Question about Toshiba Satellite M35X-S109 Notebook
Wireless network connections
About a week ago my pc had some problems and some items are now missing on from my pc. One of the items missing off the pc is the wireless network connection from under "network conections" the folder.
    Scholar:
  • 119 Answers
If your laptop came with a "System Restore" disc, back up all your data first, then boot off the System Restore disc. That will return the laptop to the state that you initially received it in.
THE RESTORE PROCESS WILL WIPE OUT ALL YOUR DATA - so make sure you copy anything you want to keep to a USB stick, another computer, a thumb drive, or somewhere other than on your laptop.
Posted on Apr 05, 2008
SOURCE:
Gateway purchased new 3/2010 has been connecting flawlessly to wireless internet until a few weeks ago. Solution had been to click on Open Network and Sharing Center, click on Troubleshoot problems, click...
Are you connecting to your own wireless router? If yes, have you changed anything in its configuration, or inadvertently reset it? If you're connecting to someone else's router (neighbor, etc.) it could be that they have locked you out. Does the wireless network show as secured? This sounds more like a security issue than hardware or driver.
Jan 06, 2011 | Gateway Computers & Internet
For the last few weeks i haven't always been able to connect to the net,on the few occassions i have no prob! but why can't i always get in? had this notebook for 14 months without a prob. only started...
first i would try moving the switch that is located on the front of the netbook to the right. Once the switch has been moved the wireless networking icon will appear on the screen indicating that it has been enabled.If this doesn't help my next step would be to remove and recreate the wireless network connection by doing the following:
  1. Click on Start, Settings, Control Panel
  2. Open Network Connections
  3. Right-click the wireless network connection, and click Properties
  4. Click the Wireless Networks tab
  5. Under Preferred networks, click the wireless network, and then click Remove
  6. Click View Wireless Networks
  7. Under Network Tasks, click Refresh Network List
  8. Under Choose a wireless network, click the wireless network to which you want to connect, and then click Connect
In Windows, there is a power mode setting for the wireless driver that may also help this issue. Follow the instructions below:
  1. Go to Control Panel, System, click the Hardware tab and select Device Manager.
  2. Click the + next to Network Adapters and double click on the Atheros wireless Network Adapter.
  3. Click on the Advanced tab, select Power Save Mode from the list on the left.
  4. Change the Value on the right to Off.
    The default setting is Maximum, which may cause issues similar to those described.
Check to see if this has resolved the connectivity issue. If it has not, the following steps may need to be completed.
  3. Right-click your wireless network connection, and click Properties
  5. Under Preferred networks, click the wireless network, and click Properties
  6. Click the Authentication tab, click to clear the "Enable IEEE 802.1X authentication for this network" check box, and then click OK twice if this doesnt help the computer may need service.
Oct 25, 2009 | Acer Aspire One PC Notebook
I'm not too familiar with wireless internet problems concerning connecting to the web. My daughter has a hp pavilion zx 5000 laptop bought originally in 2002 by their real dad. Up until a week ago she was...
Do you have a wireless router connected to yoru ISP modem I guess ? you must know the SSID name of the wireless network for it. you must open the wireless connections on you rdaughter's PC and make sure to select the SSID belongin to your wireless router.
Jun 03, 2009 | Microsoft Internet Explorer 8
HP Wireless "working" but it won't connect to networks
I had a similar problem with my HP g60-243cl and new drivers solved the problem. I also have to turn off wireless and turn it back on a couple times if I switch networks.
Apr 09, 2009 | HP Pavilion G60-120US NoteBook
My HP wireless doesn't work? I don't have wireless connection on my compaq laptop anymore.
check your wireless adapter is on... the switch is on the front of your laptop and you should show a blue light when it's on, also go into device manager and see network adapters.. you should have 2 (the wire one built-in and your wireless network adapter.. if you only have one network adapter, check the front and see if the light indicating the status of your wireless network adapter is amber.. (if it's showing amber and you're sure it's in the on position you may have a motherboard problem and you may need to send the system back (I just had one of those with a compaq computer and since the item was within warranty the fixed in a week)
if your wireless adapter light is blue and you see your wireless adapter in device manager follow this instructions and you should be ok,
vista
http://www.home-network-help.com/vista-to-connect-wireless-network.html
xp
http://www.home-network-help.com/wireless-adapter.html
Oct 03, 2008 | Computers & Internet
Wireless connection issues (to be origional lol)
Is your desktop pc still working fine.., clear your preferred wireless networks in your laptop, try searching for the wireless network again, check if you are abe to pick up any other wireless network in your laptop, so that you can conclude whether the problem is with the laptop or the router..if not try reconfiguring your wireless settings in your wireless router and check it out ,that will fix your problem..all the best..
Aug 17, 2008 | Computers & Internet
Internal Wireless Adapter for eee 900 device not listed
try Fn+F2 to enable the wireless.
As for the multiple entries in device manager, I'd delete the #2 version
Jul 03, 2008 | Computers & Internet
Dell Laptop WiFi Connection
Right click on the WiFi icon on the taskbar, select "view available wireless networks".
Then right click on change order of preferred networks
If the "Use windows to configure my wireless" is unticked, tick it
From the list below select the network you are trying to connect to and remove it and press OK
Then right click on the WiFi icon again and Vioew available networks and try to connect
Jul 03, 2008 | Sony VAIO GRT260 Notebook
Wireless connection
that unit has a driver problem, for the usb or ethernet, you might be able to re-install the specific drivers on their web site, and retry it there, unless the wireless in pci based and the you have a driver problem there, if you can use the ethernet connection then it's usb or pcmci, try that, if that doesn't work you need a tech to look at it.
hope this helps you out, let me know
Jun 15, 2008 | Acer TravelMate 2300 Notebook
Toshiba Satellite M105 - will not connect to the Internet...
the wireless card may need a new or updated driver to be compatable with the network
Jan 02, 2008 | Toshiba Satellite M105-S3004 Notebook
Toshiba Satellite M35X-S109 Notebook Logo
66 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
