I have a whirlpool front load washing machine model WFW8300SW00
Sir, I had a repairman come out and the pump is working fine....he said to replace the microcomputer and the pressure switch...does this make sense? Again the pump works fine and I don't know why I get a F21 fault.
Sir, I tried these steps...the water drains out of my washer when I fill it up with a garden hose. Also, I back filled the drain line and it was clean and drained? Now what? I have a F21 code/add a garment on my front loading whirhpool washing machine model wfw8300sw00 ser# hlt1682794. I checked the cold & hot water hoses...they were good and no kinks. I checked the drain line...I filled the washer and the water drained out. I back filled the drain line and it was clear. I reset the outside breaker and unplugged the washer overnight....nothing seems to work. I tried different cycles and settings...the same thing code comes up F21/add a garment. thanks in advance
Original Problem Dear Madam/Sir, Thank you for your recent inquiry (#1493340), sent on 3/22/08 at 9:57 pm, regarding your 2006 Whirlpool Washing Machine, model: wfw8300sw00. F21 LONG DRAIN If the drain time exceeds 8 minutes the water valves turn off. NOTES: ¦ After 4 minutes the “Sd” error will be displayed, then 4 minutes later the “F/21” error code will be displayed. ¦ Press PAUSE/CANCEL two times to clear the display. Possible Causes/Procedure 1. Check the drain hose and make sure it is not plugged or kinked. 2. Unplug washer or disconnect power. 3. Check the electrical connections at the pump and make sure the pump is running. 4. Check the drain pump filter for foreign objects. 5. Plug in washer or reconnect power. 6. If the above does not correct the problem, go to step 7. 7. Unplug washer or disconnect power. 8. Replace the pump.
  • Anonymous Mar 13, 2014
    I have a Maytag Epic Z front load washer model MHWZ600TB00 and I have been getting an F-21 code. I cleaned the coin trap, checked the drain hose, and inspected the pump including the impeller. There were no obstructions or debris in the impeller nor was not spinning on its shaft. It seems to have enough pressure and flow out of the discharge hose. I then replaced the pressure switch and I am still getting code F-21 and occasionally an SD code. I ran white vinegar through the washer since I had been using too much Tide HE detergent. I know it would seem likely to be the drain pump but it appeared to working properly. Can you help me?
  • 725 Answers
Hay Crab.
what I have found is that the washer thinks it is not pumping out .. if your drain pump is clearly removing the all the water in a good time... then the problem is your pressure is telling the computer that it still has water in the machine...
replace the pressure switch and it will solve your f21 error.
It is a round unit on the right hand side on top...with a tube and wires going to it...let me know if it helps
Posted on Apr 05, 2008
Model 5000 front loader. Why doesn't pump work?
Whirlpool washing machine drain pump replacement and ...
? 17:45
Feb 5, 2012 - Uploaded by HandySavesMoney The drain pump replacement procedure will apply to kenmore, whirlpool, maytag and other front-loading washing machines. ...does anybody knows about front loader whirlpool that won¨t start? i could use some help tx.
Oct 07, 2015 | Whirlpool Washing Machines
I have a whirlpool duet front load mod#wfw8300sw00 washer and it makes a horrible sound when spinning almost a grinding sound is it done? or could it be something minor?
i have wfw8300sw00 whirlpool duet sport, i start de machine it's turn ons side (right to left) and abour 3 minutes it stop off no message.
Apr 29, 2010 | Whirlpool WFW8300SW
Whirlpool front load leaking water from the detergent dispenser
Could be pressure too high reduce feed to machine only ....Slightly...Also try cleaning just in case its blocked
Sep 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Need a part number
The part number is W10160252. You can order the part at . The price is 131.10
Nov 13, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Washer won't final spin
After charging me $275 to change the water pump, the repairman said I needed a new computer board for another $160. I went & bought a new washer - this time a regular top loader mechanical washer with no computer. The repairman said computerized washers & front loaders in particular have lots of problems. He said top loader Whirlpools have the least problems.
Nov 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Whirlpool duet sport wfw8300sw00 f-21 error
Unplug the machine. Unscrew the 3 screws under the front edge of the washer. The service technician manual is attached to the panel that slides down and off. Find F21 code. See suggested procedures. Note: My drain pump filter had a baby wash cloth in it along with some change that was disrupting the flow. It is exceptionally easy to remove, clean, and reinstall. Just line up installation notches when reinstalling. Whirlpool should have mentioned this filter in the User & Care Guide, but I could not find it anywhere in there.
Mar 24, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Washing Machines Logo
1,064 people viewed this question
Top Washing Machines Experts
