. right now you can print as per wish.
priyabrata (Be in IT)
Feb 16, 2009 | HP OfficeJet 4215 All-In-One InkJet...
Need confirmation of fax sent and received
You can setup the printer to print a confirmation page on send. Push the setup button - then push right arrow until you see print report and press okay - press right arrow until you see fax confirmation and press ok - push right until it says on send and press ok. Hit cancel to go back to default and now you will get a confirmation for all sent faxes.
Jan 16, 2009 | HP Officejet 5610 All-In-One InkJet...
Paper jam notice......make sure paper tray is pushed down.......error....
I've just talked with HP support and they fixed the problem. This is the solution:
1- unplug printer while it's on
2- after 10 seconds, and while it's unplugged, press the cancel and OK buttons at the same time and plug it while holding the buttons.
3- after the printer is on, release the buttons
4- if it does not start the computers, then turn it on manually (with the power button) while pressing the cancel and OK buttons at the same time and release them after the printer starts
5- try the copier and print a page through the computer
6-turn it off for 1 minute and then on again. The message should not be there now
Good luck
Dec 07, 2007 | HP Photosmart C5180 All-In-One InkJet...
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
