Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
Problem getting CPU to recognize Seagate
The Seagate HD worked fine for about 6 months. Now it doesn't recognize the device. Plugging in it and out, turning off HD power, restarting CPU will occassionally get the HD to show but only for about five minutes before it drops in error. Very strange...is this a common occurance with Seagate?
I also had problems with this drive which i solved by using a freeware partition manager to create a partition on the drive as this had somehow become "lost". I used "Cute Partition Manager" to create a bootable disc and using this to access the offending drive created a partition using all the available space,this worked perfectly and i lost no data from the drive, hope this helps
Posted on Apr 06, 2008
Hey try this site and reinstall the drivers http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=freeagent-downloads&vgnextoid=3723b5b59b7d5110VgnVCM100000f5ee0a0aRCRD
Posted on Apr 05, 2008
    Master:
  • 518 Answers
It is with the Free Agent, as I also have one. What I found on mine was that the interface electronics in the bottom run too hot and start to fail in various ways. If I unplugged the power supply for an hour, then the drive would work for a while. So I put it on it's side and directed a small fan at the bottom and now it works for weeks at a time. So it's a thermal problem with the interface electronics. I've heard that some folk just bought a different housing and put the drive into it.
Hope that helps...
I have a 500 GB Seagate portable external hard drive model 9ZA2AH-500. It was working fine untill yesterday. Now when I plug it in all I get is a faint beeping sound Then it stops. I have tried plugging it...
It may be the interface that has failed but I suspect the hdd has failed.
Take the hdd out of the case and fit another drive. If that one is OK the hdd is dead. If it doesn't work, try a new usb to SATA interface.
Sep 25, 2017 | Seagate Free Agent Go Small 12 GB USB...
I cannot boot my PC when the seagate hard drive is attached. I have to disconnect the external Seagate drive and then boot. Once booted I can physically plug in my seagate External Hard drive and it...
restart the system, while restarting , press delete/F8 to enter in BIOS menu, select boot priority and select the primary HDD as first boot device, deselct the "boot otehr device" option.
it should work fine.,
Cheers!
Sep 11, 2010 | Seagate Computers & Internet
Seagate Freeagent not recognized, not in device manager either
OK 1. Go to Start>> Right click My Computer>> Manage>> Device Manager 2. Expand the USB Controller section 3. Right click and Uninstall all of the listed USB devices 4. Reboot the system
Do this with NOTHING plugged in at all. Plug back in AFTER reboot. Then it may/should all work again.
Mar 05, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate Barracuda 7200.10 EIDE 160 GB. Computer does not recogniz
Hello
If you plug it in and windows states that the device could not be recognized, try plugging it in in one of the USB ports in the back of your case, This worked for me.
If you just can't see your HD in my computer, try these following steps.
Go to:
Conrtol panel
Administrative tools
Computer management
Storage
Disc management
Now you should see see the drive in the schematic below, then right click on the drive and assign a new drive letter.
Restart, and all should be set.
If this does not work, have a look at the jumper settings on the drive itself. For this you must take the hard drive out of the case again.
Hope this works. Please rate this.
