Question about Refrigerators
My LG GRL207QVJA fridge is freezing everything. Changing the temperature setting on the front control panel seems to make no difference & the temperature in the bottom half of the fridge is constantly at -5'c I bought the Fridge freezer in 2006 but as it's not wear & tear should the fault still be covered by the manufacturer?
  • 725 Answers
I would check your owners manual but most LG only have a 12 month warranty .
check your Express or Fast Freezing Function is not turn on.
then you most like have a Thermistor/ control problem.
let me know
Posted on Apr 05, 2008
SOURCE:
Fridge Ices Up Even on the Warmest Setting (Freezer Working Fine)
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
If it runs then that cold control is the problem.
Sep 15, 2017 | Refrigerators
Maytag MFI2569VEM chills to the point that everything in the refrigerator section will freeze, regardless of the temperature setting on the front panel.
these tipe of units have an electronic board that controls basicly everything thats your problem you need to replace the electronic board. some times a temperature sensor wired to the elect. board fails but most of the time the board is the problem
Feb 10, 2014 | Maytag Refrigerators
Refrigerator 795 69292.901 built 8/09 refrigerator is very cold. temperature adjustment does not seem to work. All of the five circles to indicate temperature look alike. None is lit up or is marked,
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Hope this will help in solving the fault.....
May 14, 2011 | Kenmore Refrigerators
Fridge freezing up
Check the fridge sensor. On my Hoover HNMF2805AL80 f/f, first I replaced control module - still freezing.
Have just replaced cheap fridge temperature sensor. Part No. 97061619. Trouble is you have to cut into insulation at back of fridge to replace. I just plugged in sensor & placed inside fridge at back at the bottom - so far so good, only lettuce freezing now, everything else v. cold but not frozen. :)
Jun 02, 2010 | Hotpoint RLA50 Refrigerator
It freezes everything in the fridge,I have it on the lowest setting
depending on the make and model of your fridge, you most likely have a faulty temperature control which needs to be replaced.
some newer GE side by sides have a different issue.
Mar 01, 2010 | Refrigerators
Fridge freezes up and then meltsw
I FOUND A PROBLEM WITH A COUPLE OF THESE THAT THE AIR FUNNEL ALONG THE BACK WALL WAS SEPERATED FROM THE FLOOR OF THE REFRIGERATOR REMOVE THE CRISPERS AND LOOK AT THE BACK WALL. IF THERE IS A GAP AT THE BOTTOM AIR DUCT APPLY SILICONE {FOOD GRADE ONLY} TO SEAL THE GAP
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 12, 2010 | LG LRBN20510WW Bottom Freezer Refrigerator
VEGETABLES FREEZING IN LOWER LEFT DRAWER. I have an LG model LFX25960. If I raise the temp to 45 in the refrigerator it will be 34 in that drawer but that also makes the rest of the refrigerator too low a...
Hello, This problem is going to be the cold control, this can be located in the control panel inside the fridge. This part is also called the thermostat. What is happening here is it has opened and the freezer is getting to cold which is making the fridge too cold. This is why the food in your fridge is freezing. You should replace the cold control and you will be all set. Mike
Nov 07, 2009 | LG Refrigerators
Hi my fridge freezes every thing even at it's
your thermostat is bad, what it does it sense the temperature set buy the control setting, once it goes bad it does not recognize the temperature hot or coold and the unit keep running and freezes everything. thermostat work like the therometer switch, when it reach certain temperature it cut off.
Jul 16, 2009 | Dometic Refrigerators
LG Refridgerator GR-131R. Out of the
Good day.
Seems like your thermostat went shorted that is why you cant control the temperature anymore.
chris
Mar 11, 2008 | Refrigerators
Samsung french door fridge not working?
I had the same problem ("OF" on display and not working) and just found a fix and it worked (on SAMSUNG site).It was correctly stated that fridge is in "demo" mode. You need to push and hold POWER FREEZE and ENERGY SAVER buttons (not "Fridge button and the Power Cool buttons" as it was suggested above).
Oct 14, 2007 | Samsung RM255LASH Side by Side...
Refrigerators Logo
425 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
