Labtop computer internal hard drive
What model would internal hard drive would work it a toshiba labtop wit 40gb hard drive modle mk4025gas. that what i have now .want more gb which modle would work.
  • 99 Answers
The drive you have is a IDE, Ultra DMA 133, 4200 RPM.
If you are running XP or Vista you can purchase any brand hard drive. Size depends on what you want to spend. Recommend Maxtor. Just make sure it is IDE and for a laptop. Most computer retailers will sell them (BestBuy, Circuit City, etc)
Posted on Apr 05, 2008
SOURCE:
Rebuild a hard drive
Have you tried it in another computer as a secondary/data drive to see if you can read it?
Try removing it from the computer, putting in a zip lock bag and then in the freezer for a day or so before putting it back in the computer.
Alternatively google to see if you can get a replacement circuit board. Could work for an older drive like that.
Jul 24, 2014 | Toshiba MK 4025GAS (MK4025GAS) 40 GB Hard...
Hardrive is unknown device in bios
The BIOS determines the maximum size hard disk the computer can support.
The max hard disk size for this model Dell is 80Gb.
To use your 250Gb hard drive, install this Hard drive into an USB hard drive case and use it as an external USB hard drive.
Mar 09, 2013 | Computers & Internet
Smart failure predicted on hard disk 0:TOSHIBA MK4025GAS-(PM) warning :immediately back-uo your data and replace your hard disk draiver A failure may be imminent
It means that your hard drive is going to crash soon. If all of your important stuff is on there and you don't have an external hard driver or flash driver, shut down the computer until you do. Once you own another hard drive, boot back up and start the backing up process. There is a fantastic free backup program available here: http://www.fbackup.com/
One trick I've found that works is placing the hard drive in a refrigerator for 30 mins before using it. This will extend it's life by at least 15 minutes.
Good luck to you, and pleas leave me a positive rating! :)
Jul 27, 2011 | Toshiba MK 4025GAS (MK4025GAS) 40 GB Hard...
I have been given a Toshiba MK 4025GAS laptop, it has 240 MB of RAM. How much more RAM can I put on it?
click start right click on my computer select properties you should how much ram you have installed and how much available it looks like it is capable of 4GB of ram remember when adding more ram try to keep the same brand/type as some motherboards will only work with the one type of ram together and always place the larger ram closest to the cpu central processing unit
Toshiba Mk4025gas Pm ... Shipping: FREE Total: $98.72 Memory Specifications Module Size(s): 2x4GB Type
CPU
Intel Celeron M 370 1.50GHz BIOS Phoenix BIOS. Press F2 to enter Chipset SiS 661 Memory 512MB PC2700 DDR SODIMM (2 memory slots. Max 2GB) ** Hard Drive 40GB Toshiba MK4025GAS CD Drive Philips DVD+-RW SDVD 8441 Screen 14" TFT (Native Res.1024x768) Video Card SiS 661FX (64MB shared) Sound Card Realtek AC'97 audio Network Card SiS 900 integrated fast ethernet
Atheros AR5BMB5 Wireless LAN * Modem Agere systems AC'97 modem Ports 1x Headphone
1x Microphone
1x PC Card
4x USB 2.0
1x Modem
1x LAN
1x VGA
1x S-Video (TV-Out) Touchpad Synaptics Touchpad Battery SQU-504 (11.1v 4400mAh) Dimensions 33 x 314 x 258 (HxWxD in mm) Weight 2.3kg Made By Quanta LE1D
The full system specs are:
CPU: AMD Sempron LV 3000+ (1.8 GHz.)
RAM: 1 GB. DDR-333, Kingston
Chipset: ATI Radeon Xpress 200M (RS480M/SB450)
GPU: ATI Radeon Xpress 200M
HDD: Toshiba MK4025GAS (40 GB., IDE, 4200 RPM)
ODD: TSSTcorp Combo (DVD-ROM/CD-RW 8x24x24x24)
Other:
- Texas Instruments UltraMedia Card Reader PCI xx21/xx11
- Broadcom 802.11g Wireless LAN
OS: Windows 7 Ultimate (32 bits, obviously
as you can see there is a contradiction in how much ram but if its a windows 7 it will need a minimum of 2 gb of ram but it could use 4gb
hope this helps
Jun 17, 2011 | Toshiba MK4025GAS (c99529) 40 GB Hard...
Smart failure predicted on hard disk toshiba mk4025gas ( pm )
This means your hard drive is bad or about to go bad and needs to be replaced. If you can still access the drive, immediately back up anything important to you. You will then need to replace the hard drive. Thanks and please take a moment to rate this solution with a fixya rating, even if the news isn't what you wanted to hear. Thanks! :c)
Feb 14, 2009 | HP Business Notebook NX9110 Notebook
Toshiba external USB hard drive (portable 40GB Toshiba MK4025GAS) does not operates with xp as it used to operate earlier.device manager in control panel shows code 10.Uninstalled and re-installed USB...
Try booting to the SAFE MODE (F8 at boot) opening Device Manager, deleting all USB Root Hubs, rebooting in normal mode, let hubs re-detect, then reconnect the drive
Jun 22, 2008 | Toshiba Computers & Internet
Internal labtop hard drive
If you are running XP or Vista you can purchase any brand hard drive. Recommend Maxtor. Just make sure it is IDE and for a desktop.
Hope this helps.
Apr 05, 2008 | Computers & Internet
Computers & Internet Logo
64 people viewed this question
Ekse
Alun Cox
