I have an LG Flatron L1910S monitor which seems to have a powersupply proble.The green indicator light flashes when you start up the system and nothing comes on the screen.If you pull and tweak the power lead and then on it comes.If it is the lead then it should be a no brainer but I was wondering if there is possibly something wrong internally. Txs
  • ehben May 11, 2010
    Where is the dry solder ?
  • 35 Answers
Yes my friend.. Its just a dry solder(Loose contact).. you will need to resolder it with 0.5 mm -0.8mm lead.
Posted on Apr 05, 2008
Same power supply board LG L1910s and L1510s ?
just look the amper rating in the power supply if they are the same.
Sep 20, 2012 | LG Flatron L1951S 19" LCD Flat Panel...
The green light indicating power is blinking on and off and nothing is showing up on the screen.
when the green light is flashing it means it's not getting a signal from the computer..
1. try toggling through available sources with the source button on the monitor.
2.check all cables leading from the pc to the monitor.
Apr 02, 2010 | LG Flatron L1718S LCD Monitor
Problem on LG Flatron ez T713SH crt monitor
i have the same thing, monitor display is dark and tick tick sound audible and thats all it do untill now..
Feb 15, 2010 | Computers & Internet
Powering up problem with my lg flatron plazma tv
Those lights are a code. I don't know which TV you have, exactly. But the manual will tell you what the light code indicates and what to do about it.
Oct 16, 2017 | LG Flatron L1919S LCD Monitor
Lg flatron blank screen
t certainly seems like the monitor is not getting a signal. Did this happen after you changed something, or just on normal boot up?
It could be the video card that has failed.
Also, check the pins on the connector; sometimes they can get pushed in.
If you can, try swapping out the video card or use the monitor on another computer.
Good luck,
May 09, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
LG L194WT Monitor suddenly stop working
it is probably indicative of a switched mode powersupply trying to start then seeing a short and then trying to start again...this will cycle continuously until fault is rectified..any component that can drain the powersupply is the culprit...you need some way of detaching the powersupply from the load (monitor) to see if the power supply its self is the cause and also check if there is a loop back (a pulse) for continuous running.
qube
Jun 06, 2008 | LG Flatron 563LE 15.1" LCD Monitor
LG Flatron L1550S power light blinks green.
shorted components on the circuit. send it to a repair shop if you don't have experience on electronic troubleshooting!!!
Nov 27, 2007 | LG Flatron 995FT 19" CRT Monitor
Green-Amber-Amber Code?
I know that my post is very belated, but I think, will be helpfull for someone henceforth...
First of all, there is one "chronic" problem with LG monitors: solders. Check soldering of Video Amplifier IC303, Flyback Transformer, Q833( ! 210V) , deflection coils socket, Vertical IC601, XTAL X401 and so on...
In Your case, probably the cause of "green, amber, amber" lights is lack of 15V on the Verical Amplifier IC601. DPMS is activated, and monitor does not work at all, even power off.
Replacing Q912 (2SA1273) solve the problem. I replaced him with 2SA1680 PNP 1A 900mW 60V, and all is OK.
This problem is fundamental for ALL 17'' Flatron monitors, repaired by me (over 30).
Wish Happy Repairing!
Best regards, Ico.
Sep 14, 2006 | LG Flatron F700P 17" CRT Monitor
Computers & Internet Logo
201 people viewed this question
David Payne
David Payne
