Question about Dell E173FP 17" LCD Monitor
Black spots i hit screen and now have round circles all over, different sizes, can i somehow open the monitor and clean inside of dell 15" flat screen ?
  • Dell Master
  • 13,434 Answers
If you hit the screen, then there is noting you can do. the lcd matrix would need to be replaced.
Posted on Apr 05, 2008
6ya staff
SOURCE:
Why is there two black spots in image on screen. Two round black circles. Not sure what it means and where they came from
1st make sure screen is clean. inspect when off. use only cloth slightly damp with water.
2nd make sure it is not the image by looking at another image or a blank white screen. Some test images will display each color.
if it is there on any image the pixels are dead. But being circles sounds more line screen cleaning
Sep 14, 2014 | Vtech InnoTab 2 - VTECH
There is a large scratch on the screen, and appears black when the monitor is on. My monitor fell and hit the edge of a shelf because I had it leaning forward too much. Obviously, the mark is deep, and the...
It is evident that the LCD panel of the monitor is damaged. If your computer has Dell complete care you can get the monitor replaced. If not you can contact a local technician and get the LCP panel changed, with the remaining circuit boards and backlight assembly intact.
Jan 27, 2011 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
E172FP (Black) 17 in. Flat Panel LCD Monitor: Dell monitor problem, its the power save mode agai...
First, try it on another PC, check or try another VGA cable, if it still does not work then you need to open it up. Dell monitors are known to have bad solder connections, bad caps. See my photo albums of failed Dell monitors to get some idea what to look for.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Replacement bd: www.lcdrepair.us
May 18, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
Black spot is growing on my LCD Monitor
It is the LCD itself failing, no repair for the LCD itself, the screen will need to be replaced. Likely cheaper to replace the entitr monitor
Sep 20, 2009 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
Black spots on the screen
I think you should try going to the store and checking if your monitor is still under warrenty. From the description, I think it is beyond repair.
Jun 26, 2009 | Samsung Computers & Internet
HOW DO I GET THIS STUPID PADLOCK THAT KEEPS OPENING AND CLOSING IN THE MIDDLE OF THE DELL MONITOR SCREEN TO GO AWAY FOR GOOD?????
Solution Steps For Computers Running Windows XP
1. Click on "Start" at the bottom left of the screen.
2. Choose "Settings"
3. Choose "Control Panel"
4. Double click on the "Display" menu option.
5. Click on the "Settings" tab on the display dialog box.
6. Move the resolution slider to a different screen size (e.g. 800x600, 1024x768).
7. Hit the "Apply" button and select "Yes" that you want to use these new settings.
8. Change the resolution back to your preferred setting. Hit "Apply" and "Yes" again.
9. You can also righ-click on a blank spot on the desktop and choose "properties" to get to the same screen in Control Panel and change the settings
Apr 15, 2009 | Dell E176FP 17" LCD Monitor
Suddenly my horizontal size on my Dell montoris reduced about 1/3
On the monitor there should be some buttons that allow you to manually configure the width and hieght that the screen comes up with.
Does you screen come up squashed but you can still see everything or only 1/3 of the screen is shown and the rest is black.
Mar 20, 2009 | Dell E153FP 15" LCD Monitor
Black spot size quarter on my dell monitor and a thic white line
There are 2 answers here. First is (bad) luck of the draw for your buddy and that would be that it just happened to go bad when you gave it to him. I could believe that except for the black spot. That leads me to believe he inadvertently pressed something in the spot and the pixels are now bad. This may have happened when he or even you were transporting it or as he was carrying it in.
The question I see is how do you resolve it? If you were lucky enough to have plugged it in prior to your coworker taking it, the onus would be on him/her. If not-and to avoid bad blood at work- you may want to refund a portion of the price. Sorry there is no clear cut answer here but in the future if you should do so again, let the purchaser see it al works beforehand.
Feb 14, 2009 | Dell E177FP LCD Monitor
Dell Monitor 15"flat panel-2 Horiz. black lines
HAS IT HAPPEN ANYMORE OR IS STILL THERE.
CHECK YOUR DRIVERS, UPDATE THE DRIVERS, CHECK THE CONTROL PANAL IN THE FOLLOWING FOLDER DEVICE MANAGER, PROBLEMS REPORT, SYNC CENTER
OTHER THAN THAT TECHN SUPPORT OF YOUR VENDER WHERE YOU BOUGHT YOUR MONITOR FROM OR GO ON LINE AND TYPE THE FOLLOWING INFORMATION EXAMPLE:
DELL E151FP FLAT PANEL LCD MONITOR 2 BRUSH STROKES ON SCREEN
ENTER
SEE IF ANYONE ELSE MAY OF HAD THE PROBLEM OR TO COME FIND OUT THAT THAT WAS A RECALL ITEM FOR THAT MONITOR, JUST KIDDING, ITS WAY OUT THERE
ROD
Feb 09, 2009 | Dell E151FP 15" Flat Panel LCD Monitor
Dell E173FP 17" LCD Monitor Logo
146 people viewed this question
Ekse
Clive
Clive
Alun Cox
