Question about E-Machines eMachines Desktop PC
I'm trying to open my computer tower
I know you have to remove the side panel but I can't get to come off.  Is there an online manual anywhere that will tell me how to open it?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 198 Answers
Usually only one of the side panels comes off easily. I'm sure you'll find the online manual from your maker's site, but usually you just have missed one last screw that's keeping it from sliding out. Usually there are 4, but I once had a panel with 5.
Posted on Apr 05, 2008
How to open tower
Generally there are two screw that hold a side panel in place, they will be on the back of the tower on the right side if you are facing the back of the computer. You will seem them screwed into the panel. One of the top and one on the bottom. Slide the panel backwards, and pull it off. Some computers are different, depending on the model and manufacturer. Some dell computers have a handle on the back or side that you open it with. Never open the left side of the computer (when facing the back of the computer).
Apr 23, 2012 | ASUS Essentio CG5270BP003 PC Desktop
Tip
How to resolve a "NO VIDEO" problem on your Desktop computer?
1. Turn the computer off...
2. Remove the Power cable and drain the power by holding down the power button for 10 seconds...
3. Remove the side panel of your CPU Tower (refer to manual how to remove side panel)...
4. Loosen the screw of your Graphics card and remove it then replace it back!
5. Connect all cables and put the cover back...
6. Turn your computer back on!
Note: This trick applies to desktop pc's with video card. If your graphics is integrated with your motherboard, try reseating the video cable instead.
on Jun 08, 2010 | Computers & Internet
Open emachines el1352g-41w
Open the eMachines EL1352G-41W computer case?
Unplug the computer from power. Unplug all cables. Turn the computer tower around so the back faces you.
Look at the Left side. This Side Panel removes.
There is a handle for your fingers, formed out of the Side Panel's sheet metal.
Above the handle along the edge, and towards the Top, there is a Philips head screw. Loosen this screw. (It isn't supposed to come all the way out)
Down below the handle, and towards the bottom, is another Philips head screw. Loosen this screw.
Use the handle in the Side Panel, to pull back on it. Pull towards the back of the computer tower.
The Side Panel may only pull back so far. There may be tabs which stick out of the Side Panel, and go into slots in the computer tower's case.
For this style the Side Panel will only pull back approximately 1 inch, or so.
Then the Side Panel is brought straight out away from the computer tower, and laid aside.
[ NOTE*
Do NOT forget to observe Anti-Static Precautions BEFORE reaching inside your computer, and working on it.
Computer on a table, computer unplugged from power, computer case open.
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
Should you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
For additional questions please post in a Comment.
Regards,
joecoolvette
Dec 02, 2011 | E-Machines eMachines Desktop PC
Opening the tower to add Ram memory
I happened to find a PDF on compaq's support site: if you use Ctrl+F in your web browser and put in DC5100MT it will take you down to the right place. Simply open this PDF if your favorite viewer and there's a whole series of images explaining how to take the panel off (page 4).
Jun 05, 2010 | Compaq Presario 5000 PC Desktop
How do i remove the cover of a Gateway MFATXPNT NMZ 500SE
I found this:
"Facing front of computer you need to remove the left side cover. cover release is on top of the computer in center of side panel. Press in on button and p[ull top of side cover away."
Don't know if it's useful. If not let me know and I'll keep looking.
Mar 16, 2009 | Gateway Computers & Internet
Problem opening computer tower
Visit this web-page:
http://esupport.sony.com/perl/model-documents.pl?mdl=PCVRX650
Next click on the link reading, "System Reference Manual" located underneath the, "Manuals" category. There are instructions on how to open the side-panel on page 36.
Let me know if I can assist you further.
Mar 15, 2009 | Sony Computers & Internet
Noisy
there are two screws on the back of ur tower for each side supporting plate .remove the side plate which is on the other side of ur motherboard.then just blow out all the dust with a air blower.
Dec 22, 2008 | Gateway 504GR PC Desktop
How do I get the front cover off a Gateway tower? It is a GP7 800.
you need to provide a serial number of your computer and model. gp7800 does not say much to lookup that information for you.
in general most towers are secured with plastic tabs that are secured to the chasis of your system. what i suggest is for you to open on of the side panels and check at the back of the front panel if there are tabs securing your front panel. you don't want to force the plastic panel or those tabs as you may brake them if you apply to much force, simply move the tab to unsecure it and check all the tabs had been moved to an unlock position before jiggling with the part in order to remove it... you may also want to look if your system has a top pannel to be removed as removing this top pannel may also release other panels and may also provide acess to latches or tabs on the top part of the front panel that may allow you to unsecure these portion.
I've been trying to obtain general information on your system or any other gateway tower for you to have an idea but given how generic and also how propriatery this instructions may be is unlikely a service manual may be accessible.
with more info on your system you may want to inquire with gateway if there's a service manual with schematics by checking with them online. at this location.
http://support.gateway.com/support/ask_gateway.asp
Oct 08, 2008 | Computers & Internet
I dont know how to open up the cas of my compaq to install the memory
What is the model of your computer?
Is it a tower?
If it is a tower, look on the back of your case. Along the right side there should be two screws. Remove both screws, grasp the side of the case where you removed the screws, and slide the side backwards. The panel should lift right off.
Apr 16, 2008 | Computers & Internet
Removing the faceplate
Hi, I can help you with this. Are you trying to remove the cd-rom drive bay plate or the front panel of the tower?
Sep 16, 2007 | Compaq Presario 5000 PC Desktop
E-Machines eMachines Desktop PC Logo
56 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
