Question about Denon AVR-2801 Receiver
Video performance question
What kind of 'video' performance will I have if I upgrade to a hi end dvd player since my Denon lacks an HDMI connection, yet it has an optical in jack for audio? Can I connect the DVD player directly to my plasma tv via HDMI and then connect from the dvd players optical out to my Denons input?
    Scholar:
  • 119 Answers
The 2801 (I used to have a 2803) is just an AV receiver, so it doesn't do any video processing.
If you get a DVD player with HDMI or DVI output, you'll be better off doing what you said - bypass the receiver for video and connecting the video directly to your TV, and the audio to your receiver.
It makes things less convenient since you can't switch inputs only with the receiver's remote, but you'll get a much better picture.
If you really need to control the whole system with a single remote, consider getting a Logitech Harmony remote or something similar. They're very convenient.
Posted on Apr 05, 2008
Denon AVR-4806 HDMI problem
Check which port you have the HDMI cable connected to, then go into the menu on the TV, look for it on screen and Enable it .
Good luck
Nov 16, 2013 | Denon AVR-4800 Receiver
I have a new Denon AVR 1911 receiver all hooked up to my input devices and output thru a single HDMI cable to my Samsung LCD tv.... problem with getting audio from my DVD player: my DVD player is older...
Not likely that all those things are faulty.
The TV and DVD player make and model would be helpful to know. I would recommend running its BEST digital audio to the receiver and its stereo analog audio to the TV just in case you want to watch and hear the DVD in a lo-fi setting without the Denon. I generally advocate for connecting anything high-end (audio or video) ONLY to equipment that can use it or enhance it. Otherwise you may just be wasting expensive cable and adding unnecessary hops and connections that can fail.
Why do you want the audio to go from the DVD to the TV through the Denon? Are there no speakers on the Denon? Modern TV's have lots of inputs for the flexibility I recommend but rarely have decent audio or speakers.
May 06, 2011 | Audio Players & Recorders
I want to connect my denon 790 to my 5:1 surround, HDMI DVD player and HD samsung 55'' LCD. what cables do i need and where to put them. thanks
You will need 1 HDMI cable to link between your DVD player and the Denon,plug the HDMI cord into the HDMI port on the back of your DVD player and the the other end into the Denon 790 HDMI port labeled DVD,then you will need another HDMI cord to go between the Denon and your LCD TV,plug one end of the HDMI cord into the Denon 790 HDMI port labeled HDMI monitor out and the other end into one of the HDMI ports on the back of your TV, it doesn't matter which one you use, just remember that you will have to change the input on the tv to that specific HDMI port when you play back a DVD and you will also have to change the Denon to DVD as your source to send the audio through the Denon to your surround sound speakers.( The Denon owners manual will help!!)
Nov 26, 2009 | Audio Players & Recorders
Denon AVR-488 , problems routing cable box through receiver to tv
If you don't have one, the manual is available online: http://static.highspeedbackbone.net/pdf/AVR-488-OM-E_101.pdf
Suggestions:
1. Reset to default values. Per page 36 of manual: 1. Turn off Power. 2. Press Power while simultaneously pressing Speaker A and Speaker B. 3. Once the display starts flashing at intervals of about 1 second, release the two buttons.
2. Make sure you have AM or FM radio reception. This makes sure your speakers, amps, etc are connected and working correctly.
3. Connect DVD player to HDMI 1 in and TV to HDMI Monitor Out.
Play a known good DVD that works when you connected the DVD directly to the TV via HDMI.
Select the DVD/HDP input on the receiver and play the DVD. You should not have to perform any input assignments, etc. It should just work, as HDMI1 is the default system setting for DVD.
4. If possible, obtain a STB with HDMI out & repeat step 3 using the HDMI2 TV/CBL input. Keeping the signal path all digital (HDMI) will give you a better picture quality than forcing several analog to digital conversions (component video is analog).
4A. To use the component connection, first test by connecting the STB directly to the TV via component video/audio if possible. This tests that the component video output of the STB is working correctly.
Next, remove direct connection and connect via receiver. Connect STB to receiver as shown on page 13 in manual. Connect component video output from STB to component video input #2 (tv/cbl) on receiver. Connect the STB audio output to the corresponding tv/cbl audio inputs.
Make sure nothing is connected to the HDMI2 input or to any other TV/CBL inputs (composite video, s-video, digital coax audio).
Now select the TV/CBL input and turn on the STB. You should have both audio & video.
Mar 08, 2017 | Electronics - Others
No video
The Denon does not down scale you can not plug a DVD or other device in to the Denon using HDMI and have it come out Component, if your projector only has Component video inputs you must use Component video connections from the DVD and Cable box to the Denon
Jan 02, 2009 | Denon AVR-3805 Receiver
How to connect BLU-RAY DVD player to Pioneer Plasma TV via HDMI
The best possible solution to your problem is :
Connect your blu ray player directly to the HDMI input of you Plasma and watch HD video....
and connect the 5.1/7.1 sound thru the optical or the coaxial link directly to your AVR 3805.
You will not loose anything on the Blu-Ray.
The sound is best processsed by the AVR3805, while the video, which is the real upgrade (BluRay) in terms of resolution of picture would be processed by your plasma.
Connect and Enjoy
Dec 16, 2008 | Denon AVR-3805 Receiver
Hi' I have a Denon 3910 that is connected to an Infocus Projector via HDMI out on the Denon to DVI on the Infocus(One end of the lead is HDMI the other DVI) .problem has always been without the projector...
You can try this reset method, if it doesn't work it will probably need service by a professional. Remeber that all setting will be lost, make sure you know them so you can put them back in after you are finished.
At the player stop condition,
press 3 buttons for DVD operation
(“PLAY”,”OPEN/CLOSE”, and “ SKIP”) until
“INITIALIZE” appears and disappears in the display.
(“Initialized” appears and disappears on the TV screen.)
******All user setting will be lost and its factory setting will be
restored when this initialization is made. Be sure to memorize
your setting for restoring again after the initialization
Jul 03, 2008 | Denon Audio Players & Recorders
HDMI connection???
Hi Greg,
Again, if you have a high definition dish box with HDMI output,and a dvd player with HDMI output,please connect them both directly to your TV HDMI inputs.
When watching TV(dishnetwork box).remember to switch the HDMI video inputs.
Same as your DVD player,you need to switch it under your TV video input.
solutiondoct
May 28, 2008 | Denon AVR-2807 Receiver
BenQ FP241W 24" inch problem with HDMI connection
Sounds like the HDMI port on the monitor has been shorted out.
There are very small fuses on the video board that can be changed, but they are fiddly and you may end up doing more harm then good if you are not sure what your doing.
The fuses are actually soldered to the board...it's not a case of pop one out and pop one in like the glass type.
Hope it helps =)
Jan 15, 2008 | BenQ FP731 17" LCD Monitor
Denon AVR-2801 Receiver Logo
148 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
