Question about EliteGroup P4VMM2 Motherboard
P4VMM2 mobo lost ps 2 mouse port, first , plugged a bad dell mouse in it and bios went beep crazy, now i have lost usb 4 ports and have no way to control anything, where in the heck is that fusible resistor ? have solder gun will solder!
  • John Robertson Apr 05, 2008
    Thanks ,but thats the first thing i did , everything looks great on the front guess i will pull it out and check backside,Unfortunately things that start this way tend to go downhill in my experience, thats been my exp too, sure hate it this things a rocket, good gamer too. Appreciate ya bhiga!!!!!!!
    Scholar:
  • 119 Answers
Check for bulging/oozing capacitors on the board. If there are bulging/oozing caps, they will need to be replaced.
Also try pulling the motherboard out of the chassis entirely. You might have a short with the chassis somewhere - either an extra standoff in the wrong place, a loose screw, etc.
Unfortunately things that start this way tend to go downhill in my experience.
Posted on Apr 05, 2008
  • Brandon Higa
    Brandon Higa Apr 05, 2008
    A couple of other things to check beyond grounding problems...
    • Try resetting the CMOS config (disconnect power, pull the battery and move the jumper)
      I've had a few times where a certain set of parameters would just throw things off.
    • Check for a BIOS update (which could be a good or bad thing, depending)
    • Might be worth trying a different power supply too, if you have a known-good one on-hand. Sometimes the PSU voltages start getting wacky.
    And if all else fails, and nothing new fails on the board... Pick up a PCI USB 2.0 card. They're pretty cheap.
    I've had mixed experiences with ECS boards... most recently I had an NVIDIA-based one go really bad on me. First the RAID controller BIOS somehow got destroyed by me making simple BIOS adjustments. So I replaced the board with another unit of the same. And the same thing happened. Eventually I gave up and replaced it with a completely different motherboard. Wasn't worth of my time to figure it out (the board was really cheap - now I know why).
How can I get a mouse to work on a DELL DM061 (XP OS) from start screen?
In searching for details about your model, it may be helpful to know that the DM061 is also known as the E520
There are five things I can suggest (and they are only suggestions)
1. Restore your system to an earlier time when the mouse was working. Read this
http://support.microsoft.com/kb/306084
2. plug your mouse in and if you can do the following without your mouse
Go to Hardware>DeviceManager and navigate to the USB section at the bottom; expand this, indentify the entry which is your mouse, either update drivers, roll back (to previous driver), or uninstall driver. Disconnect your mouse and Reboot your system. When it is up, plug in your mouse again. If you uninstalled your driver you might see messages like 'Found new hardware', 'searching for drivers' and hopefully 'Your new hardware is installed and ready to use'. In any case this procedure may result in your mouse starting to work again.
3. Go to the Dell website and download mouse drivers if available, If you are using another computer, save them. You may be able to install the downloaded drivers from the media; when asked, enter the location of driver as being on the removable media that you used.
4. Try updating your BIOS from the Dell website, if such an upgrade is available. Choose the current version of BIOS if there isn't a new one. Follow Dell's procedure for updating the BIOS. (I don't really think 4. will make any difference though)
5. As a last resort, perform a system recovery (return your computer to it's 'new' state). You will lose everything on your HD if you do this, so ensure you have backed up your files.
I don't how difficult any of this is without the use of a mouse.
Good luck !
29.April.2014
Apr 29, 2014 | Dell Computers & Internet
Schematics compaq cq5210y x2
1 - PS/2 mouse port (green)
2 - PS/2 keyboard port (purple)
3 - Video Graphics Adapter port
4 - USB 2.0 ports 4
5 - RJ45 Network (LAN)
6 - Line In port (light blue)
7 - Line Out port (lime)
8 - Microphone port (pink)
Apr 10, 2014 | Dell Audio Players & Recorders
Keyboard stopped working
http://www.ascendtech.us/emachines-kb-0705-ps-2-keyboard-black_i_kbdemkb0705bps2.aspx
Things I see here.
1) The second Keyboard you plugged wasn't any good either.
2) The PS/2 port for your keyboard on your motherboard, isn't any good anymore.
