Question about Microsoft Xbox 360 Controller
Wire controller getting disconnected from Xbox 360
The green light turns on fine, but the wire has to be held in a certain position or else it disconnects. This happens especially when you move the ball thing in the wire which is the one that has to be still to work. If anybody knows how to fix this issue please tell me. Also I would like to know what that ball thing is for.
  • 1 more comment
  • loz_grime Jan 02, 2009
    i have exactly the same problem, been using while holding the wire, and the problem has got worse, keeps disconnecting through games,
    i did ask my dad to open up the pad and see if the wire can be fixed, n he had a look and seems unfixable
    so im considering a wireless pad,
    unless anyone knows any ways of fixing the problem
  • supersaiyan Jan 12, 2009
    i tried both wireless and wired controllers and it still keeps gettin disconnected every minute. is it the console thats got something wrong with it?
  • Anonymous Feb 10, 2009
    This has happened to me twice. Microsoft must have done a terrible job at supporting the wires because I've already wasted my money on two controllers. Good thing I still have my two wireless working in perfect condition. I just hate frequently charging batteries.
This could be something to do with the wire being broken inside at or around controller wire connection. To fix, you may to need to replace the wire in that section.
Posted on May 06, 2008
Controller doesnt turn on but batterys are good
Connect a game controller
Solutions
Learn how to connect a wireless or wired controller to your Xbox 360 console.
Connect a wireless Xbox controller
  1. Turn on your console.
  2. Press and hold the Guide button on the controller until the controller turns on.
  1. Press and release the connect button on the console.
Xbox 360 E console fbbfb609-f7ed-4e6e-bd35-7543b1c20d61.png?n=xbox360-connect-m-s.png Xbox 360 S console Original Xbox 360 console 342c6e70-9e56-43d8-bb3a-05f5411040bd.png?v=1#xbox360s-connect-m-m.png 170df81e-0a79-49be-8236-a0fb68eec37b.png?v=1#xbox360-connect-m-m.png
  1. Within 20 seconds, press and release the connect button on the controller.
  1. When the lights surrounding the power button on the console stop flashing, the controller is connected.
On the Xbox 360 S console, each connected controller is assigned to one of four positions. Each position corresponds to a lighted section around the console power button and the controller Guide button. On the 360 E console, a solid green light on the front of the console indicates that the controller is connected. To determine the player position associated with your accessory, look at the ring of light that surrounds the Guide button on the controller.
c9341988-8ed5-4217-9b87-353de50efbec.png?v=1#connect-xbox-controller-m-m.png 5e4ab6ab-8cb0-41e6-a037-b88221a430c7.png?n=connect-xbox-controller-360-m-s.png
71add0b7-ddf2-4439-b4b4-f50f156d92b7.png?v=1#controller-batteries-m-m.png If the controller does not turn on, check the batteries. Insert fresh AA batteries, making sure they are correctly positioned in the battery case.
You can also use the Xbox 360 Play & Charge Kit or the Xbox 360 Quick Charge Kit to power the controller. Learn more about Xbox controllers and chargers.
To connect additional controllers, follow these same steps again. You can connect up to four controllers to the console. Each connected controller is assigned a position that corresponds with the lighted sections that appear around the console's power button and around the Guide button located in the middle of each controller.
  • To disconnect a wireless controller, press and hold the Guide button for three seconds, and then choose to turn the controller off.
  • When you turn off the console, the controller will reconnect the next time you turn on the console.
  • The controller can be connected to only one console at a time. You can connect the controller to a different console, but the connection to the previously connected console will be lost.
Oct 11, 2013 | Microsoft Xbox 360 Controller
My controller was working one day and then stop working the next day it had fresh battery
Solutions
Jul 31, 2013 | Microsoft Xbox 360 Controller
Ho w to fix x box from controller to x box is really slow how to make it normal
Connect a wired Xbox controller
5fb17f50-7448-45d5-a294-9ea90994f55b.png?v=1#controller-wired-m-m.png Plug the Xbox 360 Wired Controller into a USB port on the Xbox 360 console. There are two USB ports on the front of the console. To disconnect the controller, pull on the connector, not the cable.
cbe46bf0-3a46-4d53-9d8c-6697aa57622a.png?v=1#controller-cable-release-m-m.png The cable on the Xbox 360 Wired Controller has an inline release. The inline release on the controller cable is a safety feature designed to reduce the chance of the Xbox 360 console falling if the cable is pulled.
