It wont print off my computer its telling me that i have to work off line
  • alicialane26 Apr 05, 2008
    lexmark 5400 series all in one
    Genius:
  • 2,785 Answers
Switch off your printer.then open faxes and printer from all programme.double click your printer then the printer dialog box will appear just cancel all doucment and disable properties and cancell all documents.then you switch on your printer.from the same dialog box you click on printer tab and remove the tick mark from work printer offline.
If the problem is not solved then restart your pc and check if the problem is solved.if not then reinstall the drivers again.
If you need help please post your problem
Posted on Apr 05, 2008
When I print I only get a line of garmage at the top of the page - i've tried rebooting, etc.
Have you printed a test page without it pluggetd to the computer? What did you get.
Try telling the computer it is a HP Laser jet II
Then print a test page, tell me what you get.
Only put a couple pieces of paper in it just incase it goes nuts.
Feb 12, 2010 | HP LaserJet 1300 Printer
Light is flashing and wont print
You dont give much info - I hope your expectation is the same with the answer you get.
Id check the driver for what ever printer you have hooked up to whaat ever computer you have. It might be that the print que is full or the printer is off line ... hard to tell with this scant bit of informaiton.
If you want to try again, I will try again as well.
Good questions get good answers
Thanks for using fixya.com
a
Oct 24, 2009 | Office Equipment & Supplies
Computer tells printer to print but printer wont print
Sir,
When u are inserted new catridge. it will gives one print. then follow the instruction on the printed sheet. Scan it again then u r catridge will set for Printing.
Enjoy..
Sep 19, 2009 | HP PSC 1210 All-In-One InkJet Printer
7310 wont print
u have to clear the sent job, go to printers and faxes through your start menu, if u cant find it there, go to control panel, double click on the printer and faxes icon, on the pop up window, double click to open the printer then select all the jobs and empty the box, then you can start using again, make sure the printer is off while doing that.
Jul 17, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Printer wont print after ink cartridge change
Hi pater_g:
Have you tried to reinstall the old cartidge to see if it would give a different problem ( light print ect.) if not try that. If the problem stays and you just can't communicate with the printer try rebooting you computer or go to www.hp.com/support to download a new print driver. I hope this helps you.
Apr 17, 2009 | HP LaserJet 1320n Printer
Epson Stylus dx4400 Printer printing in pink
have you tried nozzle check? it should tell you that the inks are not printing correctly it will print on a pattern of lines if there are gaps and breaks on the lines it means that you have to clean the heads. check on your manual how to do it. what is your operating system on your computer? Windows or Mac?
Feb 10, 2009 | Epson Stylus CX4200 All-In-One InkJet...
Will not Print
Try a hardware check of the printer first. To check the hardware of the printer, do the following:
  1. Switch off the printer.
  2. Load one sheet of paper into the paper feeder.
  3. Press the Power button and the Paper Feed button at the same time and hold them both down for three seconds. Then release the Power button only.
  4. When the printer begins to print, release the Paper Feed button. A page will be printed. The page should contain some text at the top and a series of horizontal color lines (cyan, magenta and yellow) below the text, with a thick black line below the colored lines. All the lines should be solid.
  5. When the test is complete, switch off the printer. NOTE: If you do not switch off the printer, it will continue to print.
Sep 24, 2008 | Lexmark X1270 All-In-One InkJet Printer
110 people viewed this question
k24674
