Question about Chamberlain 1/2-HP Whisper Drive Belt Drive Garage Access System
Chamberlain hd900d garage door opener
Just installed a chamberlain hd900d and after i set the travel limits and set the force everything works fine... Ahter 4 or 5 open and closes the top limit moves till it hits the trolly stop bold hepmike
    Scholar:
  • 143 Answers
You will have to open the unit and look inside it. Unplug it first. It should have 6-8 screws to take off. You will see 3 white plastic adjustment screws. There is a carriage they sit in. Make sure they are in this carriage. If you would like stay back a bit and plug it in and watch it run to see how it works. It is a direct contact system, so when the middle screw touches the copper limit of the limit screw it stops. Thanks BB
Posted on Oct 11, 2010
  • gotchaback Jan 10, 2011
    The HD900D does not use a mechanical limiter. It uses an electronic positioning sensor located at the gear box side of the motor. If you opened it up and watched it operation all you would see is a little circuit board with some wires running to it. If you read the posts on any number of boards, you'll learn pretty quickly that Chamberlain has some design/quality control issues with this setup. I installed a unit that was dead right of the box. Unfortunately, you can only discover the problem after you completely finish an installation. If you do it over a weekend, forget about calling their tech support line (800-528-9131) because they are closed Sat-Sun. My recommendation is to buy another brand that uses micro switches on the rail. I think Genie makes some products setup like this. Real bummer this problem, you can't just replace the circuit board, but have to replace the entire motor assembly (part number 41D794). Essentially, the little circuit board counts the rotations for the belt drive sprocket. The problem can start exhibiting itself with partly opened doors, slamming the trolley into the bolt stop on either end, or you simply won't be able to get the opener to program. The model has been around for awhile mostly sold at Home Depot. A real disappointment for an otherwise well known brand. Poor job overall, considering their antiquated approach to support, not better than anyone else, but you'd have to think Chamberlain is well aware of the problem and would have come up with a fix other than running their customers through support hell.
  • ceti2222 Aug 06, 2011
    I'm so disappointed in the performance of this unit considering what I paid. My problem is with the closed-position control limit. It's freaking unreal; sometimes I can't even program the limits sometimes. And this thing requires significant (re)programming as it's constantly jamming the door into the ground, no matter what I do. I've completely disconnected the lighting, the battery backup, and only have the wires connected for it's essential operation. I've had this thing since November of 2006 and it's become progressively worse year after year. In the hot Texas summer it gets worse and right now, I have it unplugged and am manually operating my garage door. Didn't really want to go buy another opener but it looks like I'll have to. I dropped the extra cash on this unit because it was quiet. It has all these other features that I don't care about but I've never had a problem with any product that provided such options. I remember my dad telling me back in the day to not buy top of the line stuff because it's just more stuff that can break. Maybe this isn't the problem but if Chamberlain devoted more time to quality control instead of gimmicks (I don't really care what the temperature is on the inside of my garage and if I did, I'd but a thermometer.), maybe so many people wouldn't be having this problem. /rant
What's the difference between the "limit controls" & the "force controls" on Chamberlain garage door opener model 1245r?
Limit controls determine the maximum up and down point for the door, so that it doesn't keep trying to close when it's already all the way down, or continue to open when it's fully open.
Force controls determine how much pressure can be applied against the direction of travel before the door will sense the pressure and stop moving. Imagine setting a watermelon or egg in the way of the door when it's closing. If your force control is not set correctly, it will crush the watermelon or egg.
Nov 29, 2014 | Building Materials
Chamberlain hd400 open force setting at max. Just installed. Will only open door with open force at max setting. Door appears to be balanced fine. No obstructions noticed.
If you release the opener from the door and operate the door by hand it should be obvious if there is a door problem. If it is in warranty you can call Chamberlains technical support line at 800-528-5880. Double check that model number before you call. They don't recognize it.
Oct 03, 2011 | Sears Craftsman LiftMaster Chamberlain...
Door reverses after fully closing, how do I determine if problem is due to adjustment to force or travel limits
If the door fully closes, the travel limit must be adjusted, as you suggested.
If the door were to open before fully closing, that would be too much rolling resistance.
Gary
Jul 12, 2011 | liftmaster Chamberlain Garage Door Opener...
I have a Chamberlain Whisper Drive Security + model HD900D that is opening by itself awhile after the door has fully closed & I've gone into the house, sometimes its hours after the door fully closes....
If the door hits the floor too hard the safety will reverse it to the open position. This can be an intermittent situation. A bad wall control or the wiring to it will also cause this problem. To eliminate them you can remove the wire from terminal #1 on the rear of the motor unit. A staple in the wire can cut through the insulation.
Jan 01, 2011 | Sears Craftsman LiftMaster Chamberlain...
MY GARAGE DOOR KEEPS OPENING AND CLOSING. AND ONE OF MY SENSORS IS ORANGE INSTEAD OF GREEN. WHAT IS THE PROBLEM?
As I have mentioned in other post, re-program travel and force limits. Make sure that travel limit (down) does not go too far (thus excessive force). Apparently this system has a force sensor that senses if there is something in the way of the door. This is different from the safety sensor "eyes". The problem in your setup is that you have programmed the door to travel down too much and he system looses its ability to use force sensor. Adjust travel limit (down) to a little less travel and you will be fine.
Oct 23, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
The garage door goes all the way down but then goes right back up - it does not close
Had similar problem. Re-program travel and force limits. Make sure that travel limit (down) does not go too far (thus excessive force). Apparently this system has a force sensor that senses if there is something in the way of the door. This is different from the safety sensor "eyes". The problem in your setup is that you have programmed the door to travel down too much and he system looses its ability to use force sensor. Adjust travel limit (down) to a little less travel and you will be fine.
Oct 22, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
The garage door keeps going up randomly. Both remotes are in the car so there are not being pushed..dont know what to do
Try to re-program travel and force limits. Make sure that travel limit (down) does not go too far (thus excessive force). Apparently this system has a force sensor that senses if there is something in the way of the door. This is different from the safety sensor "eyes". The problem in your setup may be that you have programmed the door to travel down too much and he system looses its ability to use force sensor. Adjust travel limit (down) to a little less travel and you will be fine.
Aug 14, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
Chamberlain 1/2-HP Whisper Drive Belt Drive Garage Access System Logo
2,462 people viewed this question
Top Chamberlain Building Materials Experts
Joseph Hoffmann
liveone15
Are you a Chamberlain Building Material Expert? Answer questions, earn points and help others