Computer off, plug it into the Mouse PS/2 port, and use a USB mouse.
BIOS will reset the I/O address for that PS/2 port, and set it for the Keyboard, when the computer is turned back on.
You may have to;
A) Turn the computer off
B) Unplug from power.
C) Press the Power On button in, and hold it in for a count of 10 seconds. Let go of the Power On button. Do this same procedure two more times.
What you are doing is draining residual power, clearing CMOS Error Codes, and resetting BIOS back to the factory default settings.
Keyboard plugged in, USB mouse plugged in, plug the computer back into power. WAIT 1 minute, turn the computer on.
Still no?
Motherboard replacement.
You didn't unplug the old Keyboard, WITH the computer on, and plug the new Keyboard in, did you? It isn't a hot-swap device. The computer must be off when unplugging a mouse, or keyboard.
For additional questions please post in a Comment.
Regards,
joecoolvette
May 28, 2012 | Computers & Internet
Plz help me i want connect wire less keybroad and mouse thnksvjtawale2gmail.com
There are 4 possible ways in my awareness...
Method 1: Resynchronize your device with the receiver To resynchronize the mouse or the keyboard with the receiver, follow these steps. Note When you synchronize the mouse or the keyboard with the receiver, put the device near the receiver and put any other wireless keyboards and mouse at least 6 feet away.
  1. Press the button on the receiver, and then verify that the light on the receiver starts to blink.
    Note Some newer Microsoft devices are permanently bound to their receiver and cannot be reset. If your device does not have a button, skip to Method 2.
  2. If a dialog box appears on the screen in several seconds, follow the instructions that appear on the screen. Otherwise, go to the next step.
  3. Press and release the Connect Channel button on the bottom of the mouse or the keyboard.
  4. Check the green light on the receiver. A steady green light means the synchronization was successful. If the problem persists, try steps 1 through 4 again.
  5. For the Wireless Notebook mouse: This issue can occur if the micro-switch on the bottom of the mouse is not released. Use a pin or a pen to try to release the button if it is depressed.
The following example shows the buttons to push to synchronize a wireless hardware device:
Receiver Bottom of the mouse: The connect channel button Different kind of receiver Collapse this imageExpand this image 838398_receiver.jpg Collapse this imageExpand this image 838398_mouse_bottom.jpg Collapse this imageExpand this image 838398_portable_receiver.jpg Method 2: Try different portsTo determine whether the problem is related to the ports on the computer, use only the two cables that are included with the wireless desktop receiver, or the single cable that is included with a mouse. USB keyboard and USB mouseIf the USB cable is currently connected to a USB hub, disconnect the device from the hub, and then connect it to a USB port on the computer. If your device is already connected to a USB port on the computer, try to connect the device to a different USB port if one is available.
Note Only one USB connection to the computer is required, even if your device has two USB plugs. If the problem persists, disconnect other USB devices and connect only the USB plug from the receiver to a USB port on the computer. PS/2 devices Warning If you have to change a PS/2 connection, shut off the computer, make the changes, and then restart the computer. Do not plug a PS/2 device into the PS/2 port while the computer is running.If your devices are connected to PS/2 ports on the computer, verify that you have the following configurations:
  • Verify that the USB plug for your mouse is connected to the green USB-to-PS/2 adapter and that this adapter is plugged in the mouse PS/2 port on the computer. The mouse PS/2 port on the computer may also be green. If you are not sure which PS/2 port is the mouse PS/2 port, see the documentation that was included with the computer.
  • Verify that the USB plug for the keyboard is connected to the purple USB-to-PS/2 adapter and that this adapter is plugged in the keyboard PS/2 port on the computer. The keyboard PS/2 port on the computer may also be purple. If you are not sure which PS/2 port is the keyboard PS/2 port, see the documentation that was included with the computer.
