T.V. turns itself off
My television turns itself off and won't turn back on without resetting by unplugging and plugging back into an electrical outlet. The last time I tried to reset the television it Autolocked itself out of every channel. How can I fix this problem. The television is only about 4 & 1\2 years old. Ticker at bottom of screen gets cut-off.
  • Anonymous May 17, 2009
    Same problem - I even paid $120 to have it fixed; and they replaced something. Worked for a while; now it cuts itself off and on and for awhile would reset; but now it doesn't last. Am getting another tv - too expensive to keep this one.
    Scholar:
  • 119 Answers
What make/model is the TV?
If it's in a cabinet or other enclosure, try taking it out - it may be overheating.
Posted on Apr 05, 2008
When I turn on my Sony TV, ti stays on about 30 seconds then shuts off, What do you think is wrong?
Do a Power Reset.
1. Turn off TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If issue persists after doing the steps, reset the TV to factory default settings.
1. Turn on the TV.
2. Using the supplied remote, press and hold the UP arrow button.
3. While holding the UP arrow button press the POWER button on the TV itself.
4. When the TV goes off, release the POWER and UP arrow button.
5. The TV will turn on by itself and the initial setup screen will be displayed. Just follow the on-screen prompts to finish the setup.
Sony KDL 46V5100 random shut off 15 20 sec
Feb 25, 2016 | Sony Televison & Video
Please my tv with on the standby mode when i try to put it back it couldn't the indicator now goes on and off with picture show please help
The standby light on a Sony television indicates when the television is turned on and operating, or turned off and in "standby" mode. However, this light also serves a secondary function: indicating when there is a problem with the television by flashing. When the standby light begins to flash, there are two reset options that can be performed to resolve whatever issue it's indicating -- a power reset and a factory reset
POWER RESET
1. Turn off your TV
  • 2. Unplug the television from the electrical outlet. If you're using a surge protector or power strip, disconnect the television from the strip itself. Only by disconnecting the power cord from the outlet can you ensure no power reaches the TV during the power cycle.
  • 3. Leave the television without power for at least 60 seconds. This gives the television enough time for all components to power down during the power cycle
  • 4. Plug the television back into the electrical outlet. If you're using a surge protector or power strip, plug the television directly into the wall outlet instead. The surge protector may otherwise interfere with the power-up cycle, especially if it is old or damaged.
  • 5. Turn on the television. If the blinking standby light continues, you'll need to move on to the factory reset process.
  • FACTORY RESET
  • 1. Turn on the television.
  • 2. Press and hold either the "Reset" or up arrow button on the remote control.
  • 3. Press and release the "Power" button on the front of the television, while keeping the "Reset" or up arrow button on the remote depressed.
    4. Release the "Reset" or up arrow button.
    5. Allow the television to reset after the "Reset" message appears on the screen.
    6. Make no adjustments to the television for at least one minute after the reset has completed. This is to allow the television time to finish auto-configuration and initial set up.
    7.Turn off the television and unplug the power cord from the electrical outlet.
    8. Wait ten seconds, then plug the television back into the electrical outlet and turn on the TV.
    9. Follow all on-screen instructions to complete setup. These are the instructions displayed the first time you set up the television, for configuring channels, menu language, time, display properties and more.
  • Dec 30, 2014 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    My sharp LCD tv won't turn on,it goes off after a few seconds.
    Time for a new TV. or you might unplug it let it set for a while and then plug it back in see if it reset itself.
    Mar 13, 2013 | Televison & Video
    NO POWER
    Need to know how many times the led is blinking.
    Re: tv kdl-55ex620 red light blink 8 times Do a Power Reset. 1. While the TV is off, unplug the power cord of the TV from the electrical outlet. 2. Let the TV remain without power for 60 seconds. 3. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.) 4. Turn on the TV. 5. When the TV powers on and a picture is displayed, reset the TV to factory default settings.
    • If the Reset message does not appear and the TV turns off and on, begin again from step 5.
    • If the standby light begins blinking eight times, return to step 1.
    6. After the Reset message appears, allow the TV to reset. Do not press any buttons on the remote control or on the TV and do not make any other adjustments for 1 minute. 7. Unplug the power cord from the electrical outlet. 8. Allow the TV to remain without power for 10 seconds. 9. Plug the power cord back into the electrical outlet. 10. Turn on the TV.
    • The initial setup screen displays if the above procedures were performed correctly.
    11. Follow the on-screen instructions to complete the initial set up. 12. Perform a system software (firmware) update.
    Sep 04, 2012 | Sony KDL55EX620 55 inch BRAVIA 1080p LED...
    I turn it on and within 5 or 10 seconds it turns itself off.This happens if I hook it up through my direct tv receiver or not.
    I need model number and brand of your tv to find out possible cause of problem.
    Thanks.
    Mar 06, 2010 | Televison & Video
    TURNS OFF ALL THE TIME
    Hi
    Thanks for using FixYa. You’ll need to reset the Projection TV and to reset it follow these steps:
    1. Turn off the television and wait for 5 minutes.
    2. After 5 minutes unplug the television power cord from the electrical outlet.
    3. Let the television remain without power for more then 1 minute.
    4. Plug the power cord back into the electrical outlet. If the television is plugged into a power surge protector, remove it from there and plug it directly into the wall outlet. Turn on the television. If the issue is resolved, then the problem is with the power surge protector and not the television.
    If the issue is not resolved then this might have happened due to over-voltage. Please check the power supply unit for swollen/bulged capacitors and burnt wires/components on the power supply board of your TV. You should try and turn off the TV for 8-10 hours to reset it. Please make sure to turn off and unplug the TV for at least 1 hour (this will drain off current from all components especially capacitors) before you perform any repairs. Also note that the TV consists of very high voltages even when it is in OFF condition. All this is only recommended if you have electrical expertise and know how to solder/re-solder components.
    Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
    Jan 26, 2010 | Samsung SP46L6HXX/XEU 46" HDTV-Ready DLP...
    I have a sony wegs lcd tv with a seperate monitor and media centre. when I turn the media centre on the monitor lights up green on the stand by light and then afetr a couple of seconds the monitor switches...
    The STANDBY light will flash if the television detects an issue within the television. Some of these issues can be resolved simply by following the steps below to reset the television.
    If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
    1. Turn off the television. Unplug the television power cord from the electrical outlet.
    2. Let the television remain without power for 60 seconds.
    3. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
    4. Turn on the television.
    Sep 21, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
    Won`t turn on
    Try leaving it unplugged for longer period of time. Look on the remote for any possible reset function. Try power button without the remote. If any ot these doesn't work there is a power supply module inside that malfunctioned. If under warranty contact where you purchased it. If not under warranty if you can get the module it is a simple plug up procedure.
    Dec 31, 2007 | LG 42LC7D-UB Television
    Sony kv32fs16 problem
    The STANDBY light is flashing on the television and there is no picture or sound. Solution
    sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
    1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
    2. Unplug the television power cord from the electrical outlet.
    3. Let the television remain without power for 60 seconds.
    4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
    Nov 02, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
    before any attempt to deep cause of problem, unsolder first all the tack switches in the front panel of tv.then turn on the tv using remote control observe? cuz maybe one of the switches is stock.if not,proceed to eeprom servicing which is u have to look for service mode of ur tv model to unlock it and reset it to factory value.
    Sep 12, 2006 | Philips 32RF50S 32" TV
    Televison & Video Logo
    242 people viewed this question
    Top Televison & Video Experts
