Question about Panasonic Lands Phones
Need to open handset for kx-tc1025 cordless phone. has 2 screws in battery compartment
  • Richard Montgomery Apr 19, 2008
    I am attempting to open the case of the handset to reset the keys to work properly. Unfortunately, I cannot seem to open the case. I have removed to two screws in the case but I do not know how to release the upper holding mechanism. I do not want to force it and break it as a result. How do you open the case of this phone, Panasonic KX=TGA571A. Thanks.
After taking out the two screws from below the battery compartment, the case will separate slightly on the bottom. Take a screwdriver and carfully pry the case open along both sides, working from the bottom toward the top of the handset. This will free the back of the handset from the primary components. It will simply snap back together when done and then replace the two screws.
Posted on Feb 06, 2011
Manual for Panasonic kx-tg6521R cordless with answering machine 2 handsets
It is this one. The handsets are the same on the base unit and the extensions.
KX TG6521 Cordless Panasonic
Jul 09, 2016 | Panasonic Lands Phones
Where can I get an instruction manual?
Panasonic kx-tga600b handset manual - Google Docs
https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesPanasonic kx tga600b cordless extension handset manual. Panasonic kx ...Panasonic kx tga520 5.8 ghz fhss cordless expansion handset manual. Panasonic kx ... Panasonic kx tg6071 operating instructions manual pdf download. Panasonic... Need manual for kx tga600b so i can turn off voice mail dont need. Panasonic ...
Kx-tg6500 manual - Google Docs
https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesPanasonic kx tg6500 operating instructions manual pdf download. Panasonic ...Panasonic kx tga650b cordless extension handset installation. Troubleshooting ...Panasonic kxtga651b dect 6.0 plus expansion handset black kx. Panasonic kx ...Can i register a kxtg6500 handset with a kxtg4500 base. Panasonic kx tg6502 ...
Panasonic KX-TGA650B ' Installation Manual - Page 3
Feb 09, 2016 | Panasonic KX-TGA650B (037988474806)...
I have a panasonic kx-tga271 handset. The speaker phone, the ringer and keypad noise do not work. Is it fixanle?
It could be the speaker. I have a handset with the same issue. The internal speaker which produces these sounds broke. If you can find a small speaker that fits inside, its an easy fix - - just take out the screw inside the battery compartment and carefully undo the plastic assembly. The speaker is held in place with a plastic anchor that twists off. There are two dots of solder which attach the wires that will have to be melted and resoldered on the replacement. Anyone thats handy can fix this. Look for a used handset for parts. You might also consider breaking apart a cheap set of headphones for the speaker. It won't be as loud, but at least the sound will be restored to some degree.
Oct 21, 2010 | Panasonic KX-TGA271 Cordless Expansion...
Panasonic KX-TG2356 Cordless Phone key pad
Open the hand set by Removing battery, remove 2 screws under battery, carefully open handset casing by prying open with thin bladed screwdriver, remove pc board by removing 3 retaining screws, on opposite side of pc you will see contacts for handset buttons clean with eraser and reassemble handset.
Jan 24, 2010 | Panasonic KX-TG2356 Cordless Phone
Openning a panasonic cordless phone handset
Carefully slide a thin bladed jewellers screw driver along the side of the case as you go the catches will release, do not force it !!
Good luck
Jan 11, 2009 | Panasonic KX-TG6021M Cordless Phone
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
Open the handset to clean keypad
Hi Sue,
Sometimes there's a screw or 2 inside the battery compartment, other than that they snap together.
Once you get the keypad out, wash it in warm water with a couple drops of dish liquid, rinse and pat dry. The Pc Board the keypad sits on can be cleaned with alchohol and Q-Tip.
Hope that helps.
Geno
Apr 01, 2008 | Panasonic KX-TGA650B Headset Phone
How do you get the KX-TGA270S apart to replace the Antenna
Real easy... remove the battery and you'll see 2 screws. then start peeling the phone in half from where the screws were.. the phone may seem like its breaking but it does snap apart... then you will needs a soldering iron to replace the antenna..
Nov 13, 2007 | Panasonic KX TGA270S Cordless Expansion...
Lands Phones Logo
137 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