Wireless controller troubleshooting
If your wireless controller disconnects or cannot connect to your console, see Xbox 360 Wireless Controller disconnects or can't connect.
If your wireless controller does not turn on or loses power, try the following solutions:
Solution 1: Replace the batteries
Insert a new set of AA alkaline batteries into the Xbox 360 Wireless Controller, and then try to turn it on.
Solution 2: Try a different battery pack
If you have another Xbox 360 Wireless Controller, take the battery pack off that controller and attach it to your controller. Then try to turn your controller on.
If your controller works with the different battery pack, your original battery pack might be defective. If your controller is under warranty, you can order a replacement battery pack from Xbox Support . See the Assistance section at the bottom of this page for more information.
If your controller is out of warranty, you can buy a new battery pack from a retail store.
Solution 3: Try a rechargeable battery packIf you or a friend has an Xbox 360 Rechargeable Battery Pack, attach that battery pack to your controller and try to use your controller. If your controller works with the rechargeable battery pack attached, you can buy a new battery pack from a retail store or order a replacement battery pack from Xbox Support. See the Assistance section at the bottom of this page for more information.
Feb 08, 2013 | Microsoft Xbox 360 Controller
My xbox 360 mic is acting up. I can talk to people but I can only hear them if the plug is twisted to a certain position
Sounds like a wire broke inside. That's why it only works when you have it in a certain position. Unless you are good at splicing wires, move the wire till you get it to work, and wrap it in that position, then don't move it at all. Good Luck.
Jul 01, 2012 | Eforcity HEADSET W/ MIC CONTROLLER FOR...
Wired xbox 360 controller wont work
Have you tried turning the console off and back on
Jun 11, 2012 | Microsoft Xbox 360 Controller
All 4 lights keep on blinking on my controller
You may need to "Sync" the controller to your Xbox console.
1) Press the sync button on your Xbox 360. The green lights on the Xbox will swirl.
2) Press the small white button on the controller (between the bumper buttons).
After a few seconds, the position 1 green LED should light up on the controller.
Apr 05, 2011 | Microsoft Xbox 360 Controller
When I try to turn on my xbox 360 my controllers do not connect to it. I get the green power light on the front of the xbox 360 and four flashing green lights on my controller. I have tried my...
Press the circle button in front of your xbox 360 and at the same time press the small circle button on your controller ( located near the port where you connect the play and charge kit cable) so they can sync with each other
Sep 16, 2010 | Microsoft Xbox 360 Console
Xbox 360 wired controller glows green for 2 secs then shuts off
Microsoft software is usually very good about finding mods within their systems. Since you have repaired a wire, it might somehow think it's been modded.
Double-check your repair work, if you used a soldering iron, it could have attached to another wire -causing a short (faking a mod). If you just twisted and taped it, you might want to consider a better fix.
Aug 01, 2009 | Microsoft Xbox 360 Controller
When i turn onmy xbox 360, i get the green lights and i get sound but i dont get a video! how do i fix that?
u probaly didnt connect one of the three wires to your tv too well try doing that i think that  will fix it because i have an xbox 360 too and i had that exact same problem yellow wire red wire and white wire
Jun 07, 2009 | Video Game Consoles & Games
Xbox 360 Wired Controller Busted
Yeah I foudn the problem. I just found out one of the wires was broken inside, right above where the controler meets the wire. It was a grayish wire, probably the one that turns it on. No wonder it would only turn on if the wire was in a certain position, it was connecting the wires! Problem solved.
Aug 17, 2008 | Microsoft Xbox 360 Controller
Microsoft Xbox 360 Controller Logo
715 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
