Question about Linksys Wireless-G WRT54G Router
Wrt54g wireless router problems
I just bought this router and the wizard is having problems finding the router. Is there a firewall blocking it or what else could be the problem?
    Scholar:
  • 119 Answers
  1. Shut down your PC.
  2. Connect your PC directly to one of the router's LAN ports via an Ethernet cable.
  3. Unplug the power to the router.
  4. While holding down the reset button on the router, plug the power for the router back in and continue to hold the reset button for 30 seconds, then release the Reset button. This should reset the router to factory defaults.
  5. Turn on your PC. If your network adapter is not set to Automatically obtain IP address, set it to do so (this is usually the default).
  6. Open your web browser and browse to http://192.168.1.1/ if that doesn't work, try http://192.168.0.1/
That should get you to the web setup page.
Posted on Apr 05, 2008
  • 35 Answers
Firewall cannot block internal connections.i think you have set-up a secured connection.
refer to this user guide to know how to set-up normal connection.
SOURCE:
Recently my router is blocking any connection to secure server such as a http
http is neither secure, nor a server. it is an unsecure protocol (hypertext transfer protocol). perhaps you meant https? your router will have a setting to allow you to block certain protocols. find your router admin page (a 192 ip address - depends on the brand) and look for protocol settings (probably in Firewall settings).
Nov 29, 2011 | Linksys Wireless-G WRT54G Router
Trying to run setup wizard on my WRT54G-TM,so i can block other people from borrowing my internet.I have one desk top hooked up and two laptops, works great ,but when i run the wizard disk it tells me...
To test your Internet connection, connect a LAN cable from your computer to the DSL or cable modem and if you can browser the Internet then your Internet connection is OK, then the problem is the LAN cnnection to the Linksys or the Linksys may not configured correctly.
Connect a LAN cable from the D-Link to your laptop/computer'sLAN port, open the browser on your laptop/computer and enter the D-Link'sconfiguration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jul 21, 2011 | Linksys WRT54G-TM Wireless Router
I just bought a laptop with Windows 7. I have a
hi,
for you to be able to configure the modem to the router,you will need to set the modem to bridge mode first for you to be able to give way for the router,try to contact verizon and let them bridge the modem then right after that,thats the time you will configure the router
thanks and God Bless
Jun 26, 2010 | Linksys Wireless-G WRT54G Router
I cannot print over wireless connection. I am using the Linksys WRT54G. I am trying to print from my laptop to my HP LaserJet 1320 PCL 6 printer. I cannot see the printer from my laptop. I am using AVG...
Disable your firewall on that computer where you shared your printer.
After that check firewall settings to allow printing from the network.
Your router working ok.
Feb 28, 2010 | Linksys Wireless-G WRT54G Router
I need to download the setup software for a Linksys WRT54G and cant find it online.
There's no need to download any software.
Use an Ethernet cable to connect your computer to one of the LAN ports on the router.
Click Start
Click Run
Type CMD and press ENTER.
Type IPCONFIG and press ENTER.
Look for a line of output like:
Default Gateway . . . . . . . . . : 14.64.1.1
Start Internet Explorer.
Type http://14.64.1.1
to connect to the web-server "inside" the router.
Click to run the "network setup wizard"
Later, click to run the "wireless network wizard".
Disconnect the Ethernet cable, and have your computer "view available wireless networks" -- you should now be able to "connect" wirelessly to your router.
Nov 19, 2009 | Linksys Wireless-G WRT54G Router
Connecting a brother hl2170 wirless printer to a linksys wrt54g
Take note all the wireless settings of the router first. Now go to the printer and Press Menu/Settings, look for wireless setup wizard. It should find the network, highlight it and connect. If it asks you for the network key, type your wireless network key. It only allows WPA-Personal(TKIP) and WEP. If you have WPA2 or AES, it will not connect
Sep 23, 2009 | Linksys Wireless-G WRT54G Router
LimeWire
If the firewall is turned on you router you will have to turn off the ports that LimeWire uses.
Aug 04, 2008 | Linksys Wireless-G WRT54G Router
My laptop won't work wireless
Use windows network setup wizard to help in setting up your wireless. The wizard can search for your wireless. Some people believe you gan get away without using Linksys's software & I agree to a point. However Linksys believes to maintain a good connection you should install the software for the wireless router. You can download it from the link below. Check out the link "Learning Center". You might find it helpful. http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1166859837401&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=3740137401B343
I suggest to all running a wireless connection to set up security with a password to keep freeloaders from tapping into your bandwith for free.
Luck!
Please vote...
Jan 23, 2008 | Linksys Wireless-G WRT54G Router
Open a port for a certain program
hi mike,
this router has its own firewall, although i don't think its a good idea to turn off the firewall
google the port that limewire uses and then use portforwarding on the router.
you can start by turning off the firewall on the router to see if it works. if it does then perrhaps just allow limewire to passthrough your firewall at the router.
good luck
smeags
Dec 31, 2007 | Linksys Wireless-G WRT54G Router
WAN requests
The feature you are referring to "Block Wan Requests" is either enabled or disabled In the pane to the right, where there are 4 subcategories to "Block Wan Requests", Block Anonymous, Filter Multicast, Filter NAT, and Filter IDENT. These 4 subcategories are your choices for blocking WAN requests. They can be either enabled, or disabled.
Nov 25, 2007 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G WRT54G Router Logo
52 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
