Question about Ovens
Overn will not work properly
I have” Maytag Gas Percision Touch control 500 Oven” Model # MGR5765QDS Range (Powered by Electric) When I turn the power on to bake It just sets @100 degree the gas is not flowing and it dose not heat at all . But if I turn the Broiler on with both setting high and low it works. I try to go back to Bake it will not work the oven is fairly new installed on Jan 2006. Per Maytag customer service re advised I turn the power off from the breaker circuit for 10 min and let it set for 2 min and turned the power on .It the not work please advise thanks
    President:
  • 2,651 Answers
Sounds like you have a bad oven ignitor, very common problem with alkl gas ranges, easily repaired by you a few screws and a wire harness part number 12400035
Posted on Apr 05, 2008
SOURCE:
Preheat goes to 100 degrees and stays there. All push buttons to 27 in Jenn-air oven work and after 45 minutes unit heats up.Now not heating up at all.
whenever you set an oven it always starts at 100,if that's an electric oven most likely the bake element is bad and the broil element is just working and heating up the oven,when you set the oven to bake both the broil and bake elements get hot.if it's gas most likely a bad ignitor,send the model number if you write back,also if that's an electric oven make sure you flip the breaker so there's no power going to the oven before you try to remove the element,i see people try to remove the element with the power still on and when they pull out the element the wires touch the metal and bang they short out the clock assy.kill the power,remove the two screws that hold the element in place or if this isn't a wall oven slide out the oven,unplug it,remove the back wall and with a meter read out the element,remove at least one of the wires first and then check it,very simple set your meter to 20k,ohms touch the leads to the element where the wires connect to it,if you see a 1 the element is bad or open,if you see anything else but 1 the element is good or closed,hope this helps you out
May 26, 2018 | Jenn-Air Ovens
Maytag double electric oven. we turn on to bake and would switch to broil then will turn off.
Assuming this is on a gas range, the bake burner ( under the oven floor) and the broil burner ( at the top of the oven) have electric igniters . When switching from bake to broil the broiler goes off due to a defective or broken broil igniter. cheap part to replace ( +-$40.00)
Oct 16, 2014 | Maytag Ovens
I have a kenmore oven. Just got an F2 error and the oven element will not turn off. Even when powered down, it heats back up when oven is in off position.
Range "Older Style"
F2 Oven too hot Replace relay board (if present) or oven temperature sensor
Range "Newer Style"
F2 Oven temp sensed; over 600F sensed by control in time of day mode, bake mode, or over 900F sensed in clean mode. Ohm test the oven temperature sensor, if OK, change power relay board.
Oct 17, 2012 | Kenmore 40494 / 40495 / 40499 Electric...
Turn oven on to 350. It clicks and goes to 100. Stays at 100 and never heats up.
Assuming a digital oven with a thermometer: The 100 degree reading is probably the lowest reading the thermometer will register.
Don't give me a poor rating because I said your question was poor. Include as much information as possible including basic description of appliance and model number. Try different things and state what works as well as what does not work.
In this way, you can get better answers. As is, I know nothing about your oven except that it does not work. My keyboard will not fix your oven. It would be helpful if you convince me that you are not afraid to physically enter your oven and touch things.
:o)
Jun 03, 2011 | Maytag Ovens
Maytag gas oven has an F1 code. Model # CGR3740ADW.
The F1 code on a Maytag electric stove means the electronic range control, clock or touch pad is defective. You or a technician can do a test to determine which item is broken, but you must replace the electronic clock range in models where the touch pad and range control are one part.
Feb 01, 2011 | Maytag 24" Built-In Single Gas Wall Oven -...
I have an in the maytag gas oven that keeps beep and show f-1 when its shut off
This simple test will help determine whether the ERC (Electronic Range/oven Control or Clock) or the touch pad is defective when this error code is present.
1. Disconnect power to the range/oven (unplug the range/oven power cord or turn the power off to the range/oven at the circuit breaker). It is very important that the power to the range/oven has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC/EOC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the code comes back (usually accompanied by a beeping sound).
7. If the code comes back and the beeping as well, replace the ERC(control board). If it does not, replace the touch pad.
Nov 02, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
Maytag gas oven wont restart after pre heat
you have a bad oven sensor /faulty connection or bad control board.look for probe coming thru inside rear wall.should read 11k ohms cold.go bad a lot part number Hope this helps ,please rate my response :)
12001655
Jun 25, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
Maytag oven reads fi
Defective touch pad or clock (ERC)
This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Jun 01, 2009 | Maytag Ovens
Maytag oven will not light
Have you tried to broil or bake? if only one of them work you have a bad ignitor. let me know and we can go deeper
Aug 23, 2007 | Maytag CWG3100A Gas Single Oven
Ovens Logo
159 people viewed this question
Top Ovens Experts
Marvin
Marvin
Are you an Oven Expert? Answer questions, earn points and help others
