Computers & Internet Logo
Posted on Apr 05, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Display is completely upside down
My screen display is upside down. How do I fix this?
Anonymous
Level 1:
Problem Solver:
  • Contributor 16 Answers
  • Posted on Dec 15, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
16
Questions
0
Helped
7558
Points
30
You can often press CTRL + ALT + UP/DOWN to rotate the screen if you have an integrated Intel Graphics card. Or it could be CTRL + SHIFT + UP/DOWN. One or the other.
Brandon Higa
Level 2:
Scholar:
  • Expert 119 Answers
  • Posted on Apr 05, 2008
Brandon Higa
Expert
Level 2:
Scholar:
Answers
119
Questions
0
Helped
59268
Points
218
Try connecting it to a different computer. If it's upside-down on another computer, then the panel is probably mounted upside-down. If it can be removed from the stand, remove it and see if it can be mounted the other way.
If it's correct on another computer, then your graphics settings are incorrect. Assuming you're running Windows, go to Display Properties, Settings tab, click Advanced button, look for a tab describing your video adapter (usually ATI or NVIDIA). In the video adapter's setup there is usually a Rotation option. The rotation option may be set to 180-degrees instead of Normal or 0-degrees.
2 Related Answers
Anonymous
  • Posted on Mar 31, 2009
SOURCE: hyundai flat screen monitor upside down display help?
There are 4 screws on the back that connect the monitor to the stand. Remove them and turn the monitor right side up and replace the screws tightly. OR you can change your layout in your video card settings.
krbshg
Banjade
  • 430 Answers
  • Posted on Aug 02, 2012
SOURCE: headrest monitor display is upside down
here are the steps how you can control your screen.
Image rotation is enabled by default and is activated by the default key combination <Ctrl> + <Alt> + <F1>.
Once it is activated, you can rotate the display with the additional "Hot Keys":
<Ctrl> + <Alt> + <Right Arrow>
<Ctrl> + <Alt> + <Down Arrow>
<Ctrl> + <Alt> + <Left Arrow>
<Ctrl> + <Alt> + <Up Arrow>
To disable this Hot Key Feature, remove the check from the Enable Hot Keys selection box in the Extended Graphics properties.
3answers
How do I fix display show upside down. TCL LED TV Model: L24T2100
http://www.tomsguide.com/answers/id-1989729/picture-flipped-upside-fix.html
1helpful
The world is upside down, the king has lost his crown, don't laugh please, my monitor screen suddenly got upside down.
Rotating the screen image is a feature of the graphics card and is normally caused by accidentally pressing a combination of keys. To correct it, hold down Ctrl and Alt and press one of the four arrow keys (up, down, left or right) until you have it the correct way up.
As your screen is completely upside down, hold down Ctrl and Alt and press the Up arrow key.
Alternatively, you probably have a Rotation setting in the display properties of the graphics card. You should be able to reach your graphic card settings, but reading and setting them properly may be difficult since everything you see on the screen is upside down until it's fixed.
If all else fails, try restoring the system to an earlier date when the display was right. This will reset the driver to its proper orientation.
Upside down screen
Go to your control panel and then the Mfr display panel configuration settings - Find and click on "Restore Defaults " or just change the rotation back to upright if you like the other changes you previously made.
3answers
My aspire screen is upside down and the picutures are also upside down. How can I fix it?
click start control panel administrive tools computer management device manager scoll to ports(com&lpt)right click to scan for hardware changes or scroll to monitors + to expand plug and play monitor right click where you have options to update driver,disable.uninstall,scan for hardware changes or select properties where in the general you have the option to troubleshoot also in the driver tab you have the same options as when you first right click on monitor
also
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
5helpful
C905 reversed upside down screen
I have a Sony Ericsson c905 phone and the screen is perfect, but upside down on all applications. Otherwise the phone operates normally. How can I fix this?
I open my phone and my screen was upside down, and it wont go back. What can i do to fix it?
See your Display Settings. Try changing it to different displays and see if that helps any.
Good luck
7helpful
3answers
Sony handycam dcr-sr40 lcd display
flip switch is not working or stucked, a loose wire connected to this switch is also possible. you may open the unit and check for it. a pro fix is better.
Grand Canyon Tech
Grand Canyon Tech
