Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
250 gig WD EHD
I pluge it and nothing shows at all no noise or anything . I just unpluged it because I moved before it worked fine,
  • 30 Answers
Try to right click on "My Computer"->Manage-> Disk Mng.
Then try to see if you can recognize you this disk.
maybe you just need to change the letter or format it.
Posted on Apr 11, 2008
I loaded 100GB of data on this EHD that was just purchased. It worked just fine loading the data and I could retrieve data right after initial load. The EHD was unplugged and sat for a few days. When we...
You're best bet is to extract the hard drive from the enclosure. Get a SATA to USB adapter (http://www.newegg.com/Product/Product.aspx?Item=9SIA1PU0ME3070). Connect that to your PC. If the problem is not with the HDD you should be able to extract any data without any issues.
Mar 08, 2013 | Computers & Internet
USB Connection failed? (WD 1tb My Book Essential 2.0)
Your HD may have died. This is actually a common occurrence with some external enclosures with WD hard drives installed (just do a Google search, you might be surprised how many people have had the same problem as you describe...)
Your actual HD may have SATA connections (but connects to a SATA-to-USB controller). Some people have claimed that removing the drive from the enclosure and connecting directly to SATA port on motherboard yielded a successful connection.
I wouldn't recommend this, as your drive may still be under warranty and might qualify for a free or low-cost replacement.
Your USB is likely working fine. However, the drive will not show up if it is dead. I encountered a similar issue with a WD external HD recently. USB connection gives the sense that "something" might be working, but if your drive isn't seen under disk management, there's a good chance that it may have failed.
Hopefully you have your sensitive data backed up.
Good Luck!
Jan 24, 2010 | Computers & Internet
I purchased 2 WD elements 1TB. I have pluged it
right click on the drive , format it and it should work, if this not solves your problem go to the shop and use your warranty, it may be broken.
Nov 16, 2009 | Western Digital Elements powered by WD 320...
WD 250 gig ext hard drive
Hello there:
you may want to unplug the device for 3 min and hold in the power button or the reset button for 30 seconds and than power the device back up and see if this helps If not go to control panel and click on system and look for the device manager and see if it is listed there if it is click on the device and where it says remove say yes than click yes again than shut down and restart the computer and the found new hardware will start up and reinstall the device again for you. ok? please keep me informed how this is going,
best regards mike
Aug 03, 2009 | Western Digital My Book Essential Edition...
My WD Mybook TByte HD is not being recognized
There could be many reasons, but I had the same issues.
It turns out I had mistakingly swapped the 12v DC PSU with another one, the drive would light up, it would click but that was it. Nothing. Gave me the runaround for ages. Seems they need more current than the little PSU I was trying could deliver, so I swapped it for a 2 amp supply and it works fine.
Mar 13, 2009 | Western Digital 250GB MyBook External USB...
Maxtor 3200 200 gig not recognized
When your drive is in RAW format, the best thing you can do is try to recover the files and then get the hard drive replaced. I would recommend trying the trial version of this program: http://www.recovermyfiles.com
If that doesn't work, let me know, and I'll see if I can come up with another way to solve the problem
Feb 23, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Worked yesterday / not working today
Someone else figured this out, but I've seen a lot of people with the same problem. Hopefully this will help you with yours. This is for WinXP and Windows Vista. It worked great for me.
*** THIS WILL VOID YOUR WARRANTY ***
1 - Disconnect the HD from USB and power supply.
2 - There are 2 screws at the back. Unscrew and open the box. (The plastic is kinda hard to open be careful)
3 - Now you have a metal box in your hands. Unscrew and open it.
4 - Now you will see a HD and a controller board. There are 3 screws that holds the controller board. Take them out.
5 - Now slide out the hard drive and controller board out gently.
6 - Unplug the controller board (power socket and IDE socket)from the Hard disk.
7 - Look at the back you will see jumper settings. (Mine was set on Cable Select.)
8 - Take the jumper out and plug it to Master ON position. now put it all back together.
Jan 25, 2009 | Maxtor Personal Storage 3200 (M1227310)...
WD portable 250 gb drive w/20 gigs of pictures
Is it truly broken or just not working, ie, not being recognized?
If it is broken, there are companies who specialize in data recovery.
One site is:
http://www.harddiskrecovery.net/
I've never used such a service, but they will give you a free quote.
Oct 14, 2008 | Western Digital 250GB MyBook External USB...
External HD not starting properly
my 500 gig mybook is clicking and not showing up at all, I am going to serioulsy lose my mind WTF!!!!
Sep 13, 2008 | Western Digital 320GB MyBook External USB...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
80 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
