Windows live messenger
I have a siemens se 587 wireless router and everything is working fine apart from i cannot log into windows live messenger. Windows live say the router is blocking a port it uses. How do i sort this out?
Thanks
Dave
**** knows
Posted on Apr 05, 2008
MSN disconnects me from the internet
Please access your router default page and disable WPS(WIFI protected system) option. And then once your done disabling the above option, and if you still have any problems,
                                       OR
Try uninstalling messenger and reinstall it again or try using windows messenger the default one which windows provide and try using that and see if you can work on it with no hastle.
Regards,
Yateesh, Bangalore.
Nov 02, 2009 | Microsoft Windows Live Messanger
Windows live Messenger 2009 on vista disconnected internet
well, i cant really help with this, but i would first try it out with wired network, and if it doesn't work, then u would know that the problem is with Messenger. then i suggest u could look up the problem on windows live support, or just re-install Messenger. (if the problem is with the wireless internet, then maybe ur Internet Card, inside ur PC is broken or needs to be rebooted) HOPE THIS HELPS!
Jul 03, 2009 | Microsoft Windows Live Messanger
Linksys WMP45G will not connect to wireless modem
well!! I have an answer for you.your comp is loosing the IP address.
goto start - programmes - accessories - dos prompt.
type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it.
goto network and sharing center,click on view status,goto propertiesand double click on internet protocol(tcp/ip) or IPv4.type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2.
ypur connection won`t drop after this.
Jun 09, 2009 | Linksys (WMP54GS) 802.11g/b Wireless...
Error 51330 on nintendo wii siemens gigaset se587 wlan used.
hi
i have just solved this problem on the SE 587, hope it works for you.
1) in internet explorer type 192.168.1.1, which should bring up your router settings - then select "wireless" and then "basic wireless settings" - under "auto channel" set it to "disable" and the set "wireless channel" to "1" , then "save settings" - my pc briefly went offline and quickly came back.
2) when setting up the connection on the wii you need the code from the bottom of the router - make sure you have "caps lock" ON on the wii when you set up.
3) now everything works perfectly on the wii - you dont even need the pc on! just the router.
good luck, IAN.
Dec 16, 2008 | Siemens (120-5830-001) Modem
Im having problems conecting my nintendo wii to my tiscali siemens gigaset se587,can you help me please as i have tried to link them both together with a wireless conection but i just get an error message?...
hi
good luck IAN.
Sep 02, 2008 | Video Game Consoles & Games
Windows live messenger won't run
I have the same wireless adapter and have had the same problem with Windows Live Messenger.If you click Control-Alt-Delete and check your running Processes you will see msnmsgr.exe.
Close it.There will be one shown for every attempt you made to start windows live.Close them all.
Next reset your Wireless Router by unplugging the power cable for 30 seconds or so.Plug it back in and your Windows Live Messenger should start.
Jun 05, 2008 | D-Link WUA-2340 (ASKU55774) Wireless...
Siemens se 587 router
HI,
You can try manuall setup of da router.
The Default gateway for Siemens Gigaset SE587 is 192.168.1.1. Open Internet Explorer and put the def gateway in the browser.
The default username and password for siemns router is admin.
Click on Setup Tab than Basic Setup on left hand side. Update the details as folloing-
Use – Tiscali data PPPoA Interface
PVC Selection – Tiscali data PPPoA
Authentication – Auto
User Name - Tiscali u/n
Password - Tiscali password
PPPoA Connection Mode- Always On
NAT - ON
And click on save settings. To confirm if the customer is connected, check the status of Online light – which should be green
. Alternatively click on status (On top) to check internet status to confirm connection.
Setting Up Wireless connection – Click on da wireless tab on the top.
Ensure that the Auto channel is disabled and the wireless channel is 11, wireless n/w is Enabled and mode is Mixed.
To secure the wireless connection – Click on Wireless Security option on left hand side
If you want the Security mode as WPA than select the wireless security mode, as WPA and enter WPA Shared key which would be on the base of the router. Again click on save settings.
Try connecting to the wireless network again and I m sure it should work..... lemme know if it does.
Cheers
SHADAB
Mar 26, 2008 | Siemens SpeedStream 2624 Router...
Problem with msn live
try www.supportspace.com
100% free, but 100% qualfied experts to help you.
Oct 28, 2007 | Siemens SpeedStream 2624 (SS2624) Wireless...
Computers & Internet Logo
107 people viewed this question
David Payne
David Payne
