Question about JVC THD-50 System
Set up I cannot set up my new system. I have star choice, VCR, Tape Deck, DVD with my new JVC system. Do I need a HDMI cable? How and where do I hook all these plugs. Can I add other speakers to this system, and how? Do I connect the white, yellow, and red plugs to the receiver, satille or the t.v.? Please help after many trys and hours.
    Scholar:
  • 119 Answers
The red and white plugs are audio - they should go to one of the receiver's inputs.
The yellow plug is composite video - if your receiver has a yellow jack, plug it into the receiver (this will let you switch inputs from the receiver), if not, plug it into your TV.
Same goes for your tape deck, though it won't have a video output.
Posted on Apr 05, 2008
SOURCE:
How to conect a equalizer sh-ge70 to a receiver hdmi
Any equalizer I have seen can be hooked to the tape loop of a receiver and then any tape deck displaced from that loop if one was plugged in will be hooked to the tape loo[p on the equalizer.
This is a very simple process and one that is often given in the owners manual of the equalizer involved.
Sep 25, 2013 | JVC TD-W118 Single Cassette Deck
Vcr tape . does not record to dvd-r disc Using hdmi cable from TV to recorder.
It is a HDMI OUT on the DVD/VCR Recorder.
You can only record to a DVD/VCR from the External DVD/VCR Input (Connected to a Freeview, Cable or Satellite Box etc) or from one to the other.
Jun 09, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
I have free cable at where I live now and hooked up my tv to the cable but now I don't know how to hook up my vcr player and my dvd player to my tv so I can tape my soap opera & watch dvd's. ...
What tv do you have? Whant model? DVD player and VCR can hook up to your tv in many different ways via HDMI, S-video, Component and Audio/Video cable.
May 07, 2011 | Televison & Video
When I hook the HDMI cable to the tv and put the dvd player on the setting for 1080p I get no picture but when I put it on 480p it works fine. What do I need to do to make the dvd player to play the 1080p?
you can only upscale through a good amp.set the dvd player to auto.how old is the tv?are you playing a new release?is the HDMI cable compatible with 1080 1.3b?
Jul 11, 2010 | JVC TH-G30 Theater System
BEST CONNECTION FOR TAPE PLAY ON HDTV. VCR HAS BOTH HDMI AND S-VIDEO PORTS PLUS THE STANDARD A/V PORTS
Use the HDMI cable to hook up the DVD/VCR combo.Use the HDMI ports and cables,best result for the new format HD Movies,Tv's shows.Less clotters too.
Mar 20, 2010 | Televison & Video
I want to hook up a higth def. cable box to asoround sound jvcTH-M505 with no hdmi,( the cable box does have it )and a samsung 46 in series 6 model 610 lcd. I can get soround sound from the movies from the...
There are a couple of different ways you can do this but this is the easiest.
Items needed - One set of RCA audio cables (Red/White)
1) On the back of your TV there should be RCA plugs marked as "Audio Out". Connect the RCA cable to these connections Red cable to Red connector and White cable to White connector.
2) Locate on the back of the surround sound system the connections marked "Audio in (VCR)". Connect the other end of the RCA cable to this connection Red cable to Red Connector and White cable to White connector.
Now to get the sound to play press the "VCR" button on the surround remote and you should get the cable box sound on the surround system.
Good Luck.....
Jan 19, 2010 | JVC TH-M505 System
Tv/digital converter box & vcr-dvd hook-up
ok cable sat wire goes into input of dvd-vcr input then coming out from the dvd vcr and into the moulator then a wire out to the tv now make sure your vcr is set to the right setting ...now you can record 1 cable..2.vcr dvd..3 modulator...4...tv make sure vcr is set to monitor
Dec 04, 2008 | Philips Magnavox DVD/VCR Dual Player
Setting up Unit
I called the JVC tech service rep. I went from the Cable box to the JVC unit with a Digital Optical Cable, from dvd/vcr player to jvc unit with a Composite Cable and Audio Cables. From cable box to tv with hdmi cable and from jvc unit to tv with componet cables and cable box to dvd/vcr with Audio/ Video and S-Video cables. This allows me to have the cable TV access and Surround sound in all mode. I have HD and Digital surround sound in three diiferent modes. Everything is working great.
Thanks for the opportunity for help just the same.
Sincerely, cthomas249
Sep 25, 2008 | JVC THD-50 System
Video channel
if your DVD player supports a HDMI cable a single cable is enough for both audio and video channel.
but both your player and TV must support HDMI.
Aug 12, 2008 | Samsung DVD-V4600 DVD Player/VCR
JVC THD-50 System Logo
69 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