If you have to change your configuration, shut down the computer, make the changes, and then restart the computer. If your mouse or keyboard has both USB and PS/2 connections, try using the other connection. PS/2 keyboard and USB mouseIf you are using a wireless mouse with a USB connector and a PS/2 keyboard, verify that the USB mouse is plugged in a USB port on the computer and that the purple keyboard PS/2 plug is connected to the purple PS/2 port on the computer. If you have to change the PS/2 connection, shut off the computer, make the changes, and then restart the computer. Method 3: Reinsert the batteries or install fresh batteriesBoth the wireless keyboard and the wireless mouse rely on AA alkaline batteries for power. Remove the batteries, and then insert them again. If the problem persists, install a fresh set of batteries in the device that you are having problems with. Method 4: Check for interferenceItems such as wireless routers, radios, cell phones, desktop fans, fluorescent lights, and large metal objects like computer cases and metal furniture may interfere with the signal of the keyboard. Try to keep such items away from the keyboard, and check the behavior of the keyboard.
Do not put the mouse or the receiver near any electrical devices, especially transmitters such as cordless or cellular telephones or other wireless mouse devices or receivers. A distance of at least 8 to 12 inches is recommended. Do not put the mouse or the receiver on metallic surfaces or objects, especially long metallic rails or cables. We recommend that you keep the mouse and the keyboard a minimum of 3 feet from metallic objects.
Nov 21, 2010 | Computers & Internet
Mouse can not work
this is usually do to a port going out or the total failure of the mouse.. or if it's a rather old mouse, the ball underneath is too worn to work.
if it's the port, there are 2 kinds, one is a round port (PS/2), you will have to turn off the computer to remove the mouse from this type of port.
if it id the round ps/2 port, you will have to either get a new mouse using usb, or you can try a new ps/2 based mouse.
REMEMBER you cannot plug in or remove a ps/2 mouse while the computer is still on!
The next port, and most common is the usb port. it's a small rectangle.
You most likely have atleast 4 of these on the back of your computer, and most of the newer computers have 2 on the front, sometimes in a hidden panel.
Sometimes if you are a windows user, windows will set a usb port aside for what normally resides there, and a mouse in a port that usally houses a printer usb plug will make windows not see the mouse sometimes.
Removing a usb port mouse is rather easy, you dont need to turn the computer off to do so.
Before considering replacing a usb mouse, try putting it into another usb port. sometimes this will work. also, see if the lights are working underneath when plugged in. (optic mouse, not ball mouse).
if you have determined that your mouse is broken, then the next step is to replace it. bestbuy sells mice for about 25-30 dollars.
if you dont mind waiting 3-7 business days, a reputable online retailer like 3btech.net can sell you a mouse for about 15-20 dollars, and 3btech does not charge for shipping.
usb mice can be found here:
http://3btech.net/keyboardsmice1-us.html
ps/2 mice can be found here:
http://3btech.net/keyboardsmice1-ps.html
Jun 17, 2010 | Computers & Internet
Problem in usb,netwrk port but ps\2 mouse and
The mobo probably has a fuse soldered down near the USB ports. The typical fuse is flat, about 1/8 x 1/4 inch, may be green in color, and may have a number on it. A simple continuity test will check the fuse, If the fuse is blown, check with an electronics supply house for the replacement fuse. If unable to repair, you might try a USB PCI card.
Another possibility would be a problem with BIOS. Make sure the USB is enabled in BIOS.
Feb 02, 2010 | EliteGroup 945G-M3 Motherboard
PS/2 PORT
There is nothing that can be easily replaced on a motherboard if your PS2 port has malfunctioned. Check your bios, if you have a setting labelled 'legacy mouse/keyboard support' make sure it's set to enabled. You should still be able to install windows while your keyboard is connected to the USB port. If everything checks out in your bios and you're still having this problem, it could be that you're using a USB to PS2 adapter, which causes some computers to glitch. Try another keyboard if you have one handy, it could simply be a compatibility issue with the windows installer.... rare, but I've been caught with it before.
May 05, 2009 | EliteGroup P4VXMS (P4VXMS-R) Motherboard
Mouse Doesn't Work in PS/2 port
CHECK BIOS TO MAKE SURE IT DID NOT TURN ITSELF OFF WHEN YOU PLUGGED IT INTO THE USB.BIOS MAY HAVE TURNED IT OFF TO PREVENT A CONFLICT.RICHARDM69
Dec 07, 2008 | Foxconn 6100K8MA-RS Motherboard
MS optical desktop 700
try one of the method below:
Method 1: Try different ports loadTOCNode(2, 'moreinformation'); Warning If you have to change a PS/2 connection, shut off the computer, make the changes, and then restart the computer. Do not plug a PS/2 device in the PS/2 port while the computer is running.