Best regards
Sep 28, 2009 | Seagate Computers & Internet
Dish Network Vip722 does not recognize Seagate Showcase 1TB Drive
Same problem here, 722 not recognizing Seagate Showcase, been going on for months now. Per Seagate advice, I replaced Dish Network Receiver, no help, finally pressed Seagate after all their "troubleshooting" (which was no help at all) & they said to return Showcase & they'd send out another. Well they didn't send me back a Showcase, but (2) 1TB external computer hard drives. Now my 722 recognizes this computer drive is there, but: 1) you can't delete anything from it once it's on there, you hit "delete" & it doesn't delete, it's still there. Contacted Seagate about this & they said to delete programs you'd have to "wipe" the entire thing by unhooking it from your DVR, plugging it in to your computer, then "wiping" (erasing) the entire contents of the drive. WHAT???? I bought the drive to store some things I'd like to keep until I have time to watch them, store other things that I'd like to keep permanently. I don't want to "wipe" the contents of the entire drive. Good grief, that isn't how this was meant to work, you are supposed to be able to add/delete any program you wish, WITHOUT having to "wipe" the entire contents of the drive by hooking it to your computer. 2) you can't "resume" something after you've stopped watching it say, halfway thru, you have to manually find where you were by skipping or fast-forwarding, 3) if you pause program you're watching, it won't restart by hitting "play", you have to hit "skip fwd" & then it will skip forward & resume playing, 4) if you hit "stop" while watching a program, it just "freeze frames" & then won't take you back to your menu (like it should), it just freezes, & to "unfreeze" it you have to again hit "skip fwd", doesn't respond to anything else 5) sometimes it recognizes the programs you have recorded, other times it does not, thus your programs you've recorded you know are there, & the DVR is recognizing the unit itself, but unless you pull out the USB, wait, then plug back in the USB, it doesn't show you your recordings listing at all. I have no contacted Seagate & have now (I feel) exhausted all of my options. I am DONE, stick me with a fork. I asked Seagate why they didn't send me another Showcase, which is what they should have done, but they replied "we're not sending any more of those out right now". Hmmmm, sounds like I'm not the only one having this problem, huh? Why else would they not send me out a replacement of my original purchased product, but try to replace it with (2) computer drives instead, which is not what I purchased, I purchased a Seagate Showcase, because it is the ONLY drive recommended by Dish Network to be "the" drive exclusively meant to work w/Dish Network....ha ha. Somebody needs to go back to the drawing board here, Dish Network blames Seagate, Seagate blames Dish Network. I'm so done with all this that I don't even care any more who's problem it really is, or if the problem is a combination of both companies products perhaps, all I know is I'm finished. I am returning both of these computer drives, and am FINALLY supposed to be getting my money back. Hallelujah, Amen, I'm getting off of this roller coaster & won't be riding again anytime soon.
Sep 20, 2009 | Computers & Internet
After Seagate device not recognized, all flash drives gave troubl
even tho you have AV software installed , I wouldn't write it off so easily. Download and run Malwarebytes from
www.malwarebytes.org
and you may be surprised how ineffective AV software can be some times.
Don't forget to rate the advice!
http://www.aa1consulting.com
Jul 28, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
My external hard drive is unreadable
Does you drive make any sounds like these? If yes you have a mechanical problem and you should get a specialist to work on it. If not - try to remove the drive from USB casing and connect it directly to your PC or put into another USB enclosure. This should help if the problem is with the enclosure itself and not with the drive.
Dec 30, 2008 | Seagate FreeAgent Pro 1TB External USB...
Installation issue - Not recognizing
hmm, no problem plugging in either side, just be sure to do the power cable first. What's doing the beep, beep?
Found a guy who had similar prob, here was his solution:
Go to Control Panel. Click on Device Manager.
Check to see if FreeAgent is shown as a disk drive.
If not, check the device list for any Free Agent device, double click and check driver. No driver installed? Update does not work? On the driver tab….click uninstall device.
Shut down computer. Unplug Free agent USB and power at the drive.
Reboot computer. As it is rebooting, plug in the power cord. Wait a minute or two….then plug in USB cord.
Windows will “found new device” ….. Just let the computer complete the reboot.
Then go to the device manager. Chances are you will find Free Agent in the drives….and in the USB list of devices. Open windows explorer….and you should see you Free Agent as a drive.
Windows will ask you to install manufacturer disk. You have no disk…non needed. Windows has installed the device. Just click on close. I you keep getting windows wants to install device…..ignore it. You can click on “don’t ask again”. (That is if your Free Agent drive is showing in the device manager as a disk…and in windows explorer….along with your other drive or drives.)
If at some later time….your Free Agent drive does not appear….repeat the steps as listed above.
(You may think it is not working….or that it has gone bad. Try this before you try to return.)
Seagate Tools…the new version….does not recognize to diagnose the Free Agent….
I have not tried Seagate Tools after getting the computer to recognize the drive.
I am surprised Seagate does not provide a Tool to recognize their own drives…and install and/or test Free Agent.
This does work for me with Vista. Thought I had lost the drive…. Seagate should provide a patch or a drive that Windows will recognize when you get the “found new hardware” and Windows asks you to insert manufacturer’s installation disk. I do not understand why that is not already there….a driver file for Free Agent...that Windows would install.
I did not buy Pro….because I did not need the backup software. I wonder if those who bought Pro are having these problems.
Oct 30, 2008 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Firewire not recognized.
If running Windoze OS, then try plugging in the firewire cable after you are fully booted and see if it picks it up as new hardware found. That may get it configured for you.
Good luck.
Feb 17, 2008 | Dell Inspiron 9200 Notebook
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
246 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
