I special-ordered & received 3(min.order) URC8910 "learning remotes" as MCM tech.s advised. I tried several such devices & none will work w/my TV(OLEVIA/Syntax-Brillian).* I told them I wanted a LR that could capture IR input from each original remote key, assigning them to learn.remote keys. Any chance you have an upgrade/capture code for my TV? The 4(L1-L4)keys aren't enough.*MODEL#432-S12 LCD/HDTV 4-Series. I hope you have the upgrade I need, as I can't return them (per conditions of special-order).
  • selstada Apr 05, 2008
    I have an LCD HDTV. Is LCD a projection TV? If so, I did not know that.
    Genius:
  • 3,422 Answers
HI,
You can try to get the parts from HERE or HERE
Goodluck..
Posted on Apr 05, 2008
  • Priya darshan Apr 05, 2008
    You can also try THIS
    Yes it is.You can check THIS out and you will understand everything about the LCD
6ya staff
SOURCE:
CODES FOR CLEAR TECH TV ON DIRECT TV REMOTE
0028,0021,0022. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Oct 27, 2015 | Televison & Video
New receiver from dish and new remote. Codes tried-683,590,674,517,611,621,627,656,661,688
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
Aug 13, 2015 | Televison & Video
How do i program this remote to my tv
You should find in your Universal Remote user's manual the code for brand of your TV and follow indicated procedur. Of course, you need the manual. Hoe you have it
May 03, 2015 | One For All URC-4021 Remote Control
How do I sinc my fireplace remote ecs1001-a two button to fireplace
Each transmitter uses a unique security code. It will be necessary to press the LEARN button on the receiver to accept the transmitter security code upon initial use, if batteries are replaced, or if a replacement transmitter is purchased from your dealer or the
factory. In order for the receiver to accept the transmitter security code, be sure the slide button on the receiver is in the REMOTE
position; the receiver will not LEARN if the slide switch is in the ON or OFF position. The LEARN button in located on the front face
of the receiver; inside the small hole labeled LEARN. Using a small screwdriver or end of a paperclip gently press and release
the black LEARN button inside the hole. When you release the LEARN button the receiver will emit an audible "beep". After the
receiver emits the beep press ANY transmitter button and release. The receiver will emit several beeps indicating that the transmitter's code has been accepted into the receiver.
Oct 29, 2012 | Skytech 1001-A Fireplace Remote Control...
I need a user manual for a STATUS model rct-08 remote control as it needs resetting.
Plug the receiver into a mins power socket. The red LED flashes every second.Press any on switch for more than 2 seconds on the remote control. The receiver will learn the code. When the LED flashes continuously after 2 seconds and goes off it means the receiver has learnt the code. You can add various receiver sockets to any one on switch to create a zone. Repeat these last 2 steps for all receiver sockets selecting a different receiver button for each receiver socket. After a power cut pull out the receivers from the mains power socket and repeat the above steps.
Plug the device you want to operate into a receiver socket. Press the on or off button to activate the receiver socket. Or press the on/off button directly on the receiver socket to operate the plug.
To decode. Press the On/Off button on the receiver socket for more than 3 seconds. After 3 seconds the LED flashes once per second, decoding is successful.
Press the All/Off switch on the remote control for more than 3 seconds. After 3 seconds the LED flashes once per second, decoding is successful.
Hope this is OK for you. Peter
Nov 21, 2011 | Televison & Video
I have an Onkyo DR-S2.0 dvd Receiver that will not turn on. That aside I'm trying to find codes for the remote in order for it to learn my Philips tv and my Yamaha stereo receiver. The remote is a RC-437M....
Can't help you with the turning on problem, but the remote doesnt use codes to control other devices it learns the signals from that devices remote. heres a link to the users manual:
http://www.intl.onkyo.com/downloads/manuals/pdf/dr-s2.0_manual_e.pdf
the programing procedure is on page 63
May 21, 2010 | Onkyo RC-549M LCD Remote Control
Program remote to replace all remotes
Hi, yes of course it is possible! First off, you have to make sure that your Dish device it set on remote address 1 in order for it to be controlled by the Harmony. Then, once you add the device to your Harmony account, if there are any functions that are missing, you can learn them right from the original remote .
Adding a device:
1. In the software, clcik 'Add Device'
2. Follow the on screen instructions.
Learning a command:
1. In the software, click 'Learn IR' next to the icon for your Dish device.
2. Go down to the bottom of the page where it says 'Learn a new command'
3. Type in a name for your command, and click 'Learn'
4. Follow the on-screen instructions.
Hope that helps you get this set up right!
Mar 17, 2010 | Logitech Harmony 700 LCD Remote Control
Cant find dvd codes for an universal remote
Unless the remote is newer than your player, it isn't likely to have the required codes built in. There is no such thing as a truly universal remote; there are many multiple device remotes but none of them will ever be complete unless they have provisions for adding code sets from newer devices via download. BTW, even the 'learning' remotes will not learn from every original.
Next time your post such a request, be advised that you must include the make & model numbers from everything. This is not a 'generic' question.
Jan 03, 2010 | Daewoo Televison & Video
Remote control codes for Symphonic tvcrg13
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
May 19, 2008 | Philips PM3S Remote Control
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
