Question about Whirlpool 30 in.GJC3055 Electric Cooktop
Cooktop WIring I have four wires on my cooktop. Black, White, Green, and Red. I only have two wire from the wall, Black and Red. How do I connect my cooktop?
  • 725 Answers
To complying with changed Codes (effective in 2002 ) regarding stoves, ovens and dryers. You will need a 120/240 volt 4 wire 40 amp and 50 amp circuit. This
Decades ago it was permitted to use a 3 wire system (having two 120 volt hots (Black and Red) and 1 combination ground/neutral wire) (green and white) to serve stoves, cooktops, ovens and dryers.
The Code change now requires all stoves and dryers in NEW construction to have the 4 wire set-up (now having two 120 volt hots, 1 white neutral and one green or bare wire ground).
Existing wiring is grand-fathered under the Code change.....I advise you to change the feed wiring over to the the 4 wire set-up...
because - as with ALL Code changes in the past...it will eventually become mandatory for all stoves, ovens and dryers as the grand-father clause drops off. By complying now...
BUT the wiring will need to change to 8/3 with ground. (having 4 wires inside one outer jacket).This is the primary reason for the Code change....to provide a greater margin of safety to the user.
I can NOT recommend the 3 wire hook-up...the 4 wire provides a seperate ground and neutral -
which makes the chance of a user shock when touching the metal frame (from an internal fault in the oven) much less likely then the old 3 wire set-up....
which did NOT have the seperate ground and neutral.
Krazytech
Posted on Apr 05, 2008
Wiring for Kenmore Elite Induction Cooktop
The white one may just form an earth loop,, I recently had a ceramic plate needing cleaned so we did the whole lot, I think most hobs have 4 wires and they are numbered rather than colour coded..hope this helps
Nov 10, 2013 | Kenmore 30" Induction Cooktop Stainless...
Helping a friend install a new unit... he has 3 wires where we took out the old unit (the old unit had 4 wires) .. the (source) 3 wire is black, white & bare.... the old and new unit have black, red,...
I suspect on teh wiring from the house the black&white will be the hot wires and the bare will be ground/neutral
use a volt meter before connecting tonew cooktop and check for;
black/bare to have 120volts
white/bare to have 120volts
if that is what you find...connect new cooktop as such;
black to black
red to (house) white
(cooktop) white and green to bare
GENE
Sep 07, 2011 | Whirlpool GJC3034 Electric Cooktop
Do i connect the red and black wires together
No you do not. You have a 220 system. What you do to hook it up is. In the box in the wall you should have 3 wires. 2 black and one white. Then on the cooktop you have the 3 wires 1 black, 1 red, and 1 white. You take the black from the cooktop to the black in the wall box. Take the red to the other black in the wall box. then take the whites and put them together. Now if you have a green or bare wire that is the ground. Just hook that to the wall box.
If you have any questions please ask.
May 09, 2010 | Jenn-Air JED8230 Electric Cooktop
Fixing wiring
yes, that is the correct wiring
Feb 08, 2009 | Jenn-Air JED8430 Electric Cooktop
COOK TOP WIRING
 You have Red and Black HOT wires and a Green Neutral - That is 220 volts. From the wall - Black is Normally HOT and White is Neutral. That is 110 volts. If that is a typical household outlet, is will only supply a demand at about 15 amps while running at 110 volts. Your Cooktop will most likely demand somewhere around 50 amps at 220 volts. - Short Answer - You will need to have a 220 volt supply line ran to the cooktop from the breaker. Easy to do but dangerous if you are unfamiliar with high voltage.
Apr 30, 2008 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air JED8430 Electric wiring confusion
On Cooktop From Box
Black to Black
Red to Black w/red stripe
White to Ground
Green to Cooktop frame
Nov 16, 2007 | Jenn-Air JED8430 Electric Cooktop
Wiring installation
You do need a 208/240 volt supply from your service panel. The green is ground, white is nuetral, and the red and black should measure 120 volts each to ground or 240/208 between each other. It is normal for most breaker panels to supply 208/240 between adjacent insulators. If you are only getting 1/2 of that then the circuit breaker may not be straddling the insulator bar but be 1/2 notch out and both breaker pins contacting the same 110 supply.
Apr 14, 2007 | Jenn-Air JED8430 Electric Cooktop
Whirlpool 30 in.GJC3055 Electric Cooktop Logo
554 people viewed this question
Top Whirlpool Cooktops Experts
Timllfixit
Lakeland Appliance...
Are you a Whirlpool Cooktop Expert? Answer questions, earn points and help others