USB keyboard and USB mouse loadTOCNode(3, 'moreinformation'); If the USB cable is currently connected to a USB hub, disconnect the device from the hub, and then connect it to a USB port on the computer. If your device is already connected to a USB port on the computer, try to connect the device to a different USB port if one is available.
PS/2 devices loadTOCNode(3, 'moreinformation'); If your devices are connected to PS/2 ports on the computer, verify that you have the following configurations: • Verify that the USB plug for your mouse is connected to the green USB-to-PS/2 adapter and that this adapter is plugged in the mouse PS/2 port on the computer. The mouse PS/2 port on the computer may also be green. If you are not sure which PS/2 port is the mouse PS/2 port, see the documentation that came with the computer. • Verify that the USB plug for the keyboard is connected to the purple USB-to-PS/2 adapter and that this adapter is plugged in the keyboard PS/2 port on the computer. The keyboard PS/2 port on the computer may also be purple. If you are not sure which PS/2 port is the keyboard PS/2 port, see the documentation that came with the computer.If you have to change your configuration, shut off the computer, make the changes, and then restart the computer. If your mouse or keyboard has both USB and PS/2 connections, try using the other connection.
PS/2 keyboard and USB mouse loadTOCNode(3, 'moreinformation'); Verify that the USB mouse is plugged in a USB port on the computer and that the purple keyboard PS/2 plug is connected to the purple PS/2 port on the computer. If you have to change the PS/2 connection, shut off the computer, make the changes, and then restart the computer.
uparrow.gifBack to the top
Method 2: Install fresh batteries loadTOCNode(2, 'moreinformation'); Both the wireless keyboard and the wireless mouse rely on AA alkaline batteries for power. If the problem persists, install a fresh set of batteries in the device that you are experiencing problems with.
Method 3: Resynchronize your device to the receiver loadTOCNode(2, 'moreinformation'); To resynchronize the mouse or keyboard to the receiver, follow these steps.
Note When you synchronize the mouse or the keyboard with the receiver, put the device near the receiver and put other wireless keyboards and mouse more than six feet away. 1. Press the button on the receiver, and then verify that the light on the receiver starts to blink. 2. If a dialog box appears on the screen in several seconds, follow the instructions that appear on the screen.
Otherwise, go to the next step. 3. Press and release the Connect Channel button on the bottom of your mouse or keyboard. 4. Check the green light on the receiver. A steady green light means the synchronization was successful. If the problem persists, try steps 1 through 4 again.
Method 4: Install the latest software loadTOCNode(2, 'moreinformation'); If you are troubleshooting a wireless mouse, download and install the latest Microsoft IntelliPoint software. For more information about IntelliPoint software, visit the following Microsoft Web site:
http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx (http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx) If you are troubleshooting a wireless keyboard, download and install the latest Microsoft IntelliType software. For more information about IntelliType software, visit the following Microsoft Web site:
http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx (http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx) uparrow.gifBack to the top
Method 5: Clean the mouse lens loadTOCNode(2, 'moreinformation'); This problem may occur if you are using an optical or laser mouse and the lens on the mouse is dirty. To clean the lens of an optical or laser mouse, follow these steps: 1. Use a dry cloth to clean the bottom surface of the mouse. 2. Check to see whether the mouse functions correctly. 3. If you see dust on the bottom of the mouse, use a can of pressurized de-ionized air to blow away the dust on the lens. 4. Check to see whether the mouse functions correctly. 5. If the pressurized air canister is not available, blow dry air on the lenses by using your mouth one or two times. 6. Check to see whether the mouse functions correctly. 7. If these steps do not resolve the problem, use a cotton bud to clean the lens without scratching it.
Sep 18, 2008 | Microsoft Wireless Optical Desktop Comfort...
Wireless keyboard
wireless keyboards and in wireless mouse devices, use the following methods in the order that they appear in.
Mar 02, 2008 | Sakar 62150 Keyboard
EliteGroup P4VMM2 Motherboard Logo
70 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
