Question about Maxtor OneTouch III Mini Edition (R01E100) 100 GB USB 2.0 Hard Drive
Hard drive not being detected
The hard drive fel down from a table of 3 ft height.The power supply is on but the hard drive is not being recognized.the hard disk does not seem to be rotating.Pls advise if the problem can be fixed as there is highly important data in the disk
  • 2 more comments
  • maxtor help Apr 05, 2008
    Thanks for the reply.Is it possible to fix a broken circuitboard and will there be any loss of data?
  • janak_ofw Apr 28, 2008
    hi my name is janak.when i going to attach my external maxtor 160GB hard disc. It shows that its connected but i cant find location. My friend taken my disc to use it and unfortunately he did format. I am facing this problem now.What should i Do?
  • asfourn41 Dec 17, 2008
    the harddisk falldown short distance light is continuously on but cannot be recognized by the compuoter
  • pokonei06 Feb 16, 2009
    when attaching my maxtorOneTouch III mini on the USB port it gave the sound as if it was attached but couldn't find it
  • 98 Answers
It's possible the circuitboard inside is broken.
Posted on Apr 05, 2008
  • Dave Thompson
    Dave Thompson Apr 06, 2008
    I think your best option would be: external harddrive cases are available on ebay, electronic depart. store, etc...
    Open the case up in that one and transfer the harddrive inside to another case. Some cases have visible screws and are easy to get into.
    If you go this route, I can walk you thru how to do it, if you get stuck.
    Circuitboards are not made by hand anymore and have really tiny components, so they are harder to troubleshoot.
  • Dave Thompson
    Dave Thompson Apr 10, 2008
    You will not lose any data going this route.
If one container has a capacity of 6000 gallons, compute for the radius if its height measures 5.50 yard.
Ha ha ha... this is for your High School class? V = 6000 gal * (1 ft^3 / 7.481 gal) = 802 ft^3..... h = 5.5 yd * (3 ft / 1 yd) = 16.5 ft..... Assuming a cylinder, V = pi * r^2 * h... r = (V / pi h)^0.5 = 15.5 ft * (1 yd / 3 ft) = 5.16 yd
Jul 18, 2011 | Computers & Internet
I have a seagate freeagent go 500 GB drive. It fallen on ground (from one Ft. height). when i connected it now it's light is flashing continously and it's not recognized by system. upon connecting...
Hi'' so sorry for you , yes hard disk are so delicate when it fall , a fragile hardware even with just a little bang on tables or to a hard things the next is it would be damage , so here is another way to check on how to see back your files on the 500gb HHD you dropped,i hope this can help you, Open and connect to an unplug pc, if your 500gb HDD is a sata connection use the sata wire to connect hard disk directly to a PC mother board , insert the sata wire to a Sata port and put a supply on the disk , but be sure your disk is placed on top of box or books just to make sure it would not make any short circuits and then start power on, this is very risky work ,a professional technician is recommended to work it out .
Jul 16, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My Dell Latitude E6400 do not detect the Hitachi XL 1000 external disc
Several things could be happening here:
1. your electronic controller in the hard case has failed.
2. you didn't properly disconnect the external hard drive in Windows > with the
"Safely Remove Hard ware and eject Media" in the task bar.
3. if you have a power supply to the USB drive it may have a damaged power connector or not supply proper power to the device.
4. the drive may not be supported by the motherboard for your PC.
5. check the user manual for you PC to see if it is compatible with your device.
Mar 18, 2011 | Hitachi 1TB External USB 2.0 Hard Drive
My Transcend StoreJet 500GB cannot be opened
Mar 16, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
Shut down windows but power supply still alive
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to fail to detect a hard drive continue on a cycle or to shutdown
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA and
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
problems
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Dec 13, 2010 | EliteGroup P4M890TM2 (V1.0B) Motherboard
Computer shuts down. Sometimes powers back up. Sometimes won't
problems
hope this helps
Dec 10, 2010 | Hi-Pro (HPP303W) 300-Watt Power Supply
Error message E02
Ricoh Priport VT-2100/2130/2150/2300/2500/6000
E 01 Malfunction in cutter section: The cutter motor does not reach both right and left cutter position detecting switches within 2 seconds 1) Drive wire cut
2) Drive section malfunction
3) No power supply E 02 Malfunction in the paper table drive section: The lower limit sensor or the paper table height sensor is not turned off even though the paper table UP or Down signal is applied 1) Drive worm gear broken
2) Mounting screw of the worm gear broken
3) No power supply
Apr 01, 2010 | Ricoh Priport VT6000 Copier
Hard drive
Make sure your jumpers on your hard drive are properly set. Also, test another cable to rule out that your IDE cable hasn't faulted. You can also go into your bios settings on startup and check to make your hard drive is detected, if not run the auto detection and see if it is seen then.
Nov 18, 2008 | Dell Dimension 8400 power supply ** FREE...
Maxtor OneTouch III Mini Edition (R01E100) 100 GB USB 2.0 Hard Drive Logo
229 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
