Question about Dell A940 All-In-One InkJet Printer
Hardware error:0502 sir, I am using Dell AIO Printer A940 for one year.Its show best performance.but two days above printer show on screen (HARDWARE ERROR:0502).and computer no detect printer. when I press power batton printer on and show error:0502.when i open the cover cortridges not moves.but when i shut the cover cartridge is not move. please Resolve this problem. Thank you. Dell AIO Printer A940 service tage:htsnj21 express service code:38806945849 E-mail:starlight_200046yahoo.com
  • 8 more comments
  • Anonymous Jun 18, 2008
    Printer stops after printing one page in multi-page document and posts the foregoing error message: hardward error 0502. Please provide meaning of the message and solution of the problem.
  • Anonymous Dec 07, 2008
    what does the encoder strip attach to?
  • Laurie Caldwell Dec 18, 2008
    i have had my printer for quite a while and I just tried the cleaning recommendation. When I turn it back on it gives a loud snapping sound and then still show the error. Any suggestions?
    I tried the cleaning recommendations and when I turn it back on it gives a loud snapping sound and then show the same error.
  • kermitconnec Dec 27, 2008
    I have the same problem, but I've worked with it for hours, now the ink cartridges won't move and they're under the right side of the printer. I just put in new cartridges and the black one says it's the right one, by number, but it is smaller than the last one--ordered and obtained from Dell.....
  • Anonymous Jan 07, 2009
    I have the same problem. Dell printer is not working. It claims hardware error 0502 and I've unplugged everything and turned it off and rebooted. Problem still exists. Any ideas of what to do next? thanks!
  • Anonymous Jan 10, 2009
    After scaning I got the hardware error 0502 notice the next time I went to use my printer
  • jfegan Jan 17, 2009
    I've done the above repositioning of the encoder strip but the error code does not go away.
  • si75 May 25, 2009
    same problem
  • mooreme1 May 11, 2010
    Dear damanpreet_c:
    I am an idiot when it comes to anything mechanical. I have attempted to follow your directions; however, am still receiveing Hardware Error 0502. Perhaps the Endcoder strip is still out of place? (I am not clear as to what 'in place' exactly looks like.) When the printer cover is lifted (as if to place document on the glass for printing) and the Power button is touched to turn on the printer, the black bar on to the right of the screen does not move across. Can you offer additional direction.
    I am attempting to install refilled Dell cartidges. The printer has not been used for greater than a year.
    My thanks for your assistance.
    Mary Elizabeth
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 69 Answers
1. Ink cartridges lids are open which is not allowing cartridges to move freely.
2. Ink cartridges carriage will not move from its original position(left) when front cover is opened
3. Encoder strip is Dirty.
4. Encoder strip is Out of position.
Solution:
1. Open the front cover and check if ink cartridges lids are properly snapped in.
2. Turn the printer off and pull out the power cable from power socket, open the front cover and manually center the ink cartridges carriage.
Clean the metallic rod inside the printer using WD40 or Kleenex from Left corner to right corner properly.
3. Cleaning the encoder strip:
a. printer should be off and disconnected from power.
b. open the front cover.
c. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer and you can move the cartridges carriage to clean the strip completely.
d. Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
e. Close the printer and try again to print.
4. Repositioning the Encoder strip.
a. Remove the power cord from the printer.
b. Open the front cover.
c. Gently slide the ink cartridge carrier to the middle of the printer.
d. Gently move the top part of the printer belt to the right.
e. Using an index finger, gently push encoder strip down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
f. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
g. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
h. Once the encoder strip has been re-seated, close the scanner lid.
i. Re-connect the power cord to the printer and try again to print.
Incorrect position of encoder strip
hardware error:0502 - 564e52e.gif
Correct position of Encoder strip
Hope it should fix the issue.
Posted on Nov 07, 2008
Receiving hardware error 0502 on my A940 printer
Please use this link to fix -
DELL fix for 0502 error code
as DELL have provided detailed instructions on how to fix this one.
Jan 27, 2011 | Dell A940 All-In-One InkJet Printer
Dell AIO A940 is giving me an error code 0502 and won't print. Says it is busy?
Check this out for the error. The trick here is to make sure the bar is cleaned and lubricated with furniture polish or cooking oil.
http://blog.forret.com/2006/02/lexmark-printers-with-hardware-error-0502/
May 24, 2010 | Dell A940 All-In-One InkJet Printer
My dell a940 printer has a 0502 error how do i fix it
Hi Remcountrybo,
You can fix this by following the instructions given in the following link.
Fix Error 0502 in A940 All In One InkJet.
-Rate if it helped you.
Apr 10, 2010 | Dell A940 All-In-One InkJet Printer
What is a Hardware Error 0502 displayed on an
Hi there
On the multi function machine seems to be a coating on the metal rod that the cartridges travel on. Just wipe this rod with a Kleenex and the problem seems to go away.
Somehow it presents a drag on the cartridges and causes an error.
Myself I would put a little bit of oil after on a cloth and wipe along the bar.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Jan 15, 2010 | Dell A940 All-In-One InkJet Printer
Hi: my name is Roland I have a dell a10 error 0502
Hi there
Hope this will do the trick
Nov 19, 2009 | Dell A940 All-In-One InkJet Printer
Wont finish print job hardware error 0502????
I found this:
Hope it helps!
Mar 28, 2009 | Dell A940 All-In-One InkJet Printer
Dell all in one printer 940
try holding the power down for 15 seconds
Mar 06, 2008 | Dell A940 All-In-One InkJet Printer
Dell A940 All-In-One InkJet Printer Logo
1,324 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
